Old March 9th, 2010, 17:17   #1
keaton
keaton's Avatar
TDI(s): 2005 Mk5
Default DIY ECU tuning?
so I'm new here, i have just been reading and poking around in my free time for several months....
i was wondering what the TDI market is like for the DIY tuner?
from my understanding, from vag-com's website it does not do ECU flashing/reprogramming...
i don't own a TDI yet, but when i sell my BMW I'm going to get one.
before i bought my BMW i started learning/decoding the OEM ECU (chip tuning blows) but figured out my BMW's DME as well as the next generation of motor after mine. the biggest problem in that battle was the market was so tight on information that people who knew stuff didn't want to help and if they did help it wasn't much..... so needless to say after i figured it out i handed out a lot of information to help the DIY'ers. from NA tunes to FI tunes, MAF rescaling, injector scaling, load rescaling, and also helped with remote tunes. pissed off pro tuners
keaton is offline   Reply With Quote
Old March 9th, 2010, 18:54   #2
vwmikel
vwmikel's Avatar
The TDI tuning market isn't much different. There is a lot of information out there if you want to do a very basic tune, but most of the people who know a thing of two more than the basics tend to keep their mouths shut.
vwmikel is offline   Reply With Quote
Old March 9th, 2010, 19:16   #3
keaton
keaton's Avatar
TDI(s): 2005 Mk5
where is a good place to start reading?
do the post 1996 cars go through the OBD scan port, or is it going to be like OBD 1 chip tuning with EEPROM emulators (for easy tuning)?
so with software interface are you guys using to edit the maps? in a hex editor?
so what i'm thinking of getting a a ALH motor (1998-2003), i was thinking post 1999.5 so the car comes with a VGT
i see people doing MAF to MAP setups, whats the reason? if your doing a rescale of the MAF table why no use a bigger MAF?
does the computer have the code for running both MAP & MAF?? the e46 BMW computer has a software switch that allows the tuner to use either MAF or MAP... just different pins on the ECU and different formulas for calculating fuel, timing, etc.
Old March 9th, 2010, 19:30   #4
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
So you published a bunch of BMW tuning secrets and in doing so pissed off the professional tuners that refused to help you learn how to tune BMWs???
And now you want help to do the same to the professional TDI tuners?
I hope I read that wrong....
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old March 9th, 2010, 19:36   #5
vwmikel
vwmikel's Avatar
The '96 Passats were actually OBD1 at first unless they got the TSB recall ECU. The OBD1 ECU is 8 bit and uses two DIL EPROMs. '97-'98 Passats and MK3's used OBD2 ECU's that used two PLCC32 EPROMs. These were 16 bit. Nothing is OBD flashable until 2000 model year.
The software that people use varies, but you can bet that nobody is using a basic hex editor. I see that as being somewhat crude since you wouldn't have 2 and 3D mapping capabilities.
All US MK4's have VNT's. That includes '98 Beetles and '99.5 Golfs/Jettas.
The primary purpose of the MAF on most TDI's is to control the EGR. It is also used for smoke limiting on US TDI's, but that can be switched to reference the MAP sensor. The technical term for this would be speed density.
Old March 9th, 2010, 19:44   #6
vwmikel
vwmikel's Avatar
Bill
That is exactly the kind of thing that people are afraid of. Of course there is the obvious reasoning that they don't want to create a competitor, but a far worse scenario is the guy who knows just enough to be dangerous.
It is often that I get people asking a lot of questions, but the point I try to make is that learning to tune TDI's is not a way of saving money when tuning your own car. Just the time alone to learn enough to do a basic tune on your own car would make that prohibitive. What we charge really is cheap when you consider how much time we have into development and the money that we have into software and tooling.
Old March 9th, 2010, 21:05   #7
keaton
keaton's Avatar
TDI(s): 2005 Mk5
Bill
That was the end result, not the goal. There was a huge DIY calling and tuners raping the market $1200+per tune is too high, same price for a stand alone. Others were already trying it, I just happen to have a back ground in electrical engineering and software on embedded systems. Its not that big of a secret just knowing what to look for in the hexadecimal ...
1999.5+? I keep reading that a model to get for the golf /Jetta
Winols and tunerpro rt do both. TunerPro RT also does real time tracking in the hex
Yes I'm aware that its called speed density system. Is this a software switch or a MAF table rescale?
Old March 9th, 2010, 21:19   #8
keaton
keaton's Avatar
TDI(s): 2005 Mk5
Not the goal to be a Pro tuner. just a DIY'er.
My time is free for my projects. You say its cheap for what I get, but if I want my tune tweeked to optimize my upgrades after everyone then that's a new tune...... diesel tuning is not that hard, go back to the cummins Gen 1/2 4bt/6bt no DME just a mechanical IP. More fuel = more power and higher egts, more air = lower egts. ...
I'm not new to diesel tuning, just new to diesels with a DME.
Old March 9th, 2010, 23:50   #9
vwmikel
vwmikel's Avatar
'99.5 Golfs/Jettas were MSA15.7 and not OBD flashable. '00-03 is EDC15V and OBD flashable.
I use winols, but I don't think TunerPro will run a 16 bit emulator....at least not the last time I looked.
It's kind of both.
Neither was it for me.
I'm not sure who would charge you for a small update. Most of us are pretty liberal with that sort of thing if you bought a loader. Diesel tuning may not be as hard as some gassers, but it is far from as simplistic as you make it sound.
Old March 9th, 2010, 23:57   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Most tuners charge a small fee, some none, for retunes due to hardware changes.
If only it was simple. What are safe boost levels at what RPM? How much timing advance do you choose? How much N75 (controls the VNT vanes) duty cycle? How far out do you run the torque to and when do you start dropping it? How do you avoid over-speeding the turbo? How much fuel do you add or pull for various nozzles? How much fuel do you add or pull to keep smoke and EGTs in check? Then factor in the various turbos that have different operating ranges and speeds. Also account for those with stock or upgraded exhaust, stock or upgraded clutch, stock or upgraded IC and/or IC pipes.
On top of THAT, what maps do you change?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old March 10th, 2010, 00:32   #11
hatemi
If you're interested in learning then www.chiptuners.org is a place to start digging. Be prepared for some hostility and territorial pissing. You just have to live with it. Just don't ask before you have done some searching yourself and show the results of your own work. For example if you're asking for what a certain map does then show what maps you already found out yourself. Too bad the good tutorials are not available anymore.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old March 10th, 2010, 01:14   #12
ryanp
ryanp's Avatar
I would love to learn to map but on the other hand i dont value my time as 'free' so the endless hours tweeking, burning, logging ect could get very boring, instead i pay some and the file that works perfectly first time falls into my inbox
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old March 10th, 2010, 04:28   #13
Rub87
cheap 16bit emulator that can do 29f400 psop44 or twin 29f010 plcc32 would be nice
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old March 10th, 2010, 04:57   #14
ArturCosta
Fuel Economy: (7.5L/100)(5.5L/100)(4.9L/100)
x2
Artur Costa
Audi A4 1.9TDi(110bhp) 1996
GT1852vb , PP764+T4 Injectors+hammer mod ,260 dbilas cam, 450nm kevlar clutch , 5speed TDI115 gearbox, 60mm inox exhaust pipe , fuel cooler,oil cooler , 5L FMIC
ArturCosta is offline   Reply With Quote
Old March 10th, 2010, 05:56   #15
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Tuning like everything else requires a certain skill to be proficient at. Tuners WILL protect their market vigorously. IN the end, they will lose to the folks who like open source tuning\editing. The ones who are really gifted, have nothing to fear from such groups. They will always be ahead, and available for a fee (of course) to fix the mistakes made by those with inadequate knowledge. Its just like auto repair. Most everyone (at least on sited like this) do their own brakes, many do their own turbos, injectors, oil changes and so on. That market was badly diluted so that auto repair places cant make money easily. Of course....shops were "thieves" for charging for "simple" repairs that most have to read a how to to accomplish and still need help. Just like you said about tuners. They are "thieves" for charging for their work and experience. But like auto repair shops...the tuners will fall as well. BUT again, like a gifted mechanic, a gifted tuner NEVER has to worry.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Page generated in 0.19782 seconds with 9 queries
[Output: 139.89 Kb. compressed to 117.77 Kb. by saving 22.13 Kb. (15.82%)]
