| TDI Conversions Discussions on converting non TDIs into TDIS. More general items can be answered better in other sections. This is ideal for issues that don't have an overlap and are very special to swaping engines. |
March 9th, 2010, 14:20
#1
VW Golf II TDI
Good evening all!
It's with great pleasure that i'm starting a thread on TDICLUB.
I'm Nelson, aka Nitrox and i'm from the south of Portugal. I'm in vw's for a while now and i'm going to show you here one of my daily drivers.
I've been a reader of this forum for a while, there so much quality information for people like me who is doing a conversion. I hope to learn with you and of course i will share everything i'm doing to my car.
So, it's a Golf II from 1991 that had the 1600 TD.
When i bought it in 2007, it came like this:
The original 80hp wasn´t enough for me, so i started some mods:
Modified inlet manifold
Replaced the original k14 for a k24
Golf 1 Gti thermostat for the engine oil
Fitted a Mercedes Van Intercooler
and oil cooler from Mocal
Engine bay completed with relocated battery
Custom made battery holder
March 9th, 2010, 14:45
#3
March 9th, 2010, 18:41
#6
You are the VW person that I've seen make their own muffler. Keep the pics coming.
BTW I would not use the k-frame from your mk3 in the mk2. It stands a good chance of being bent.
March 12th, 2010, 06:43
#7
Thanks for the advice! I thought exactly the same. So i manage to find another one in decent shape!
I started to stip the engine bay:
And heres the difference between the Golf 2 k-frame vs Golf 3 k-frame:
I also kept the larger Golf 3 sway bar.
Also installed the front Passat cross member in order to have the better Golf 3 Tdi motor mounts.
Everything in place
March 16th, 2010, 15:13
#8
So, with the AFN engine out, time to change gaskets, seals, pulleys in order to avoid future problems!
With 250,000km on the clock, it's unusual to see a head clean like this:
AAZ gasket with new oil pump.
New timing belt, tensors, waterpump, etc.
I have deleted the A/C, so had to change the pulley system.
March 16th, 2010, 20:00
#9
Originally Posted by Nitrox
Is that one of my old pop-off valve plugs?
I love the car. I have definitely given some thought to buying another MK2. I miss my old Jetta TD.
March 16th, 2010, 20:53
#10
Very nice car indeed. I like the wheels. How did you do the larger water-cooled oil cooler along with the sandwich plate for the air-air oil cooler?
'88 Audi 80 quattro, AWX PD, Colt Cams stage II, european spec 01E 6-speed, 240mm solid flywheel, SB clutch, Bosio R783's, Arp studs (maybe), ported and polished big valve head, 4 bar map, GTB2260VK, VWMikel tuned, (in process) Build: http://forums.tdiclub.com/showthread.php?t=234380
'82 Vanagon Westfalia TDI
March 23rd, 2010, 09:33
#11
Location: Blaine, Washington and Vancouver, British Columbia
Nice project!
I miss mine too. I've been considering a MK1 or MK2 with a 1.6 TD sans turbo, and a little nitrous oxide (with a LDA equipped pump). I like the sheer simplicity of the IDI and the linear NA powerband.
March 23rd, 2010, 13:18
#12
Looks good, but you have your timing belt tensioner wound backwards.
March 26th, 2010, 15:09
#13
Hi! nop, this one was made here!
Just Bolted an accessory that came along with the sandwich...
Could you show me which one n the picture please?
Some news.
I installed a GT22 with a 1z exhaust manifold
Now i have to sort a new back engine mount...
March 27th, 2010, 13:44
#14
Keep the info on this one coming.....looks very interesting and should be one fast Mk2 TDI when finished.....well done so far.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
March 27th, 2010, 17:54
#15
Fuel Economy: Depends on what I'm towing!
Looks pretty nice so far! Keep us posted.
2005 Passat BHW Variant w/01E 6 gang
