Old February 27th, 2010, 20:32   #1
mattn_85
TDI(s): MK4 Jetta
Default High mileage pump duse problems
Hello all,
I am an old member of this forum and currently own a 2003 Jetta TDI. I am planning on being in the market for a new car soon and have my eye on a 2006 Jetta TDI with the pump duse engine. The only thing is that it has 209,000 KMs on it.
I am wondering if there are any problems that I should be looking for, or if I should just stay away from it.
Here is the link
http://www.frederictonvw.ca/PreOwned...3-9d07002eb235
I have tried searching but didn't find much on this subject.
Matt
mattn_85 is offline   Reply With Quote
Old February 27th, 2010, 21:03   #2
Ol'Rattler
Ol'Rattler's Avatar
The major problem with these cars is the POS dual mass flywheel and premature cam wear. If it idles smoothly and has good power, most likely the cam is O.K. If the DMF is on it's way out, there will be vibration and noises from the drive-train.
209K is certainly a lot of KMs so chance are the problems I described have already been addressed.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old March 8th, 2011, 09:18   #3
tme2011
tme2011's Avatar
Default Did you purchase?
Did you end up buying the vehicle? I think I am experiencing the camshaft issue @ 190,000 mostly highway miles (305,775 KMs)
http://forums.tdiclub.com/showthread.php?t=310518
tme2011 is offline   Reply With Quote
Old March 8th, 2011, 17:50   #4
tdisedanman
I lost my faith in these engines. Between a relative and us, we had 4 PD vehicles. We now have zero. My wifes 05 passat had to have a remanufatured engine installed at about 49000 (warranty than god) but, it did some funky thinks after that. Brother in laws A5 had electrical problems and cam probles. Can replaced under extended warranty at about 60000 miles. I lost my faith in VW diesel product. Sorry, I know that this statement won't be popular here. Loved the A5, it was comfortable, handled well. The DSG trans on mine was great and serviced as called for. But, like I said, the PD engine scares the crap outta me.
2005.5 jetta TDI - gone
2005 Passat TDI - gone
2011 E350 bluetec - present
tdisedanman is offline   Reply With Quote
Old July 7th, 2011, 04:34   #5
madhun
Mine (2006 2.0 Tdi Golf) has 220k's on it and short of minor servicing issues have never had a problem with it. Had a suspected DSG issue that turned out to be a plug on the injector loom.
madhun is offline   Reply With Quote
Old July 7th, 2011, 05:14   #6
digorius
TDI(s): 2004 Jetta
I have an 04 PD with 328000 kms on it. I replaced the DMF setup with a V6 SMF at around 250000. I have had the cam checked a couple of times and all seems well. I have used a zinc additive since around 180000 kms to help. I have had a few probs with the car but overall it has been a good car.
2004 Jetta TDI, coolerectomy, Kerma Tune, VR-6 clutch with SMF
digorius is offline   Reply With Quote
Old July 7th, 2011, 08:20   #7
Henrick
What Zinc additive are you refering to? ZDDPlus maybe? How much did you use of that additive?
Henrick is offline   Reply With Quote
Old July 8th, 2011, 12:55   #8
kfcoltn
Fuel Economy: 43-45 MPG
I have 233,000 miles on my 06 Jetta, no major problems, needs DMF, but havent done it yet, just live with the occasional stter at hwy speeds. Just chage the oil early not late and use the right oil (505 01 or better.
kfcoltn is offline   Reply With Quote
Old July 12th, 2011, 05:02   #9
digorius
TDI(s): 2004 Jetta
Henrick,
I used ZDDPlus for quite awhile, one of those small bottles at each oil change. I think I am using Redline now. I have the bottle at home. It changed the last oil change because the guy that does my oil changes doesn't carry ZDDPlus anymore.
Page generated in 0.13383 seconds with 9 queries
[Output: 85.06 Kb. compressed to 72.20 Kb. by saving 12.86 Kb. (15.12%)]
