Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old February 18th, 2010, 14:41   #1
jimbobb2
TDI(s): 2010 Jetta
Default Fuel tank size?????
I see a lot of people posting 16+ gallon fill ups in the late model Jettas. My book says the tank holds 14.5 gallons. How are you getting another gallon and a half or more than full in the tank? I know you vent it and the filler neck is worth some, but surely not that much. Maybe I dont have enough guts to run it down that low?
jimbobb2 is offline   Reply With Quote
Old February 18th, 2010, 14:45   #2
shizzler
Fuel Economy: Solid 50, daily life.
search function is your friend.
But since I'm already typing here, yes, the filler neck IS that large. Somewhere between 1.5 and 2 gallons, if you've done the ventectomy. Very handy having that much more fuel on board.
'03 ALH Jetta: For Sale
shizzler is offline   Reply With Quote
Old February 18th, 2010, 15:01   #3
RiceEater
Fuel Economy: 53 mpg @ 70 mph
Do you think maybe that it is a gasoline tank used for diesel? Maybe it is not the filler neck so much as the provisions for evaporative emission controls?
RiceEater
RiceEater is offline   Reply With Quote
Old February 18th, 2010, 15:11   #4
JSWTDI09
JSWTDI09's Avatar
New TDIs do not have a vent, therefore a ventectomy is no longer an option. I'm not certain exactly what year this change occured, but I do know that on 2009+ cars you cannot do a ventectomy. The most fuel I've ever put into my '09 is 14.1 gallone (US) and I would have filled up sooner if I found a station selling diesel fuel sooner.
JSWTDI09 is offline   Reply With Quote
Old February 18th, 2010, 15:42   #5
lovemybug
The 99.6-2005 Jetta and Golf, as well as the 98-2006 New Beetle, use the A4 chassis, and those did use the same fuel tank as the gas models used. On the diesels, the filler neck vent is useless since diesel fuel doesn't expand and vaporise like gasoline does. You can take the guts out of the vent housing, and it helps to use the full volume of the tank better, which is actually about 17 gallons. The reason it was rated at 14.5 was to allow for expansion of the liquid fuel.
2002 Red New Beetle TDI, Manual swap.
Mods so far: Coolant migration mod, Ventectomy, Euro headlight switch, HID retrofit, KII VCDS cable
I can't believe how much crap I can fit in this thing.
lovemybug is offline   Reply With Quote
Old February 19th, 2010, 13:22   #6
solartempest
solartempest's Avatar
Originally Posted by Plus 3 Golfer
So, I'd say one would be lucky to squeeze a few tenth of a gallon over the 14.5 gallons stated capacity by filling up to the brim of the filler neck.
I have put 14.5 gallons (54.8L) into my tank going a few inches down from the top of the filler neck without pushing it at all. Several times, I have easily gone between 14 and 14.5 gallons.
I suspect the tank can hold close to 15 gallons (57L) to the top of the filler neck.
The most I have pushed it was 107 mi (172km) past the low fuel light. I filled 10L and drove another 30km before I filled the entire tank.
2009 Jetta TDI DSG, Scangauge II
photography.solartempest.net
solartempest is offline   Reply With Quote
Old February 19th, 2010, 14:32   #7
MayorDJQ
The '09's have a vent, it's just permanently open. Fuel tanks have to be vented, otherwise you'd be creating a vacuum as you drive along and consume fuel.
MayorDJQ is offline   Reply With Quote
Old February 20th, 2010, 12:59   #8
Qship
Qship's Avatar
TDI(s): 02 Jetta TDI
I have an ALS MKIV. How do I take the "guts" out of the vent tank?
An object in motion tends to stay in motion until it goes off the road.
cuurent cars: 02 Jetta TDI, 97 GTI, 94 Miata. Gone but not forgotten: 81 Dasher Diesel Wagon - slowest car in the 80's, 0-60 in 29 seconds, 78 Rabbit Diesel, 81 Scirocco S
Burn oil in your car and coal in your house.
Qship is offline   Reply With Quote
Old February 20th, 2010, 15:12   #9
MayorDJQ
Looks in the How-To's at the top of the 101 section.
What's an ALS? Do you mean ALH?
Old February 20th, 2010, 19:59   #10
Tom Brown
I love the range of my 01 Golf. If the fuel tank were much larger, they'd have made refulling part of the service interval maintenance. lol!
Tom Brown is offline   Reply With Quote
Old February 22nd, 2010, 16:14   #11
Qship
Qship's Avatar
Yes, ALH (typo). Found the how to, and performed the extraction.
Old February 22nd, 2010, 20:25   #12
lovemybug
You should find it easier to top off your tank now that you have the vent guts taken out.
It will also help for being more consistent on your fill-ups for tracking fuel mileage.
Old July 25th, 2010, 19:23   #13
analogue_nut
Fuel Economy: 38-45 so far (50000 miles 7-8-13)
Default 2010 tdi gas tank
Greetings - my wife and I just bought a '10 TDI Sportwagon, so I'm still learning where all the fuel stops are in around the Wichita, KS area. While running errands at lunch last week I almost ran it down to nothing. My range was shown at 5 miles, when I finally spotted the friendly green diesel sign about 2 blocks away. It took 14.67 gallons to fill it up. Don't want to repeat that any time soon!!!
analogue_nut is offline   Reply With Quote
Page generated in 0.27668 seconds with 9 queries
[Output: 108.10 Kb. compressed to 89.79 Kb. by saving 18.31 Kb. (16.94%)]
