| Events, Gatherings, Clubs Want to meet other TDI members face to face? Going to a VW Event? Why not try and organize meeting some new faces and putting faces to our usernames? This forum is for organizing meetings and events with other TDI Fans. |
February 18th, 2010, 07:03
#1
Feb 20th GTG @Dubwerx
Its official, Dubwerx is hosting our GTG on Feb 20th, at 8:00 to whenever we get kicked out.
Dubwerks is being extremely gracious allowing us to use their space and associated tools and equipment (and heat!).
Start at 8am, CinciTDI will provide lunch (pizza) around noonish and coolers with water. Bring any additional non alcoholic drinks you want and we will keep them cold.
Small jobs are welcome, especially topside work, we want to get as many people in and done as possible. All work is done with your hands and guru assistance as necessary. This is not drop off your car for service day
Bigger jobs will need both Dubwerx approval and guru approval if you require assistance.
If you require parts you must bring them or work can not be performed.
2002 Golf TDI -- RocketChip Stage2 / Sprint 520 / VR6 Clutch / Koni Reds / DG race pipe / EGR Delete -- member of the CinciTDI Club --
February 18th, 2010, 07:04
#2
Job List
As always bring your own parts and your own hands and don't dig into something unless you know you can do it or have someone committed to helping!
rexhart - an overboost CEL, timing belt and a door replacement
OhioCoalRoller - overboost CEL, intake cleaning
Doogie - Shocks and Struts, glow plug replacement
reynolcj - fuel filter, trans fluid, intercooler check/cleaning, key programming, frozen window, washer fluid pump
Growler - install Doniol Boost/EGT Gage
pfiermka - needs SKC
Nash_TDI - adjusting turbo actuator, overboost, 11mm pump swap
05passat??? - oil change, stuck window, hubcaps?
Steven Wallace - dieselgeek skid plate, euro hitch
Andy Schroder - VAG scan for anti-lock, needs SKC
cojones - window switch
MCR - brake bleeding
Racking and stacking of the bigger jobs, in order of request, guru committed in ()s
Fully depends on guru commitment, time and room in the garage
1) Doogie - shocks and struts (Eric)
2) rexhart - timing belt
3) OhioCoalRoller - intake cleaning
4) reynolcj - intercooler check/cleaning
5) Nash_TDI - 11mm pump (paramedick)
6) Steven Wallace - skid plate, euro hitch
7) psst1997 - PS rack and pump swap, suspension work
February 18th, 2010, 08:07
#3
I'm not sure I can make it, but I am really interested in bleeding my brakes, especially if someone has a power bleeder.
Matthew
2003 Golf
February 18th, 2010, 08:56
#4
We can drop intercooler check/cleaning, key programming from my requests unless its super slow and no one shows up  I'm happy just to be there lol.
February 18th, 2010, 11:26
#5
Eric will be helping doogie while I concentrate on the IP. I'll probably grab Growler if he gets free.
TDI Repair Services available. PM or E Mail me. No greasecars, please.
An all TDI Family!!
February 18th, 2010, 12:36
#6
Fuel Economy: 63.25mpg max
My brother and I are fairly competent in all of the small stuff including the suspension when we aren't looking at my car.
Kerma Tune, PP502s, VNT1749vb, 11mm pump, PD150 intake, PD150 TIP, R32 airbox, R32 MAF, R32 Snorkle, Eurojet SMIC, Street Density dogbone, PD lift pump, 3 bar map, PP 2.5" turbo back, Koni Yellows, Neuspeed race springs, Neuspeed rear strut bar, GLX lights w/ fogs, OEM GLI Body Kit, 42DD double gauge pods, Wolfsburg interior, Stewart Warner boost gauge, mfa sport cluster, full audio, and many others.
Best tank 1000 miles, 15.8 gallons, 63 mpg.
Worst tank ? miles, ? gallons, 29 mpg.
February 18th, 2010, 13:53
#7
THought we were starting at 8amishy. thats when I plan to be there.
See everyone on Saturday.
--Aaron--
-Need TDI Service?-Check My Availability Calendar ,Info and feedback Thread.
"Matrix" 2001 Golf GL TDI. RC3f,Sprint 520s,11mm,DONIOL boost/egt,Sachs VR6 & 1Z SMF,TT SS,DG Green Racepipe,OMI,IDParts Boost Pipes,Dynaflow CCV, SavageDiesel 2.25"v1.0 DP,Whitbread 2.5" SS catback,VR6 Springs,FSD,Picklecaps,steel plate with MOGolf Mod.
moda, My 2003 EuroVan GLS VR6, The family Truckster.
February 18th, 2010, 13:56
#8
ack, thats what I get for cutting and pasting.. its 8am, don't worry I will be there
February 19th, 2010, 06:34
#9
I have been planning on going all along with my brother Nash_TDI but just now realized there is something that could be done on my car...
Any interest and/or time to do a PS rack and pump swap? Also have new tie rods, ends, ball joints and control arm bushings I would/could install at the same time. Dubwerx have a press?
February 19th, 2010, 11:43
#10
psst1997 I think we will be limited by time and physical space, we are hoping to use one side of the garage for the smaller jobs and the other side for the bigger jobs. Hopefully the bigger jobs will go smoothly and quickly but you never know.
February 19th, 2010, 13:04
#11
I completely understand. Thanks for adding me to the list, I can only hope it works out in my favor but no worries if not. This is all stuff that I can do on my own but a lift and such would make things a lot easier. Not to mention the need for a press for the CA bushings.
See you guys in the morning!
February 19th, 2010, 17:12
#12
You guys are awesome! I have all the parts I need for the struts/shock swap and am ready to go. I will be more than happy to drop some coin in the hat for lunch, extra drinks, whatever. See you first thing! Doogie
February 20th, 2010, 03:11
#13
heading out. See y'all in awhile.
An all TDI Family!!
February 20th, 2010, 17:23
#14
Good times. Lots of familiar faces. Solid work done on multiple cars.
Thanks to Dubwerx for hosting and their hospitality. Thanks to all that let us play with their cars.
Bruce and Eric
An all TDI Family!!
February 20th, 2010, 18:31
#15
Had a really good time meeting old faces and new ones. Lots of people and lots of work that got done.
Thanks to everyone that made it!
