Anyone ever figure out why the different gaskets are the way they are?
Looks to my eye that the water ports are the only difference, and they've got similar area, just in different spots. The PDs run a tenth of a millimeter closer piston/head clearance; 0.51mm compared to 0.41mm, no idea why. Also from the information up there it's made up of similar thickness layers rather than the three different thickness layers of the ALH gasket (thick flat plate, very thin shim for which "hole number" it is, and two spring shims for sealing)
Makes me think the PD's got some better sealing properties going on, figuring they're all the same stamping stacked up 4 to the one hole, 5 to the two hole, 6 to the three hole, so the belleville washer made by the creases around the cylinders are all nested and therefore adding their spring rate together.
Got an ALH going together with 1.14mm protrusion, and that makes a PD 3 hole gasket perfect for the ALH figure of piston/head clearance. I'm thinking I'll go with the PD gasket this time, unless someone says that's a bad idea.
