| VW MKV-A5 Golf/Jettas Discussions area for A5/MkV Jetta/Golf (2005/2006 PD and 2009 CR). |
February 13th, 2010, 04:30
#1
Ecm Failure
Engine fault light came on for no apparent reason. Went to dealer and diagnosis was ecm was overheating causing light , new ecm on order and awaiting vehicle return to me. Any other vehicles out there experience this? Did not find any on site search or a google search.
February 13th, 2010, 06:45
#2
Fuel Economy: A5: 35mpg Avg / B4: 41mpg Avg
That just seems odd! If they are replacing it under warranty, you may want to let them go ahead and do it. If it's on your dime, I would get a guru opinion; they can scan it with VCDS and see for yourself.
Tony
Diesel fleet: 2006 Jetta, TDI, DSG, 35MPG avg; 2006 DC Cummins, CC/LB/DRW, Jake, 15.5MPG avg, 47kmiles; 1996 Passat TDI, 5sp, Project car! 204k miles, Avg 42mpg / best 48.9mpg, Troubleshooting Links: Whitedog's No Start Trusted TDI Mechanics A4 Limp Mode IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
February 13th, 2010, 14:03
#3
Rolex & gin
I'll second that advice. I'd be interested in seeing what the code that is stored is.
- Don
'97 Jetta TDI - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TD I Sedan - Blue Graphite / Black Pleather, DSG, Sunroof, LED Tails - RNS-510, Prem Bluetooth.
VAG-COM available (Chicagoland)
dzcad90@mchsi.com
February 13th, 2010, 15:15
#4
dzcad, I like that avatar!
Tony
February 14th, 2010, 15:12
#5
Under warranty ,their cost not mine. Still waiting on parts , snow seems to have delayed many deliveries. Long story but had to take my truck out of storage because of VW breakdown , ended up trading truck for new 2010 Mega Cab Dodge with Cummins Diesel. Could I tell Volkswagen if truck had stayed in storage I wouldn't have traded it so the new trucks cost should be covered under warranty
February 14th, 2010, 15:40
#6
Nice try...I'm sure others HAVE tried!
Tony
