Old February 11th, 2010, 14:23   #1
fruitcakesa
Fuel Economy: 40's
Default Torque Converter replacement
After a day of deliberation, I decided to take a moderate repair track and will install another TC and ring gear unit in my car.
Any consensus as to new or used?
Does anyone have one for sale to fit my 02?
PM if you do.
Thanks.
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old February 11th, 2010, 14:25   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Just gotta R&R the trans, pretty straightforward job. Pinch off the coolant lines to the ATF cooler and you won't lose much coolant.
Be sure to only use the same converter you took out, they are letter coded.
They are not cheap new.
oilhammer
www.cardocautomotive.com
Old February 11th, 2010, 15:13   #3
fruitcakesa
Fuel Economy: 40's
OH: Thanks for the heads up.
Where is the letter located. I assume the pan must be off to see it?
Old February 11th, 2010, 15:17   #4
fruitcakesa
Fuel Economy: 40's
Would the vin# identify the letter?
Old February 12th, 2010, 13:41   #5
oilhammer
oilhammer's Avatar
It is on the converter, but the dealer should be able to decipher from the VIN. I think all the diesels will use the same one.
oilhammer
Old February 12th, 2010, 13:45   #6
02tdivw
TDI(s): 02 Golf Tdi
Fuel Economy: 4.2-6.5 L/ 100km
PM if you do.
Thanks.
I have 02 golf , removing soon. let me know
02tdivw is offline   Reply With Quote
Old February 12th, 2010, 14:39   #7
fruitcakesa
Fuel Economy: 40's
Dealer wants big $ for new and aftermarket is also pricey.
With 125k on the trans would a good used unit of comparable mileage be the more cost effective course?
How often does a TC fail in these cars?
Mine still functions but the ring gear is NFG so go figure.
What do you think.
I plan to keep the car and get a 5 speed swap when a donor is available.
Old February 12th, 2010, 17:33   #8
csstevej
Check with Ken, here's the link FS: Torque converter
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old February 13th, 2010, 17:07   #9
fruitcakesa
Fuel Economy: 40's
What can fail in a torque convertor?
Old February 14th, 2010, 20:43   #10
oilhammer
oilhammer's Avatar
The internal clutch seal can bleed over, causing the lockup function to not work. The stator can become warped from heat and get out of balance and self destruct and send schrapnel throughout the transmission, the bushing can wear out and cause the convertor to chatter, they can get out of balance and cause a vibration, they can get a worn spot in the sealing surface and leak ATF.....
oilhammer
Old February 15th, 2010, 02:18   #11
steelmb
You are such a ray of sunshine. LOL
steelmb is offline   Reply With Quote
Old February 15th, 2010, 04:46   #12
oilhammer
oilhammer's Avatar
He asked. That was a generic list of possible failures, not VAG/Sachs specific.
FWIW, I have seen very few TC failures in these cars, and in the OP's case it was the ring gear that is tooefed.
oilhammer
Old February 15th, 2010, 10:23   #13
jollyGreenGiant
jollyGreenGiant's Avatar
I've got a good one if you want it...
jollyGreenGiant is offline   Reply With Quote
Old February 15th, 2010, 15:38   #14
ninedee_golf_tdi
I can't remember if the ring gear is serviceable on the 01m or not. Anyone know ?
ninedee_golf_tdi is offline   Reply With Quote
Old February 15th, 2010, 17:37   #15
fruitcakesa
Fuel Economy: 40's
It is welded to the TC
Page generated in 0.16704 seconds with 9 queries
[Output: 123.73 Kb. compressed to 102.44 Kb. by saving 21.29 Kb. (17.21%)]
