Old February 11th, 2010, 03:25   #1
forgeman
Question Afn Shudder under load
Hi,
I have a 1998 audi a4 tdi 110hp afn.
the main issue i have is in 3rd, 4th and 5th gear if i accelerate from about 1200rpm then the engine shakes quite violently until the around 2500rpm.
Heres what i have done so far:
full service including fuel filter.
all vacuum lines changed
timing checked with vag com
maf unplugged went striaght to limp mode.
accuator moves freely.
also to add to the fun there is no fault codes being shown.
so there we go
any help would be great
cheers colin
forgeman is offline   Reply With Quote
Old February 15th, 2010, 07:53   #2
forgeman
no ideas?
i had another read of the codes and 00575 pressure control difference came up?
any thing else i should check?
cheers colin
Old February 15th, 2010, 08:54   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
motor mounts, clutch/flywheel maybe?
BobnOH is online now   Reply With Quote
Old February 15th, 2010, 10:54   #4
forgeman
thats a good idea ill check the mounts on my next day off.
how could i go about checking the clutch and DMF ?
cheers colin
Old February 15th, 2010, 20:25   #5
steelmb
Originally Posted by forgeman
Hi,
so there we go
cheers colin
Is accelerating from 1200 rpm in the higher gears a normal practice for you? I would also think engine mount or clutch.
steelmb is offline   Reply With Quote
Old February 16th, 2010, 02:08   #6
forgeman
some times not hard acceleration just a small change of speed.
but it happens when accelerating any where in between 1200-2500rpm so i could accelerate from 2000rm and still the problem persists.
i will check the engine mounts on my next day off. but how would i go about checking the clutch?
also i understand i should replace the dmf while im in there?
cheers colin
Page generated in 0.15433 seconds with 9 queries
[Output: 68.10 Kb. compressed to 59.28 Kb. by saving 8.82 Kb. (12.95%)]
