Old February 6th, 2010, 14:02   #1
Blockman
TDI(s): A3
Default Wiper Switch Bypass?
My wiper switch is non functional and the wipers run continuously. I do not have time to change the wiper stalk switch and need a quick fix until i have more time. Can i place a fuse tap in the existing fuse location and add a simple toggle switch as a short term fix.
Blockman is offline   Reply With Quote
Old February 6th, 2010, 14:50   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
It looks like pulling fuse #5 (15 ampere) will shut off all power to the wipers. A pair of fuse taps on a burned out fuse (to hold the taps in place) in position #5, and the taps then leading to a good in-line fuse and in-line switch should work indefinitely.
Svante Arrhenius 1896
Old February 6th, 2010, 15:57   #3
G60ING
G60ING's Avatar
Next time I'm at my storage unit I will see if I have any mk3 wiper switches. If so its yours for the cost of shipping.
I would guess the total time for replacing the stalk is 15-20 minutes.
Yank the air bag...5mm allen wrench
pull the steering wheel....24mm socket
pull off the steering column trim (not certain may a couple screws and you may have to pull the knee bar cover)
Then its just 3 screws for the switch and a plug.
Being in my ultra busy season at work I can understand not having 20 minutes but the 20 minutes is probably also required for the fuse/switch trick.
Just yank the fuse until you get time to repair it correctly
G60ING is online now   Reply With Quote
Old February 6th, 2010, 18:53   #4
Blockman
TDI(s): A3
I appreciate the offer for the switch ...will gladly pay shipping costs. The real surprise is that this is a 20 min job. I read an old thread and it took 2 hours for this process ? Either way i will patch with a inline tap until i get a proper switch to replace.
Thanks again for the willingness to share your parts and knowledge.
Old February 7th, 2010, 05:00   #5
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
G60ing is wrong. It is actually a four hour job (including beer drinking, Chips & BSing) and don't you be tellin my wife anything different . Rookies .
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Page generated in 0.13360 seconds with 9 queries
[Output: 65.34 Kb. compressed to 57.47 Kb. by saving 7.88 Kb. (12.05%)]
