Old January 13th, 2010, 16:48   #1
Jibeho
TDI(s): 2015 Golf
Default ABS 00668 with a twist
2000 NB
Driving home today I got the 3 beeps flashing brake light and steady ABS. Scan says ABS 00668 Supply voltage term 30 16-10 outside spec, Intermittent.
Here is the twist. While driving and at idle it seems like something is pulling very hard on the alternator. You can feel it driving an see it under the hood. Is this something other than a bad connection?
2000 TDI NB, SMOG .205, B99 254k miles(Dead)
2006 MINI Cooper S 17% JCW CAI, One Ball
2009 Jetta TDI (Sold to VW)
2015 TDI Golf S DSG
2016 Mercedes C300 4matic
Jibeho is offline   Reply With Quote
Old January 13th, 2010, 18:02   #2
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Check fuse box on top of battery . Make sure is not start burning and melting fuses.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old January 13th, 2010, 18:41   #3
Jibeho
TDI(s): 2015 Golf
I'll give it a good lookover tomorrow evening. I was also getting a battery light on and off for the last few miles.
2015 TDI Golf S DSG
Page generated in 0.14729 seconds with 9 queries
[Output: 54.99 Kb. compressed to 49.61 Kb. by saving 5.38 Kb. (9.79%)]
