Old January 4th, 2010, 20:12   #1
madsen22
TDI(s): 05 jetta
Default car wont go over 60 or rev over 3k rpm
im new to the site.. my wife owns an '05 jetta tdi. but shes having problems with it.. its spudring at 1800-2300 rpm. not letting me go over 60 mph. not blowing black smoke or any smoke for that matter. but it used to. talked with her cousin which has an '03 jetta tdi said it might be the fuel filter. told us to hop on here and see what other people say. any ideas on what it could be?
madsen22 is offline   Reply With Quote
Old January 4th, 2010, 20:18   #2
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Could very well be. When was it last changed?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old January 4th, 2010, 20:19   #3
madsen22
TDI(s): 05 jetta
heh never been.
Old January 4th, 2010, 20:20   #4
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Yeah...there's a 20K mile interval on that.
Old January 4th, 2010, 20:30   #5
madsen22
TDI(s): 05 jetta
she didnt maintain her car much before she met me.. hardly ever changed her oil... and ill just stop there lol
Old January 4th, 2010, 20:42   #6
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
You might have thousands of dollars in damage for the lack of maintenance when it comes to oil (being a PD TDI). What oil was she using, and how often was it changed?
I would contact TurbineWhine in Asheville and setup a time for an appointment to have the car looked over...
Old January 4th, 2010, 20:47   #7
madsen22
TDI(s): 05 jetta
dealer stuff... she had her cuz grab it for her when she added or had the dealership change it
Old January 4th, 2010, 20:47   #8
madsen22
TDI(s): 05 jetta
not too sure on wat the weight is thou.
Old January 4th, 2010, 21:01   #9
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Dealers can't always be trusted to use the correct oil. There are specific grade and specification requirements for TDIs, especially the PD type.
Hopefully she was changing the oil not more than every 10K miles.
Old January 4th, 2010, 22:46   #10
TornadoRed
TornadoRed's Avatar
If she was just a girlfriend, then you could walk away. But since the car belongs to your wife, you are now in charge of maintaining it.
You came to the right place. Maybe the problem is with the fuel filter... but I doubt it. It could be the engine is not getting enough fuel, or not enough air. You need to start from the beginning, replacing any and all filters that should have been replaced long ago. and the same with fluids. For anything more complicated than you can handle yourself, contact someone on the "recommended mechanics" list (sticky thread at the top of TDI 101).
'03 Golf with 698k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old January 5th, 2010, 05:01   #11
PDJetta
PDJetta's Avatar
(Ex) wife #2 was like that, but that is not why we divorced (she had the Tiger Woods syndrome). I can definitely identify with you.
I also bet that VW 505.01 oil was never used after the factory fill in this car. The '05 TDI MUST use this spec oil or most likely the camshaft and lifters will fail and this is a $3000 plus repair, unless you do it yourself or find the rare person on this list that can and will do it for less.
If you love her, you will read upon this list on how to properly maintain this car and do it.
You (or someone knowledgeable) needs to completely go through this neglected car and perform all required maintenance. If you do not know if a maintenance item has been done, just do it.
How many miles are on the car?
I would venture to say your original posting issue is the fuel filter is plugged. Replace it ASAP! and if not, I would suspect the in-tank lift pump (failure).
--Nate
Old January 5th, 2010, 06:43   #12
TornadoRed
TornadoRed's Avatar
Originally Posted by PDJetta
I also bet that VW 505.01 oil was never used after the factory fill in this car. The '05 TDI MUST use this spec oil or most likely the camshaft and lifters will fail and this is a $3000 plus repair...
Hold on -- that was the argument back in 2004 and 2005, but now we know better. The cam and lifters will either fail or they won't, and it does not seem to matter whether the VW-spec oil was used or not.
There are too many PD TDI owners using API-rated synthetic oils, with good results, to let this bogus 505.01 warming pass without comment. We've had these PD engines in North America since the 2004 model year, and folks have been running unauthorized oils nearly that long. TDI Club member GMARK was the first to run a controlled test of Mobil Delvac 5w40 in a PD engine, his story is here >>> http://forums.tdiclub.com/showthread.php?t=174007
To the OP: check out the "TDT mafia" thread -- for some reason, PD TDI owners who've switched to Mobil 1 Turbo Diesel Truck 5w40 have decided to form their own group. TDT is not identical to Mobil Delvac 5w40, but still pretty close.
Old January 5th, 2010, 06:52   #13
Ski in NC
Fuel Economy: 48-52 typical
Madsen- Regarding the flat engine over 3000.. Definitely change the fuel filter first. Could also be MAF (mass air flow meter). But change the fuel filter first.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old January 5th, 2010, 06:55   #14
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Are our public school systems that bad? Why can so many people not read the manual? This is like the 11th clogged fuel filter thread in the last couple months.... sheesh....
oilhammer
www.cardocautomotive.com
Old January 5th, 2010, 08:48   #15
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
As OH said, start with the fuel filter.
Go get a vagcom on it and run some logs. Check for a bad MAF.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Page generated in 0.16390 seconds with 9 queries
[Output: 125.43 Kb. compressed to 103.97 Kb. by saving 21.46 Kb. (17.11%)]
