Old January 2nd, 2010, 13:07   #1
lmrjlr
Fuel Economy: 55 MPG
Default Rough Idle
After replacing the seals on my injection pump I am experiencing a rough idle. The car runs fine during normal driving speed. I first I suspected dirt in the lines or injectors so I added some injector cleaner to the tank but it did not help the situation.
Has anyone had any experience with changing out the Engine Speed Sensor? Could this be the problem? Or do I need to clean the Inector?
lmrjlr is offline   Reply With Quote
Old January 2nd, 2010, 16:28   #2
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
The crank position sensor rarely fails. When it does, the engine won't start.
Which car are you referring to?
What is your IQ set at? i.e. Injection Quantity?
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old January 2nd, 2010, 20:49   #3
lmrjlr
this is on my 2000 bug . how would I know the IQ?
Old January 2nd, 2010, 22:48   #4
rackaracka
Need more information... Did You change the seals or did You have a trusted mechanic do the work? Did they or do You have a VCDS to read the IQ (Injection Quantity) and then re-set the proper values with mechanical adjustments to the head? Was the IP removed fro the car?
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old January 3rd, 2010, 11:24   #5
lmrjlr
[FONT='Verdana','sans-serif']I changed the seals out myself. I did not remove the Injection Pump form the car. I did the seals on my 98 without any problems so I thought I would not on this one. Looks like the same pump to me. No I do not have a VCDS. I did it according to the instructions on the sight.[/FONT]
Old January 3rd, 2010, 12:20   #6
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Originally Posted by lmrjlr
[FONT='Verdana','sans-serif']I changed the seals out myself. I did not remove the Injection Pump form the car. I did the seals on my 98 without any problems so I thought I would not on this one. Looks like the same pump to me. No I do not have a VCDS. I did it according to the instructions on the sight.[/font]
This is common problem when you do pump seals with out VCDS and taking IQ volume before replacing seals. Most likely you have low IQ and you need to adjust it. Only way to that is with VCDS (VAG-COM).
I bet you in cold morning is getting worst, then when engine get hot it get little better.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old January 3rd, 2010, 12:46   #7
Dodoma
Why would you need to adjust IQ volume when the pump was not distrubed?. Moreover, Imrjlr did the same procedure before without problem. See if replacing the filter helps. Also, if my understanding is right, the ecu determines IQ volume based on other parameters.
Dodoma is offline   Reply With Quote
Old January 3rd, 2010, 13:59   #8
TonyJetta
Read the FIRST post:
He needs to check the IQ and adjust via hammer mod.
Tony
Old January 3rd, 2010, 14:30   #9
jetta ,97
jetta ,97's Avatar
Because he did upper seal and when you move that even if you make mark on pump you will have to adjust IQ.
Movement is in micro mm, so you can't see with eye. That why you need take IQ volume before you replacing seals to know how much you need put back when you replace seals.
I did a few ,and newer have been able to put it back same way that it was. I had to adjust with VCDS, or hammer mod.
HEX+CAN
Old April 11th, 2010, 13:02   #10
lmrjlr
Just to let everyone know I did get the rough Idle fixed with the Hammer and wood block method. I did it with the engine running. I do not own a VAGCOM and I am sure it is not perfect but it is 90% improved. Before this my idle speed was around 1100 and rough. now it is around 750 to 800 - and smooth idle. Who would have believed that a ball pein hammer and a 4x4 wood block could fix my problem. Thanks again.
Old April 11th, 2010, 14:58   #11
TonyJetta
That RPM is a little low. Spec is 903.
Tony
Old April 11th, 2010, 15:42   #12
egibbys
egibbys's Avatar
Fuel Economy: High 51.5
Perhaps he is guessing about where it is since he doesn't have VAGCOM. Although I was unaware that the hammer mod messed with the idle speed. I have done this to my car and my idle was unaffected.
My idle used to sit at 903 rpms and then drop to 840 after sitting for 10 seconds. This made my idle very rough and not tolerable. I used VAGCOM and raised the idle to around 990rpms. Don't know if this is recommended but it helped smooth out the idle a bit. It also got my IQ to stay in one place. When the rpm drops the IQ bounces a lot. So lets say its at 4.0, it would bounce from 3.8 - 4.6. Just all over the place. Now it tends to vary only by 0.2. My IQ is currently at 5.0.
I've been told that the fuel quantity adjuster is warn out inside the pump. Does that sound right? I was told that the only way to fix the problem was to get a new pump.
1999.5 JETTA TDI - SOLD
egibbys is offline   Reply With Quote
Old April 11th, 2010, 15:57   #13
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
The mod does not affect the idle, but fuel will.
The pump may wear, but you can adjust it doing the mod. There should be no need to replace the pump unless you can no longer get it to stay in spec.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old April 11th, 2010, 16:15   #14
egibbys
egibbys's Avatar
Are you refering to the timing? Cause its pretty close to "within spec". It bounces in and out of the area on the graph. Its just a little low. The mechanic says he can't get it any closer.
Page generated in 0.14818 seconds with 9 queries
[Output: 119.33 Kb. compressed to 99.48 Kb. by saving 19.85 Kb. (16.63%)]
