Old January 1st, 2010, 17:47   #1
fleuger99
Default Low Beam Headlight Bulb?
I could not find the low beam headlight bulb info in the owners manual. Does anyone either know where to find this info for all our 2010 JSW TDI bulbs or specifically know bulb type for the low beam headlight? ie. H7 or 9006?
Thanks!
2012 Touareg TDI Lux| Tow Package
Past - 2010 Graphite Blue TDI JSW
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
fleuger99 is offline   Reply With Quote
Old January 2nd, 2010, 06:35   #2
aenea
TDI(s): 2010 JSW
H7. The high beams are H15.
aenea is offline   Reply With Quote
Old January 2nd, 2010, 12:14   #3
fleuger99
Thanks for the response, found it on the Vortex
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
Old January 2nd, 2010, 13:11   #4
Car901
Car901's Avatar
Default light bubs
fleuger - what are you upgrading to?
Previous & current oil burners
1980 Audi 5000S Diesel - long gone
1992 F-250 7.3 IDI - traded for:
1999 F-250 7.3 Powerstroke - my War Wagon
2010 JSW 6-spd - my new S.E. Expressway stealth weapon
Car901 is offline   Reply With Quote
Old January 2nd, 2010, 14:54   #5
2010GWTDI
I just put in a set of Philips X-Treme H7 HIR bulbs. Wow, what a difference over the stock Halogens. I did a ton of research and HIR is as close as you can get to the brightness and lighting pattern of true HID lights. They were not too expensive, $52.99 on eBay, but the change at night is incredible. I had HID's in my GTI and was really worried about going back to stock halogens. These bulbs wiped away my concerns completely.
2010GWTDI is offline   Reply With Quote
Old January 2nd, 2010, 16:53   #6
fleuger99
Hey,
How is sunny FL?
I wanted something brighter than the OEM lights. My last 4 cars have had HID's and I miss the great lighting. I've used several yellow bulbs from Hoen in the past for fogs but their HID "like" bulbs are 70W and 80W which I'm scared will fry the 50W OEM connectors.
Someone I know suggested these and despite being pricy he said have excellent lighting and are 55W. So, I might give these a try.
http://www.piaa.com/Bulbs/Bulbs-H7.html
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
Old January 3rd, 2010, 08:49   #7
danham
TDI(s): 2010 JSW
I thought the OEMs were 55 watts? Also, I ran some of those PIAAs in my Audi A4 and no way were they putting out "110 watts of light for 55 watts." I used to have true 100-watters in my Ford camper van (!) and so I know what 100 watts looks like as the paint begins to bubble on the trunk of the car in front of me [g].
The PIAAs were adequate, but appear to overdrive the filaments, giving more light but for a shorter lifespan. Not worth it IMHO.
-dan
2010 Jetta TDI SportWagen, black/black, stick, pano roof, Porto 17" wheels, iPod, protection & luggage Legos, nuvi 760 GPS, V1 radar, DRLs disabled, iPhone "GasBook" app as fuel finder.
Previous rides: '06 Audi A3 2.0T (traded for JSW); '98 Audi A4 1.8TQ chipped; '92 Corrado VR6; '90 Corrado G-60; '87 GTI 16v; '83 GTI; '77 Diesel Rabbit; '71 Porsche 914-4; '67 Volvo 122S; '66 Porsche 912.
danham is offline   Reply With Quote
Old January 3rd, 2010, 11:39   #8
fleuger99
-dan
Dan,
You are correct, they are 55W, my error. Thanks for the heads up on the PIAA bulbs. Hmmm, now I have to think what to do next
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
Old January 3rd, 2010, 11:49   #9
danham
TDI(s): 2010 JSW
Originally Posted by fleuger99
Dan,
On the F800 forum, lots of folks have tried various bulb swaps and most have been unhappy with the results (or toasted their wiring or the bulb housing). So the consensus there is go for a full HID conversion or live with the OEM lights.
My plan is to wait for fogs on the JSW, as they do a decent job of filling the gaps in the halogen low beams, which is what I need most as my eyes get older.
-dan
Old January 3rd, 2010, 11:52   #10
Car901
Car901's Avatar
Hey,
How is sunny FL?
.....I've used several yellow bulbs from Hoen in the past for fogs but their HID "like" bulbs are 70W and 80W which I'm scared will fry the 50W OEM connectors.
Sunny - No. Warm - No. Looking forward to getting back home, but not the drive. When I put the Silverstars in the war wagon, I fried both sockets in short order. Ended up with a custom harness w/ 12ga. wiring and relays to drive the bulbs...OEM wiring at the socket seemed to be 18 - 20ga w/ severe voltage drop.
The harness came from here: www.suvlights.com
Old February 10th, 2010, 06:16   #11
Ram.Vasu
Dan,
fleuger99,
What did you end up doing... Did you go with PIAA?
Thanks in advance.
Ram.Vasu is offline   Reply With Quote
Old February 11th, 2010, 17:23   #12
fleuger99
Originally Posted by Ram.Vasu
fleuger99,
Thanks in advance.
Ram.Vasu I ended up doing nothing yet. Instead I had a 3M Clear Bra installed to take my mind off the head lights
I have higher priority things, like H&R Sport Springs and next month buying Pirelli rubber for my Karthoums and having it all installed. Then I'll revisit head light replacement bulbs....that is unless the VW Fogs are available then it will be fogs and Hoen Yellow bulbs for those.
Did you do anything with your head lights?
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
Old February 13th, 2010, 11:08   #13
Ram.Vasu
fleuger99,
Well - just ordered a pair of Philips X-Treme Power H7 from Powerbulbsdirect in EBAY store - they are shipped from UK, they are only $ 35.10 including shipping. Have not received them yet - will let you know how it goes.
BTW - which part of the MA you are in.. and I am in Lexington/ Burlington area.
Old February 13th, 2010, 11:29   #14
danham
TDI(s): 2010 JSW
Those look good and get good reviews, but with the caveat that bulb life is shorter because the filaments are "overdriven" to achieve the higher output. As with so many things automotive, there's no free lunch.
-dan
Old February 13th, 2010, 11:57   #15
fleuger99
fleuger99,
Let me know how those bulbs work for you once you have them installed. I live in Norfolk MA (Not too far from the Wrenthum Outlets). I was messaging Car901 and we were talking about getting together next month for a beer. Anyone else interested we should have a mini JSW TDI/Golf TDI GTG. We could see where everyone is coming from and meet somewhere at the mid-way point for the majority.
2008 R32 MKV
2006 Jetta GLI
1998 Passat V6
Page generated in 0.15542 seconds with 10 queries
[Output: 126.04 Kb. compressed to 104.61 Kb. by saving 21.43 Kb. (17.00%)]
