OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs |
January 17th, 2010, 20:53
#16
Jason, I would stay on them to get that sorted out. It's not a 'cheap' venture after the software and dependent on what hardware you pick up. I'm curious to hear about their customer service...the other curious thing is if others are having the same issue...theoretically, if it's a bug it should be affecting more than you, if not everyone, right? Keep us posted!
January 20th, 2010, 13:38
#17
I am currently working wit Jay Jones from Devtoaster and gaining some ground.
I will keep this thread updated with progress.
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
January 21st, 2010, 17:59
#18
UPDATE;
Nothing to update, still no response from Devtoaster, I have enabled the GATHER INFO function and automatically emails the service dept., but no response as of yet.
January 26th, 2010, 13:19
#19
UPDATE:
Do not purchase this product for a MKIV, the support guy is a idiot and I know the product better than he does.
Can't figure out what I'm sending him, have to send him an email 3-4 times on the same topic before he understands.
Over all not impressed with the product or service, so much for OUT OF A JOB YET,KEEP BUYING FOREIGN stickers, you've all seen em.
February 24th, 2010, 12:09
#20
What scanner to buy
Requirement 1: Read codes (and reset the intermittent P0722 / G38 speed sensor problem code I have in wet weather).
Requirement 2: Provide mpg readout (other nifty gauges would be a plus).
Option 1: VAG-COM; $250 + a windows computer I don't have. Too expensive for now.
Option 2: iPhone (which I have) + DashCommand http://www.palmerperformance.com/pro...hone/index.php ; $29.99 + Kiwi WiFi Module; $149.99 = $179.98 total.
Possible, but I don't know how well it will read or clear VW specific codes. Does anyone know of less expensive OBD/WiFi modules?
Option 3: ScanGauge II, $159.99.
Only $20 less than Option 2
Option 4: Kiwi MPG, http://www.plxkiwi.com/kiwimpg/buynow.html; $89.99
Looks like the same features as ScanGauge II, but $70 less. What's the catch?
Any other suggestions or options?
No mods yet.
March 2nd, 2010, 03:31
#21
Short update: Anyone have any experience with the Kiwi WiFi module? Anyone have any good experience with cheaper OBD-WiFi modules?
No mods yet.
March 7th, 2010, 12:12
#22
Thats what this thread is all about is the REV DEVToatser, they just call KiwiWiFi.
Not worth it in my opinion.
Fuel level -Not supported
EGT-not supported
Fuel Consumption- inversley proportioned and doesn't read properly
Several; other PID's not supported as well, just can't remember what ones since I don't use it that much.
June 25th, 2010, 06:44
#23
http://www.devtoaster.com/products/rev/
Kiwi Wifi (US Made) doesn't support a lot of the codes. OBDkey and ElmCanII-WLAN support many more but are more expensive. Haven't got one yet, but my employer's supposed to have profit sharing in August (first time in a couple of years) and I might buy an OBDkey and REV then.
No mods yet.
June 25th, 2010, 08:44
#24
it doesn't look like ElmCanII-WLAN is made anymore, at least you can't get it from the site linked to from the Dev site.
What I'd like to see is software that suports the cheaper bluetooth dongles, unless there is less throughput with bluetooth, then I guess I'd just like cheaper Wifi module.
June 27th, 2010, 12:13
#25
EGT will only be supported if the ECU can read it. The Passat 2.0l TDI has an EGT guage, so on that car you can read it. On most OEM's there is no EGT guage, so there is nothing to read. OBDII supports EGT but if the sensor is not there, you obviously cannot read it.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
June 28th, 2010, 12:25
#26
Agreed for older mkiv, but of all the sensors on a 2010, one of them has be able to spit out EGT to a gauge. Heck by that thought, I should be able to monitor my differential pressure across my DPF to see when it'll do a regen.
I think what we'd all want to see is an iphone/andrioid app of vagcom. I'd gladdly plunk down the $350 or whatever for that level of support for my car.
July 1st, 2010, 04:03
#27
Bluetooth
Not Rev's fault. It's the hardware/software engineers at Apple who only built a subset of the different bluetooth protocols into the iPhone.
No mods yet.
July 10th, 2010, 17:48
#28
It's software. Their Bluetooth hardware stack is fairly robust. They just figured that their customers would never, say, send pictures over Bluetooth. Like every free phone for the past few years. So they only have a very tiny subset of the Bluetooth stack programmed. And if you're an App Store app, your options are to make your own "Made for iPhone" (you pay more) adapter, or use their Bluetooth stack (which will obviously not work since they don't have a Bluetooth serial port in their stack). If you were an app on Cydia, you could write the missing part of the stack (not hard if you know what you're communicating with), inject it when your app loads, and support Bluetooth OBD scanners.
So yes, blame Apple. But blame the front-end people. The engineers designing their hardware have nothing to do with the marketing people that tell the programmers what to code and what not to code.
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
July 12th, 2010, 18:02
#29
Because we want to make it completely platform independent so it will work on iPhone, Android, or whatever the next hot mobile device might be, it's will not be app per se. It's also still quite a ways from being a shipping product, but we are working on it:
-Uwe-
__________________________________________________ ___
VCDS®: Satisfaction guaranteed or double your fault codes back!
July 12th, 2010, 19:09
#30
Torque Addict
Fuel Economy: low: 35 high: 56 avg: 42.0
-Uwe-
Whoa! Most exciting post in a very long time! Consider me one to upgrade my VCDS to "mobile" then!!! As soon as this is released I'll get it, I'm sure you'll have a compelling upgrade price structure for current "cable" owners :-) My iPhone is always on a mount charging by the radio. I'd love to log without lugging the laptop around!
