Old December 22nd, 2009, 07:23   #1
BrentRN
BrentRN's Avatar
Default ESP button: What does it do?
I found in my owners manual a description of the Electronic Stability Program but there is nothing in the control section on the ESP button. If I push it will the car use its ESP to predict that I will be in an accident tomorrow?
The manual describes the ASR button where my wagon has a button marked ESP. Are they the same thing? Should the button be pushed or left alone when it's slippery?
Former TDI owner
BrentRN is offline   Reply With Quote
Old December 22nd, 2009, 08:15   #2
owr084
Leave it alone. It is always on. Pressing the button will disable it and a light will appear on the dash to indicate it is off. It will turn itself back on the next time you restart the car. Here's a video of what it does: http://multivu.prnewswire.com/mnr/vw/32207/
Skip the marketing drone and fast forward to the 1:18 mark to watch the demonstration.
<-- just for you Aja8888. Someday maybe you'll get a widescreen monitor or just put up with the fact that sometimes, the information conveyed is more important than resizing the photo.
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old December 22nd, 2009, 08:16   #3
engineerorange
engineerorange's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 39/41/44
It will disable the Electronic Stability Program. Only handy if for some reason you NEED to spin the tires.......
2006 Jetta TDI, PKG 1, DSG Campanella White with beige
Ask me about my aircooleds
engineerorange is offline   Reply With Quote
Old December 22nd, 2009, 08:18   #4
abctdi
abctdi's Avatar
Pushing it removes the function IIRC. If you find ESP preventing your progress due to ice, pressing the button will allow the tires to spin without all the automatic anti-spin control engaging.
I have never had to press it, but we only get snow a few times a year here.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old December 22nd, 2009, 09:14   #5
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
When you press the button 3 times and wink, it resizes the grapics you put on this thread that are way too large making it difficult for everyone to read.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is online now   Reply With Quote
Old December 22nd, 2009, 09:57   #6
aja8888
aja8888's Avatar
I have an IBM Thinkpad. It is a big as I could get (15.5"). Sorry. Most folks here don't have 24" widescreen monitors. Maybe the BMW forum guys all do?
Thanks for the info. I Have ESP (edit).
Old December 22nd, 2009, 10:09   #7
BrentRN
BrentRN's Avatar
It looks like ESP is for stability while going through curves or in lane changes. Is there a disadvantage to having it on or off when driving straight in slippery conditions such as snow covered or icy roads?
Former TDI owner
Old December 22nd, 2009, 10:24   #8
abctdi
abctdi's Avatar
I once pulled into a freshly snowed upon parking lot and tried to spin the car to no avail...no fun at all, but very safe indeed.
Old December 22nd, 2009, 11:15   #9
owr084
It is very helpful when dealing with puddles in your lane. The ESP helps to keep your car going straight right through without allowing the front tires to be "grabbed" by the puddle.
aja8888 - Your Passat must be an oddball because according to my 2005 Passat brochure, ESP, ASR, and EDL were all standard for the GLS. But, the brochure is wrong in some cases, like not mentioning the availability of cloth seats. I suspect yours was one of the first batches off the line after the end of the 2004 MY.
RBB
Old December 22nd, 2009, 11:19   #10
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
It's very helpful when changing lanes and having to cut through the little globs of built-up snow between the lanes... Keep it on all the time except when you're trying to creep up a snowy hill... the ESP will eventually put the brakes on both sides of the car if it gets confused enough...
Yuri
ymz is online now   Reply With Quote
Old December 22nd, 2009, 11:25   #11
aja8888
aja8888's Avatar
EDIT: I have ESP, I am wrong...
Just researched specs on the 2005 Passat TDI and ESP was an option, not a standard feature. So not all of them may have them, unless Edmunds is wrong..
Old December 22nd, 2009, 11:28   #12
WeLikeBlue
My 2004 GLS has cloth seats also. Sure, the leather would have looked better, but here, parked outside at work during the day, I've come to appreciate the cloth after my shift.
And back on topic... It might be just me, but I could swear that turning the ESP off in normal, dry pavement conditions causes my transmission to shift more smoothly. I don't make a habit of turning the ESP off, but you know what happens when you tell some people, "Here's a button, but DON'T push it!"
My *former* DD: "Fritz" - 2004.5 Passat TDI GLS sedan, graphite blue, totally stock, sold 2/7/2016 http://forums.tdiclub.com/showthread.php?t=454256
WeLikeBlue is offline   Reply With Quote
Old December 22nd, 2009, 11:57   #13
ScottW
On ice it seems you would not want your tires to spin...so why not just keep it on all the time?
At what point is it preferable to turn it off? Racing from a stop?
Just don't see my wagon...racing! LOL
2005 Passat TDI Wagon GLS 17" wheels. Recall completed:glow plug's/ECM reflashed, chainless 10-14-09
ScottW is offline   Reply With Quote
Old December 22nd, 2009, 12:32   #14
abctdi
abctdi's Avatar
On ice, some have been ESP'd to the point where nothing happens and no forward progress can be made at all. At that point, no ESP is the best thing, for a few seconds...
Old December 22nd, 2009, 12:38   #15
engineerorange
TDI(s): 2006 Jetta
Our 2005 B5 does not have ESP, it only has ASR. It has a negative option on the window sticker that says something like "without ESP".
Of course it's also painted a color that wasn't available in 2005, go figure. I am thinking it was pushed back in a corner rework area or something over the summer holiday in Germany and got lost until production started back up on the 2005's.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.16243 seconds with 9 queries
[Output: 129.82 Kb. compressed to 107.45 Kb. by saving 22.37 Kb. (17.23%)]
