Old December 21st, 2009, 21:38   #1
nemesis500548
TDI(s): 02 Jetta
Fuel Economy: 45 - 50
Default Dead battery, remote key fob, door lock trouble not working
It took me a while to find the surprisingly simple answer to this aggrivating problem, so I'm reposting the info with lots of keywords so hopefully it will be easier for the next guy to find. Maybe even have someone list it in a FAQ or something.
Anyway, the battery died on my car a few days ago and after getting it going again I noticed that the remote/key fob would unlock the drivers door and trunk, but no matter how many times I hit the unlock button it wouldn't unlock the rest. I tried the key pairing deal thing in the owners manual and still no go. So after a few hours of searching this and other websites I found the simple and retarded answer.
Hit the lock/unlock button on the passenger door.
I have no idea how it works or why. I can't even begin to understand how or why. It baffles the mind. If this was intentional programming, who the hell thought of it. I mean really, battery goes dead, so the remote will only unlock the driver door. And to fix this you hit the lock/unlock button on the passenger door. Are you kidding me? Who the hell thinks this s**t up! And how did the first guy figure it out?
nemesis500548 is offline   Reply With Quote
Old December 22nd, 2009, 07:11   #2
Powder Hound
Powder Hound's Avatar
Nice repost. At first I thought it might be an admission that shaving door handles wasn't such a hot idea after all.
Old January 4th, 2010, 10:19   #3
btrumper
Thank you so much for posting this information. I encountered the exact same situation as you describe and until I found your post, I had been completely baffled as to how to remedy it. I did as you said and the problem completely disappeared. This place is great!
Thanks again.
btrumper is offline   Reply With Quote
Old January 4th, 2010, 12:20   #4
XXX_er
TDI(s): 2002 golf
Fuel Economy: 55mpg highway
OR eventualy the remote lock/unlock will just start working properly all by itself
XXX_er is offline   Reply With Quote
Old January 9th, 2010, 15:43   #5
ik0n
ik0n's Avatar
GREAT POST!
Took my car in and had the windows tinted today.
The guy told me that the battery had gone low (guess it went dead) because they leave the car on to use the controls.
I couldn't figure out, what was wrong; so I just told myself: "The TDI club will have an answer for me when I get home".
Sure enough, one quick search and I found my answer/fix!
Cheers!
2004 Jetta Wagon TDI (Spice Red)
Spark Plug Free Since: November '09!
ik0n is offline   Reply With Quote
Old February 18th, 2010, 11:23   #6
copatdir6
copatdir6's Avatar
Fuel Economy: 52+ MPG!
Thumbs up
Thank you so much. I had my battery not die completely, but after sitting in the cold overnight, it started VERY rough and at one point the dash lights all came on (indicating a dead/dying battery). It did turn over (thankfully) but for the past 2 days the passenger and other doors would not unlock just as you described.
I am in class right now, but will try your "method" of fixing the issue and let everyone know if it resolves it.
Again, thanks for the post.
2003 Bora TDI - SBC Stage 2 Daily Clutch, RC Stage 2, CAT Fuel Filter, Ventectomy, EGR Cooler Delete, JL Stealthbox, Diesel Geek Skid Plate, Best Mileage to date: 52.86mpg
"Remember, if the women don't find ya handsome...they should at least find ya handy!" -Red Green-
copatdir6 is offline   Reply With Quote
Old February 19th, 2010, 11:38   #7
copatdir6
copatdir6's Avatar
Talking
Hey, just to let everyone know....this worked like a charm. Just as stated. Thanks again!!!
Old February 27th, 2010, 13:43   #8
DieselFiend1.9
DieselFiend1.9's Avatar
Fuel Economy: 36 Avg
thanks for the tip!!! I tried your fix on my 2003 Jetta TDI and it was a GREAT SUCCESS!!!
Like ik0n, my batt died at the window tinting place and the doorlocks were malfunctioning ever since. Apparently a dead/dying battery will cause this and hitting the passenger door lock control is the only way to remind the controller that other doors exist besides just the driver's door!!
THANKS AGAIN!
DieselFiend1.9 is offline   Reply With Quote
Old August 8th, 2012, 12:05   #9
cspeter8
if this works it is very useful knowledge!
more keywords for finding this thread:
Double unlock on FOB doesnt unlock all doors
cant unlock the doors with Fob (Drivers door is ok)
Another confirmation - a 2005 Jetta TDI Sportwagon - this WORKS!!!
2004 Passat TDI tan sedan, ~200,000 miles chainless/ westfalia hitch, manual trans swap.
2001 Jetta TDI blue sedan, ~225,000 miles - ~sold
2005 Jetta TDI blue wagon
~sold
(Greasecar kits on all)
cspeter8 is offline   Reply With Quote
Old September 24th, 2012, 12:30   #10
Wickers
Hey, bit of a lurker on here but you lot have got me out of the mire on more than one occasion - I now have this problem, but can't fix it with the suggestion, either that or I'm doing it wrong. My passenger door has no "unlock" button the same as the drivers door does - do you mean the button that sits proud of the door? The one that gets depressed vertically? I've tried that and ot makes no difference. To be fair, I think the battery is pretty much on its last legs so will this fix only work once the battery is replaced? Thanks for your time.
Wickers is offline   Reply With Quote
Old August 23rd, 2016, 19:49   #11
ZipiTDi
ZipiTDi's Avatar
This did not work for my B5.5.
New battery installed in January.
Door lock problems began about a month ago (July), first with the passenger door left side. Key fob wouldn't lock or unlock it. Unlock switch on driver's door sometimes worked, but stopped working a week later. Have to manually open door using the interior handle.
Then a week and half ago, the right side rear passenger door started doing the same thing. Only manually opening it from the interior handle works to open it now too.
Today, the front passenger door failed to unlock.
Trunk lid and driver's door lock/unlock works fine with key fob and interior switch. What a pain in the neck.
Took it to my indy shop. Owner/mechanic was totally stumped. Said he'd never seen this happen, and all he works on are VWs and Audis (going on 32 years now). He got the front passenger door to unlock using the lock/unlock switch on that door, and key fob worked on both front doors again. No charge.
I just checked the car door locks again (5 hours later) and key fob was not locking/unlocking the front passenger door again. Reached over to use the lock switch and it worked to open only the front doors. So frustrating!
8 years of dealing with all the expensive maintenance and repairs on my '05 Passat TDi wagon and my '04 Jetta TDi sedan, and then all the fraudulent crap, etc., VW did pulled on the newer TDis, have soured my desire to ever own another VW. I'll be selling them both very soon. Going back to Subaru.
Save
Save
ZipiTDi is offline   Reply With Quote
Old January 9th, 2017, 10:16   #12
Cdmac
TDI(s): Leon fr mk1
Default Solution hasn't worked for me.
Hi guys. Long time lurker, first time poster.
I got a new remote fob just back in April for my Seat Leon FR TDI. It's worked fine since getting it 9 months ago. However I noticed today that it now only unlocks the drivers door. It doesn't unlock the other doors, including car boot/trunk. The solution suggested of unlocking the passenger side door manually isn't an option with my car. Now, the day before I noticed this problem my car battery died and I had to get a jump start off my wife's car. That was 2 days ago. My SEAT has been running fine since the jump start but it does seem the key fob/remote locking issue began same time that car battery died. Incidentally once I unlock the doors manually (using the central locking button on the drivers side door) the fob/remote will lock them all the doors when I exit the vehicle, so the problem is remotely unlocking doors, other than the drivers one. Is this likely a side effect of my car vattwry dying? Any suggestions appreciated. Cheers
Cdmac is offline   Reply With Quote
Old February 4th, 2018, 17:33   #13
TDI_FNG
TDI(s): 2004 Jetta
OMFG, thank you, thank you, thank you.
Last month I ran out of fuel and ran the battery down trying to prime the system, fortunately I don't have to crack the lines at the injectors. The AAA guy was in total disbelief. Shortly after I started to notice that a double tap wouldn't unlock all the doors (I seldom have passengers).
I have to agreed with the OP, what kind of 'tard thinks this is a good "feature" to program into the system?
TDI_FNG is offline   Reply With Quote
Page generated in 0.16076 seconds with 9 queries
[Output: 113.45 Kb. compressed to 95.03 Kb. by saving 18.42 Kb. (16.24%)]
