ninedee_golf_tdi
Maybe I'll finish this up tonight...after 7 months ?
It isn't "hard" and I found if you just move some stuff out of the way you can do it easily.
I have to run the car up on some ramps so my floor jack can get underneath it, so if needed, do that first.
Disconnect the battery
While up top, unbolt the two clamps holding the a/c line. You're eventually going to drop the compressor out the bottom and removing these two clamps gives the line some slack
You can remove the hose bracket to gain access to the a/c line clamp nut by depressing the keeper on the bracket and just sliding it off. The nut is then very visible.
Remove the top screw on the right side fan (you'll get the other two later)
Remove the upper boost hose (you'll need the room to maneuver your arm)
Not shown, jack up the car and put it on jack stands. Remove the lower engine cover and right side skirt. Decompress the serpentine belt tensioner and remove the belt.
From the top, move the fuel hoses out of the way, (no need to disconnect them) then remove the serpentine belt tensioner (allows access to the upper alternator bolt)
Remove the upper alternator bolt
From underneath:
I opened the clamp holding the radiator hose and pushed the hose aside
Unplug the electric harness from the a/c compressor
From underneath:
