Old July 4th, 2006, 20:45   #46
whitedog
TDI Scholar
Fuel Economy: 42 Jetta, 47 Beetle
Default How about the PD engine.
I have looked over this list and have looked at the stuff at Ross-Tech and I still have questions. This list is very good and helpful for many things, but I'm still a bit confused on some things especailly with thee PD engine. There are measuring blocks with a description (like 23 on the PD engine) that says something, but what is it really about? What does it tell us?
There are others, and at this time I won't bore you with all of my questions, so I will ask, where can I find more info on what each of these blocks mean? The definition is fine, but sometimes it doesn't tell me enough (see block 23 on the PD engine).
How can I figure out what they mean to the operation of the engine?
Old August 13th, 2006, 12:05   #47
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
I am finding some discrepancies w/my ECU 038 906 012 CP and the Group list at the head of this post. I have no Group 21 (too bad, it looks like a good grouping of values), I do have a Group 24 (temps), etc. I'm editing my label file to accomodate my findings. I feel for Ross-Tech trying to make a solid product in a liquescent environment.
'01 Jetta GLS, 5 sp, Black on Black, Leather, Moon Roof, MFSW, Monsoon, Heated Seats, a work in progress
FlyTDI Guy is online now   Reply With Quote
Old October 7th, 2008, 18:12   #48
whitedog
TDI Scholar
Default Group 16
Group 016 (additional heater)
Generator loading
Additional heater
Activation of heater elements
Voltage supply from ECM
Additional heater display is 8 digit number where, left to right, 1 =
nothing
nothing
ECT sensor inoperative
engine started within the last 10 seconds
engine speed below 870 rpm
battery voltage below 9 volts
generator inoperative
ECT exceeds 70 C-80C (158F - 176F), or intake air temp exceeds 5C (41F)
Activation of heater elements is a 2 digit number. Left digit = 1 when high heat output relay is on. Right digit = 1 when low heat output relay is on.
OK, so I had a flashing battery light tonight. I checked this group and first I had something like 20-some% loading and 14.3X supply voltage.
I had no flashing light at this time.
I shut off the engine then checked voltage: 13.2V. I then restarted engine and still no flashing battery light, but now I was at 99.X% loading and 12.1V.
I'm thinking grounds or regulator. What think you?
Old November 22nd, 2008, 14:47   #49
crosscr
TDI(s): 2000 Beetle
Originally Posted by Sebastian
Ok, here we go...
http://www.ross-tech.com/vag-com/dow...iles/03-01.lbl
http://www.ross-tech.com/vag-com/dow...06-016-BEW.lbl
This file covers the following ECU's:
038-906-016-AG
038-906-016-H
038-906-016-Q
The file has been created from scratch to be used as template for future EDC16 files and does not contain the data of the old 038-906-016-H.LBL, if I find some more time, it will be completed with some more info about the other blocks.
Any hints/suggestions?
Does anyone have anything for a 038-906-16-AB
crosscr is offline   Reply With Quote
Old May 5th, 2009, 18:09   #50
A_Shifter
A_Shifter's Avatar
So I realize the thread's dormant...nevertheless, this looks like the best one in which to post my query.
Can someone explain the procedure for testing groups 008 and 011 (3000rpm in 3rd at WOT etc)?
2003 Jetta TDI Wagon
, VNT-17, Titan PP520s, 3 Bar MAP, Racepipe, EGR Cooler Delete, PP 2.5" DP>304 SS custom 3" cat-back, Peloquin Diff, .681 5th, VW DC Stage III+ Clutch, Boxed Fork, Sigma 5 Shifter, Bilsteins, Rear Sway, Boost/Pyro/Oil Pressure/Oil Temp/ScanGauge, Cross-drilled rotors, Panzer Plate.
A_Shifter is offline   Reply With Quote
Old May 5th, 2009, 18:13   #51
whitedog
TDI Scholar
Why are you wanting group 8? are you sure that you don't want group 1?
Old May 5th, 2009, 20:30   #52
A_Shifter
A_Shifter's Avatar
I believe I need 1,2,5,8 & 11. I'm gathering info for an Alligator Tune.
Old May 8th, 2009, 20:12   #53
A_Shifter
A_Shifter's Avatar
So...No?
Old September 1st, 2009, 14:13   #54
zeaustar
TDI(s): golf mk4 tdi
So...No?
you want to do this on a rolling road or get someone on the computer while you drive.
go to measuring blocks and click where it says log. drive the car up to a long straight stretch of road, get to third gear and when you are at about 2500 rpm click the button where it says 'start'. now you want to floor the pedal (WOT= wide open throttle) and hold it there until you get to 3500 rpm then click 'stop' on the computer and then the other button that says, 'done,close'.
find this file using your browser and it will open in microsoft exell.
you will now be able to observe how the values change dependant on the revs
zeaustar is offline   Reply With Quote
Old October 19th, 2009, 08:09   #55
A_Shifter
A_Shifter's Avatar
Default Aligator/VAG-COM file logging Procedure
In case a search brings someone to this thread, here's the VAG-COM file logging procedure from Diesel Inside.
Old October 19th, 2009, 08:43   #56
andreigbs
andreigbs's Avatar
Fuel Economy: 42 avg.
Changed your alternator pulley yet? I did, charging went from 13.6 avg. to 14.2 avg.
2004 Bora PD, RC1+ // 148,xxx miles // 41 MPG
Quote of the month: "Also take fun for drive my car "
andreigbs is offline   Reply With Quote
Old February 16th, 2013, 15:34   #57
Zrnojed
TDI(s): Passat tDI
Originally Posted by plavis View Post
Is this readings OK?
The car is Eu Bora/Jetta ATD PD 100.
EGR duty cycle is always the same 84.5%, except when I press accelerate pedal. When the engine is accelerating duty cycle is lower. When engine accelerates to demanded rpm, it's back to 84.5%
Anybody has an answer to this?
I have the same reading on my Passat 1.9 TDI PD AWX,and i wanna know if that is ok,or not!?
Zrnojed is offline   Reply With Quote
Old February 16th, 2013, 18:52   #58
FlyTDI Guy
FlyTDI Guy's Avatar
I can speak to all but the Inj. Duration... it all looks absolutely normal to me. Your MAF is reading a bit high for the EGR being open, other than that, I don't see any problems. Your choice of groups is limited and not the most interesting or telling when looking for problems. Do you have any?
Old February 19th, 2013, 13:35   #59
Zrnojed
TDI(s): Passat tDI
I do not have problems,but i am interested-why is EGR cycle over edge of 70 %.
I had my neighbours passat on diagnostic,yesterday,and his reading was about 55-60 %.
I am also confused about,what,exactly is EGR duty cycle?
Old February 20th, 2013, 13:14   #60
FlyTDI Guy
FlyTDI Guy's Avatar
I see where your concern is now. I'm primarily experienced w/my ALH and have had my EGR 'neutered' for some time now. The operation of the ALH EGR is mostly digital in that it's either on or off and not much inbetween. Low duty cycle indicates off and high indicates on. Normally at idle, it will start off on and cycle to off after a minute or two. It goes off when accelerating but can come back on when cruising at a steady state. When on, it's recycling exhaust back into your intake tract. On your engine series, the logic may be more analog in that there are various states and degrees it may be on. Why your duty cycle is above the "normal" range may indicate a sticky mechanixm or clogged intake. I would interpret the overly-high duty cycle to mean your ECU is issuing the command to open but flow is not reacting as anticipated and measured by the MAF. The ECU therefore increases duty cycle to attempt to get the feedback it's expecting.
If you don't have "EGR Insufficient Flow" or other EGR related errors, I wouldn't be overly concerned. You may want to check your intake for clogging and verify your EGR is working properly with a Mity-Vac (assuming it's 100% vacuum operated). Also verify you have adequate vacuum (+/-30in/hg on and ALH) with no hose or connection leaks. Another test might be a leakdown test on the EGR actuator, again w/a Mity-Vac.
I've probably already said too much as I'm not an expert with your engine series. You may want to re-post this question in the Passat section and see if you have better luck.
Page generated in 0.15825 seconds with 9 queries
[Output: 129.29 Kb. compressed to 107.97 Kb. by saving 21.32 Kb. (16.49%)]
