Old November 28th, 2005, 15:29   #31
Taggs
Thanks.
Taggs is offline   Reply With Quote
Old December 15th, 2005, 17:00   #32
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation My BEW PD engine has a -Q ECU
Originally Posted by Uwe
If anyone would like this file, it's here:
http://www.ross-tech.com/vag-com/dow...-906-016-H.LBL
(Right click on the link to download it, left clicking will likely just show you the contents in your browser).
At some point we'll probably integrate that into the 03-01 redirection file so it's used by all BEW engines, not just the -H ECUs.
-Uwe-
The ECU in my 05 PD Jetta Wagen (engine code BEW) has a -Q at the end of the part number.
I picked up my 05 PD Wagen back in April '05. I'm not sure when the car was built.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old December 16th, 2005, 07:57   #33
Sebastian
If you have the BEW and a VAG-COM KEY or HEX interface, contact me via email: sebastian@openobd.org
Sebastian
Sebastian is offline   Reply With Quote
Old January 16th, 2006, 06:12   #34
technocrat
Fuel Economy: 45/42/39
Is there a vag-com label file for the BEW 038-916-016-Q engine yet?
technocrat is offline   Reply With Quote
Old January 16th, 2006, 06:49   #35
Sebastian
Since nobody contacted me as requested (above), the answer is pretty much: no.
*edit*
Actually I received files, but due to my own mistake it got lost.
Sebastian
Old January 18th, 2006, 17:17   #36
Sebastian
Ok, here we go...
http://www.ross-tech.com/vag-com/dow...iles/03-01.lbl
http://www.ross-tech.com/vag-com/dow...06-016-BEW.lbl
This file covers the following ECU's:
038-906-016-AG
038-906-016-H
038-906-016-Q
The file has been created from scratch to be used as template for future EDC16 files and does not contain the data of the old 038-906-016-H.LBL, if I find some more time, it will be completed with some more info about the other blocks.
Any hints/suggestions?
Sebastian
Old January 18th, 2006, 17:38   #37
RichS
Fuel Economy: Lifetime Average 42 MPG
I'm sorry that the adaptation file and block listing file for the 038-906-016-Q engine control module that I sent you the last week of December didn't help. I was going to email you and see if there was anything else I could do, but I was waiting because I knew you were in the process of moving.
RichS is offline   Reply With Quote
Old January 18th, 2006, 19:08   #38
Sebastian
Sorry Rich, the file was helpful, but somehow (no clue why) my email folder got damaged and the file was gone. So nevermind my own mistakes/problems, hope this file now helps and as said, there are still gaps, e.g. the other adaptation channels and some more measuring blocks. These things will be filled, not today, but as soon as possible.
Sebastian
Old February 26th, 2006, 15:27   #39
dave333
Ok, here we go...
038-906-016-AG
038-906-016-H
038-906-016-Q
Sebastian,
Thank you very much for your work. I now have labels on my measuring blocks on my BEW motor with the -AG ECU.
I owe ya a cold one next time you are in N. Florida...
dave333 is offline   Reply With Quote
Old March 3rd, 2006, 15:47   #40
jnecr
jnecr's Avatar
Fuel Economy: 40ish?
So I have Prodiag software for my PDA now and none of the blocks are labeled. They have units on most values and that helps condsiderably. But, does anyone know, or can anyone, post the blocks and values for me? They are substantially different than the ALH ECU posted by MoGolf in the first post. I've figured out the most important ones, but there is lots of ones that I don't know.
-John
jnecr is offline   Reply With Quote
Old March 3rd, 2006, 17:12   #41
jnecr
jnecr's Avatar
Nevermind ya'll!!! Dave helped me out and pointed me in the direction of simply looking at the files that Sebastian posted.
-John
Old June 4th, 2006, 04:03   #42
plavis
Fuel Economy: 45 miles per galon
Mogolf, have anything for PD 100 (ATD) European?
plavis is offline   Reply With Quote
Old June 5th, 2006, 10:54   #43
Sebastian
Here you go...
http://ross-tech.com/vag-com/downloa...06-019-100.lbl
Sebastian
Old June 6th, 2006, 01:03   #44
plavis
Thanks. I'll trie it in next few days.
Old June 9th, 2006, 07:04   #45
plavis
Is this readings OK?
The car is Eu Bora/Jetta ATD PD 100.
EGR duty cycle is always the same 84.5%, except when I press accelerate pedal. When the engine is accelerating duty cycle is lower. When engine accelerates to demanded rpm, it's back to 84.5%
Page generated in 0.16851 seconds with 9 queries
[Output: 122.60 Kb. compressed to 101.37 Kb. by saving 21.23 Kb. (17.32%)]
