Old December 2nd, 2009, 19:29   #1
bosshog
Default Rear defrost doesn't work
I drive a 2002 jetta and my rear window defrost does not seem to be working. The indicator light comes on but the window does not defrost. The fuse is ok and the connections on the window are good. I'm guessing its the switch or relay does anybody know where on the panel this relay is located?
bosshog is offline   Reply With Quote
Old December 2nd, 2009, 20:04   #2
Herm TDI
Herm TDI's Avatar
Thank MOGOLF for posting this info
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old December 2nd, 2009, 20:26   #3
bosshog
I thank this entire site for all the things I've learned I seem to have a little trouble searching sometimes but not bad. Well back to the car maybe I got some bad info because I don't see a relay for that defroster on the diagram is it controlled entirely by the timed switch in the dash?
Old December 2nd, 2009, 20:32   #4
Herm TDI
Herm TDI's Avatar
The rear defogger is powered by the load reduction relay through the defogger switch.
What I would recommend is pulling the switch and check continuity.
The switch is most often the weak link in this circut.
HermTDI@Yahoo.com
Old December 2nd, 2009, 20:39   #5
bosshog
Thanks I'll check that switch and go from there.
Old January 24th, 2011, 14:23   #6
Herm TDI
Herm TDI's Avatar
Default rear defog switch
Originally Posted by york77777 View Post
I am having a similar issue. The switch lights up, the fuse is fine. Would the switch light up if it was causing the problem as mentioned above?
Yes.
The "switch light" only indicates that there is power to the switch (fuse is good).
You need to take a meter and check for voltage at the window heat element.
With the switch on, then check for voltage at the window heat element.
No voltage at the window heat element = defective switch.
HermTDI@Yahoo.com
Old January 25th, 2011, 08:38   #7
Herm TDI
Herm TDI's Avatar
Default Switch P/N
Snip....Snip: Do you happen to know the part number for the switch?
The P/N: 1J0-959-621-D-01C {Switch for heated rear window}
This P/N is for the 1999.5 as indicated in your profile.
In the future if you require part # information please provide your full car info. Most perfered is the VIN as this will prevent mistakes and you buying incorrect part/s.
HermTDI@Yahoo.com
Old November 13th, 2012, 15:51   #8
15austin
Sorry to bring back an old thread, buy where or how do I check it the rear defrost at the window? I have a mulitmeter so where do I put the terminals?
2000 Jetta gls TDI 5spd. 245,000miles. Ventectomy. Black/Black
15austin is offline   Reply With Quote
Old November 14th, 2012, 11:59   #9
Herm TDI
Herm TDI's Avatar
Default meter
Place the meter wires at both ends of the window heat element.
Set your meter to 12VDC
HermTDI@Yahoo.com
Old July 3rd, 2016, 23:37   #10
Was a fordie
do u know if theres a part number for a new window defroster element.. looks like a small wire with a grommet. and some broken glass is attached to it yet with what looks like some type of window/mirror glue... I would like to get two that i could easily mount onto the back glass that is on the kit of the project im working on and still have functioning rear defrost.
Was a fordie is offline   Reply With Quote
Old December 30th, 2016, 16:23   #11
Allen03
Default 03 jetta rear defrost not working
Have read down this thread and if I have 12 volts at window connections. Does that mean the heating element in the window is bad? It also has aftermarket tint on it doesn't appear to have been removed.Everything I have checked ahead of the window checks out good has continuity through the switch as well switch is lighting up and know that only means the switch Is getting power but I'm kinda at a loss at this point any help appreciated sorry for bringing back such an old post
Allen03 is offline   Reply With Quote
Old February 3rd, 2018, 20:53   #12
TDIFan1989
Fuel Economy: 58.68 MPG US (best results)
Originally Posted by Herm TDI View Post
Yes.
A warning story for anyone out there looking into this problem, power at the defroster switch (red illumination when the daytime running lights are turned on) doesn't always mean the fuse is 'good'
I had picked up some of these 'Glow when they Blow' fuses from Princess Auto. Didn't think too much to check them at the time. Had the defroster switch prematurely stop operation during a cold night run to the store. Red illumination was still present but the switch was not clicking in to engage. Thought the switch was dead internally somehow. I still had power at the fuse right?
After swapping out the switch with my mechanic, I still saw the same symptoms. At this point I suspected the fuse. Mk4 Jetta lists as Fuse 26. Fuse is one of those 'Blow and Glow' ones I had put in. Testing across the terminals indicated continuity but the fuse portion was clearly showing soot like it had blown.
Tested out other fuses I had around, same deal, the fuse portion would blow but the fuse was still letting trace power past. I reported them to Princess Auto. Word to the wise, check the fuse if you have a specialty type.
TDIFan1989 is offline   Reply With Quote
Page generated in 0.14834 seconds with 9 queries
[Output: 106.37 Kb. compressed to 88.78 Kb. by saving 17.59 Kb. (16.54%)]
