Old November 13th, 2016, 16:59   #16
tristan21
tristan21's Avatar
Same problems (all lights work, including brake lights but both tail lights fail to light up) Any solution?
01' Jetta GLS
tristan21 is offline   Reply With Quote
Old November 14th, 2016, 09:43   #17
wonneber
You didn't mention if the license plate light works.
If you have the manual with wiring diagrams you should trace the power feed backwards to where power is supplied.
W/O the manual you have to trace the wiring harness backward to the front.
If the stop and backup lights work correctly (at the same time) I would think its not a bad ground.
Rich W.
Old November 30th, 2016, 22:46   #18
Aridzonan
TDI(s): 2001 GOLF
I have a similar problem. I started to blow brake light fuses on my 2001 TDI Golf. Whre the Glow Plug light started flashing.. Changed the brake switch.. No change. Still blowing fuses. The cable connectors to the brake lights show no signs of damage and the brake fixtures have zero signs of heat / corrosion damage. Hints for a good place to start?? Thanks..
Aridzonan is offline   Reply With Quote
Old December 1st, 2016, 00:53   #19
UhOh
UhOh's Avatar
Hatch wiring issue. Been there, done that.
http://forums.tdiclub.com/showthread.php?t=281443
Old March 7th, 2018, 05:55   #20
kaneelschep
So did anyone get to fix this?
My rear lights went out too. Including the running lights in tne front. So basicly everything on fuse 22 and 23. Also the dashboard has no light and the green symbol for lights doesnt come on in the dash. Plus no warning buzzer for lights on reminder.
Everything else works like normal.
I measure no power on fuse 22 and 23.
Someone mentioned light switch.
Anyone try that?
And how to check?
Thanks!
kaneelschep is offline   Reply With Quote
Old March 7th, 2018, 10:36   #21
wonneber
What is the car?
Your signature indicates 'currently none'
Old March 8th, 2018, 00:30   #22
kaneelschep
Sorry. Audi b5.5 avant. 2001.
Old March 8th, 2018, 19:09   #23
wonneber
Anyone try that?
And how to check?
Thanks!
Assuming yours is the same as mine:
Both fuses get power from the headlight switch.
Also fuses 3 and 4. Interior light & license plate lights (resp)
To pull the headlight switch out turn it on, push it in, then turn it a bit farther (iIrc)
A bit of wiggling & it should pop out.
Pin 15 on the switch should have power. Not exactly clear but it looks like it gets power at the load reduction relay then to a 110 amp fuse over the battery.
Hope this helps.
Old March 8th, 2018, 19:37   #24
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Anyone try that?
And how to check?
Thanks!
If the dimmer switch on the dash becomes disconnected it does the same symptoms. Check the wiring there.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old March 9th, 2018, 04:38   #25
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
The info in this thread doesn’t help with your car. “A4” in this case is in reference to the Vw mkiv chassis, not the Audi A4. Very different animal!
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old March 10th, 2018, 04:09   #26
UhOh
UhOh's Avatar
Ten-four!
Page generated in 0.14883 seconds with 9 queries
[Output: 101.32 Kb. compressed to 85.59 Kb. by saving 15.72 Kb. (15.52%)]
