Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Upgrades (non TDI Engine related) The place of handling, lighting and other upgrades that do not relate to the performance or economy of the TDI engine. In other words upgrades to your TDI that don't fit into fit into TDI Fuel Economy & TDI Engine Enhancements.Please note the Performance Disclaimer
Old November 21st, 2009, 16:55   #1
VW97JettaTDI
VW97JettaTDI's Avatar
TDI(s): VW97JettaTDI
Fuel Economy: 40+
Default Rear Jetta Calipers Seized?
Basically in sum, my resr calipers piston is stuck pushed out, i pulled the ebrake arm and can expand the piston but can not push it back in. the caluiper is removed from the car and has brake line off as well as the bleeder valve( i thought if i took them off it might decide to return back inside the caliper, lol)
So i was in mid process of painting some used calipers with a coating of VHT paint both front and rear. And to prevent getting any paint on the shaft to rotating emergency brake lever arm i decided to wire tie the emergency brake pull lever depressed as if the brake is being used while i painted the calipers. Then since i got busy with school and work i hadn't been back to my project for four months, i figured it was a good thing since i herd its good to let paint set. But when i went back the other week and attempted to install the callipers, but one of the rear calipers pistons will not depress back into the caliper. I attempted in every way to push it in but it wont, however when i released the brake arm from wire ties and depressed it again i could expand the piston but not compress it. so i not have the piston sticking out with no way of pushing it back in, the other side is almost the same, except its only slightly stuck out, and when i actuate the break. The piston moves out but then moves back when i release it. Yet the piston is stuck a little to far out so i cant fit the pads in with the caliper over the rotor. Any advice? tips or thoughts?
"God Help Us Were In The Hands Of Engineers"
Dr. Ian Malcolm
VW97JettaTDI is offline   Reply With Quote
Old November 21st, 2009, 21:42   #2
Ol'Rattler
Ol'Rattler's Avatar
TDI(s): 2006 Jetta
Probably not seized.................You need a tool to retract the pistons. You have to turn and push the piston at the same time to get it to retract.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old November 22nd, 2009, 08:24   #3
LiLredTDI
LiLredTDI's Avatar
Fuel Economy: ohh...I'd say bout 42mpg
x2 you will NEVER get it back in without the correct tool. dont cheap out and buy the 5 dollar box thing that fits on a ratchet it will drive you INSANE!!! Buy a metelnerd or harbor fright kit to acomplish this task.
2004 Jetta PD-RC5, 17/22,stg.IIcoltcam PD150 Inj.,Rosten Rods, Ported head,Street toys DP, Cat/Muff Delete, R32 airbox/snorkle,PD150 TIP, SB stg 3 ,NSboost/egt gauges, BBS RS II's, Koni FSD/Eibach Kit, M3 side skirts/ rearwindow spoiler,GLI F/R lips FK bumper scoops, GLX headlights/Joey mod, GLI Brushed door/radio Trim, GTI 3-spoke, 2-tone doors, Heated leather seats with beetle doughnuts,rear sunscreen,alum.door sills
LiLredTDI is offline   Reply With Quote
Old November 22nd, 2009, 08:43   #4
Ol'Rattler
Ol'Rattler's Avatar
TDI(s): 2006 Jetta
That $5 cube thing works pretty good, actually. The trick is to remove the disk, bolt the caliper back on and then just lean against the cube with your ratchet and turn..............................
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old November 22nd, 2009, 16:10   #5
Birdman
TDI(s): Jetta 2003
Fuel Economy: don,t know yet?
Most auto parts stores (autozone-advance auto) will loan you the tool to do the job. You pay for it then when you return it they return your money. No need to spend money on a tool you will only use once or twice for most people anyway.
2003 Jetta 216 injectors, race pipe, OMI, 2.5 cat back pipe, Sachs power clutch,Lightweight fly wheel,Rocketchip 3.0,Dieselgeek race pipe,Borla SS exhaust,Dieselgeek Intercooler pipes,Pierburg MAF,EU cluster with LED Boost gauge,,
Ventectomy,Alientech window,Old Navy ccv filter,Catch can,Dieselgeek short shifter,ATE power slot rotors,Porterfield pads,Shine suspension,Shine rear sway bar,TT pedals & foot rest,Cat fuel filter 2 micron,Alum skid plate,Euro headlights and switch,5 Brake light mod.
Birdman is offline   Reply With Quote
Old November 26th, 2009, 09:28   #6
VW97JettaTDI
Fuel Economy: 40+
alright, i guess ill take it into autozone saturday and see what happens, thanks!
Dr. Ian Malcolm
Old November 26th, 2009, 12:39   #7
owr084
Bite your tongue! One should never turn down the chance to buy new tools. Now, if any of you need to replace the clutch plate on a 5 speed tranny from a 1978 Toyota pickup, I have the clutch alignment tool
RBB
2005 VW Passat GLS TDI C&C (Chipped and Chainless), 2007 VW Eos 2.0T, 2002 Mazda MPV ES
owr084 is offline   Reply With Quote
Old November 26th, 2009, 22:56   #8
BustedTDI
BustedTDI's Avatar
Same thing happened to me, I took off both rear calipers and took them into Autozone, where they cranked them back in for me....
BustedTDI is offline   Reply With Quote
Old February 18th, 2010, 12:49   #9
VW97JettaTDI
Fuel Economy: 40+
lol, yeah this happened so long ago, but before this i forgot that some calipers needed to be pressed and twisted at the same time. i picked up the tool which locked into the piston and compressed the pistons. works great.
Dr. Ian Malcolm
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.10085 seconds with 9 queries
[Output: 86.04 Kb. compressed to 72.54 Kb. by saving 13.49 Kb. (15.68%)]
