Old November 18th, 2009, 14:39   #1
Chrono86
TDI(s): 97 Jetta
Default 97 Jetta TDI cranking, but won't start
Hi guys,
I'm new here and barely know anything about cars in general...
The other morning I went to start my Jetta and the engine continually cranked, but won't start. If I hold the key in the start position is will just keep cranking.
While this is happening the oil light is flashing on and off...I checked my oil, it's fine.
Also, while cranking the exhaust spits out white smoke.
Again, I don't know a whole lot about cars, so if somebody could try helping me search for some basic symptoms that would be awesome. I'd really like to avoid paying for this car to be towed
Thanks,
Adam
Chrono86 is offline   Reply With Quote
Old November 18th, 2009, 23:15   #2
Havokk
Havokk's Avatar
TDI(s): 1998 Jetta
Fuel Economy: 46-54, better if i were to clean the garbage out of my passanger seat, must be 60lbs of garbage there. who the hell has time for that crap?
check out this no start thread first and see what you figure out. After let us know what u did if things do not turn out well.
Troubleshoot a car that won't start.
probably a fuel issue. maybe your fuel filter. When was the last time it was changed? check for air in the fuel line (the see through one)
Havokk is offline   Reply With Quote
Page generated in 0.13214 seconds with 9 queries
[Output: 49.01 Kb. compressed to 44.85 Kb. by saving 4.16 Kb. (8.49%)]
