Old November 7th, 2009, 08:38   #1
kruppy
Default Power/Heated Mirrors Don't Work
I bought my 2000 TDI used about 4 years ago, ever since i bought it the power mirrors nor the heat function have ever worked. I have since changed the mirror glass (they were flaking anyway) and they still dont work. I borrowed a friends vagcom and was wondering if there is a way to check for a problem in the circuitry. I found no blown fuses, maybe that one is missing? Does anyone have that reference? Vagcom reference would also be a plus. Thanks
kruppy is offline   Reply With Quote
Old November 7th, 2009, 09:20   #2
DanG144
VCDS Central Convenience #46, example below.
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
Part No: 1J2959802C
Component: 5X Tőrsteuerger. FS0002r
Part No: 1J2959801D
Component: 5X Tőrsteuerger. BF0002B
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Old November 7th, 2009, 10:03   #3
kruppy
Thanks for the response Dan, but I have never used a Vag-Com and need a little explanation with that if you don't mind?
Old November 7th, 2009, 12:48   #4
DanG144
turn the car key on, not start.
hook up your cable.
select (upper left of screen) controller module 46
Once communication is established with the controller (numbers on top fill in), then select "fault codes". It should show the faults in the example if they are bad.
You can reset the faults, if you wish. If they are bad they will come in again when you try to turn on the mirror heaters.
Old November 7th, 2009, 12:50   #5
DanG144
I can look up the fuse # when I get home tonight, if no one looks it up for you before that.
Old November 7th, 2009, 12:51   #6
kruppy
No fault codes, but it says heated mirrors are turned off and power mirrors are not operational?
Now i'm having a tough time figure out how to change heated mirrors to on and what it means by power mirror in operational. I can't seem to find out how to do a login or post describing how.
Old November 7th, 2009, 12:57   #7
DanG144
When the switch is in the middle, between the left and right mirrors, that should turn on the heated mirrors. At least if your car is like mine.
Old November 7th, 2009, 13:00   #8
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
What position is the selector switch in,if it's either L or R position they won't come on.
As for the fuses, here's a handy reference.
It may also be the switch itself.
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).__________________
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old November 7th, 2009, 13:17   #9
kruppy
So by the looks of it, there is no fuse for the power mirrors. I get a POS X- on Mirror Adjustment switch Driver (e43) when i push nob down and when i push to the right when on R (i know same value but that's what it read). Nothing happens when the switch is on L or when its on defrost (vag-com does not say on)
Old November 7th, 2009, 13:26   #10
JASONP
JASONP's Avatar
Remove the selector switch and do a continuity test , sounds like it's the culprit given the mirrors don't work either.
Old November 7th, 2009, 17:37   #11
DanG144
The power comes from fuse S5, fuse #5 on the inside fuse panel - along with a lot of other loads. Or at least control power for the heaters comes from fuse 5. It is very hard to tell for sure, but main power for the left door comes from fuse S37, and this may provide power to the heater elements.
If you have power mirrors the power goes through the mirror switch.
If you do not have power mirrors, the power goes through the rear defogger switch.
Old November 7th, 2009, 17:39   #12
DanG144
I would suspect a broken wire - it seems as likely as a bad switch. So I would check the wiring first, since that does not involve expense for new parts.
Old November 8th, 2009, 16:41   #13
kruppy
Checked for broken wires in the door panel with no luck, took the switch apart and tried to clean up contacts a little bit and also again no luck. I hopped on flee-bay and picked up a switch from Hong Kong for 7.50. We'll give that a chance. If not, i'll be back! Thanks guys for your help!
Old January 23rd, 2010, 04:25   #14
Qship
Qship's Avatar
TDI(s): 02 Jetta TDI
Hi Kruppy - What was the solution to your problem? I have the same symptons on an 02 Jetta.
An object in motion tends to stay in motion until it goes off the road.
cuurent cars: 02 Jetta TDI, 97 GTI, 94 Miata. Gone but not forgotten: 81 Dasher Diesel Wagon - slowest car in the 80's, 0-60 in 29 seconds, 78 Rabbit Diesel, 81 Scirocco S
Burn oil in your car and coal in your house.
Qship is offline   Reply With Quote
Old January 23rd, 2010, 09:52   #15
kruppy
Ended up being the switch. Bought a new one on ebay for like $5 and problems solved!
Page generated in 0.16205 seconds with 9 queries
[Output: 116.54 Kb. compressed to 96.25 Kb. by saving 20.29 Kb. (17.41%)]
