Old October 22nd, 2009, 19:37   #1
draco76
Default To rebuild or replace? 1.9L TDI
I'm going to be buying an 03 TDI beetle that overheated and was told engine bad. I can get a local engine for $1100 but its got like 180k miles on it. Anyone know where I can get a rebuild kit for this engine? I'd rather spend a little extra and get engine rebuilt but I can't find a kit.
draco76 is online now   Reply With Quote
Old October 22nd, 2009, 19:55   #2
yatzee
yatzee's Avatar
Fuel Economy: between 5.2-5.8 l/100
most just swap the engine with a used 1. If you want to splurge, there are a bunch of vendors who will happily sell you a new 1.
The problem with rebuilding *any* overheated engine is that you don't know the extent of the damage. If you're lucky, it's only the head gasket, but it could also be a cracked head or worse.... it's a can of worms!!!
2004 Bora Tdi Sport with a bigger turbo than yours , 91 MB 350SDL that burns oil, surprise, surprise.
My for sale thread: http://forums.tdiclub.com/showthread.php?t=347156
yatzee is offline   Reply With Quote
Old October 22nd, 2009, 20:35   #3
draco76
I know someone who can rebuild the engine for me I just would need a kit with bearings, rings, sleaves etc. I can send the head to a machine shop or just order a rebuilt one. I just don't know a good vw parts site.
Old October 22nd, 2009, 22:04   #4
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
www.tdiparts.com
www.boraparts.com
www.metalmanparts.com
www.worldimpex.com
www.1stvwparts.com
...among others which are escaping me at the moment. User Franko6 is also an excellent resource and can get you any engine parts you need. Send the head to him and he will go through it or exchange it for one of his rebuilt heads. His work is top-notch, prices are very fair, advice is free and he knows what he is doing. Every head that leaves his shop is perfect. Don't go the "local machine shop" route, too much to go wrong with inexperience. I went that route and paid the price. Frank fixed me up right though and my car runs great. No website, but payment is easy via Paypal or by sending him a cashier's check.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
Fax or Ph: 417-232-4634
But personally, I would jump on that used engine. Throw in a cam and set of lifters (very reasonable) and a new timing belt kit and that engine will be ready to go for another 200k miles or more.
ALH TB Tool Rental Trusted TDI Mechanics
2000 NB 3 pedal mod RC3 PP520's Eurojet SMIC SBC 3 2.5" side exit straight pipe2" lift
TDICADDGUY is offline   Reply With Quote
Old October 23rd, 2009, 07:04   #5
draco76
Thanks whats he charge for the head job, or exchange. I guess I can just ask him
Old October 23rd, 2009, 07:58   #6
TDICADDGUY
TDICADDGUY's Avatar
I think for the head alone it is in the $700 range, but you would have to contact him for current pricing. He's just a phone call away.
You will find no cheaper place for rebuild or reassembly parts, Frank is the man and has everything you need.
Old October 23rd, 2009, 10:27   #7
jettawreck
jettawreck's Avatar
I just sent a head to him yesterday. I bought a project car w/TB broken, so there is some head "damage". Mine is going to run more than $700, but from all accounts it will be like new.
Head bebuilt, complete install parts/gaskets, new nozzles installed/balanced, TB kit: estimate $1400. Great guy.
If the history on that used engine is known, thats the way to go, for that $$. IMHO
2004 Cadillac SLS (wife's)
Old October 23rd, 2009, 10:41   #8
BobnOH
Fuel Economy: 50/45/35
before you rebuild you should assess the damage to the engine. This will require time and money, but will save you time and money in the long run. There is no rebuild kit that will cover everything
Old October 23rd, 2009, 11:14   #9
Franko6
If I ever buy a salvage yard engine, the first thing I do is ask for the return policy. "No Refunds" means "NO DEAL!". Then I take the head off and inspect. If the cylinder walls don't look good, I return it and save the time installing a bad engine. 180k is not particularly junk, but a lot of bad can happen in those miles.
Pulling the engine is a bear... not much time is lost doing some inspection. There are two reasonable approaches. Like I said, pull the head and look at the cylinder walls. If they are good, check the #1 rod and main bearings. The bolts on the rods and mains are not reusable (torque to yield), but if there is no overheating of the bearings, the only problem you have is a blown head gasket. Fix the head. It takes a rather severe situation for these blocks to be damaged in an overheat situation.
The average 'overheated' head is usually less expensive to rebuild because you usually don't have bad valves. As long as the cam journals are good, it's very straighforward.
I have comprehensive rebuild kits, which I can tailor to your needs. I have every nut, bolt, screw and washer, timing belt kits, pistons, rings, blocks, oil pans... a one-stop shop.
That includes matching bent rods for weight and length, balancing rotating mass, long-block and short block assembly and machining services. And of course, cylinder head work.
I also handle injector service. Flow-rating nozzles in matched sets makes improved performance.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is online now   Reply With Quote
Old February 27th, 2011, 17:17   #10
HugoStiglitz
TDI(s): 1998 mk3
does anyone sell a overhaul kit?? i have a 97 tdi runs fine but i wanted to ovehaul it while the getting is good/ it has almost 400k
HugoStiglitz is offline   Reply With Quote
Old February 27th, 2011, 17:44   #11
AndyBees
AndyBees's Avatar
Fuel Economy: life time average above 50 MPG
autohausaz.com is a good place to shop!
Kit? Well, just sit down, make a list of what you want to replace! Then order those parts!
2000 Jetta TDI, 50+ overall average (no tune)
300k mile mark on 12/28/11
427 fill-ups, in Excel spreadsheet, 323k miles...
'84 Vanagon ALH TDI engine (32 mpg), Polaris Diesel ATV, Allegro Bay RV 5.9 cummins
VWs 40 years, VW diesels 33 years, ALH TDIs 11 years
Page generated in 0.15455 seconds with 9 queries
[Output: 104.06 Kb. compressed to 87.76 Kb. by saving 16.30 Kb. (15.67%)]
