Old October 11th, 2009, 19:02   #1
TurboBugger
Fuel Economy: 25mpg
Question window roll up / roll down on 02 jetta tdi or 00 beetle
hi,
I heard you can modify the vw jetta or vw beetle to allow the remote alarm to roll up and roll down the windows
there was some alientech page that is no longer active that did this. Is there a way to program the ccm or ecu to allow the remote to do this?
TurboBugger is offline   Reply With Quote
Old October 11th, 2009, 21:06   #2
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Short answer, no. Long answer, search.
While Alientech doesn't appear to be accepting new orders you could check eBay and here for units.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old October 20th, 2009, 14:56   #3
kei78
yes you can...
http://forums.tdiclub.com/showthread.php?t=148070
The guys in the Ontario area are lucky that one of its members are doing this for anyone who wants...
I have it done on mine... its completly reversable if you ever want for some reason.
Team Captain - Team Toyo Street
lil' Red: Jetta 1.8T
Missy: Golf TDI
"lil" Red v.3 Two Toned & Wide Bodied
Feature: Sport Compact National - Sept/Oct 2004
Cover/Feature: HCI Magazine - April 2006
Feature: Speed Style Sound (S3) Magazine - September 2006
Feature: RPM Motoring Magazine - February 2007
Feature: Quebec Tuning - June 2007
kei78 is offline   Reply With Quote
Old October 23rd, 2009, 10:45   #4
TurboBugger
Fuel Economy: 25mpg
I have a serial cable and a usb dual k vagcom. I was wondering if I could cut my serial cable and solder it to the vagcom obd2 connector? Does anyone have a diagram to do this? I do not know which obd2 wire goes to which pin on the serial cable
Old October 26th, 2009, 10:21   #5
TurboBugger
Fuel Economy: 25mpg
Im looking for VDC Pro. Does anyone have it? please PM ME!
Old November 5th, 2009, 22:49   #6
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
I thought there was a "flash" tool you could buy at one time that flashed this onto the ECU?
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old November 6th, 2009, 09:02   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
You can buy toll witch is flash yourm cc module .It call KVW100
here you go:
1.http://www.ecstuning.com/Volkswagen-...Search/Kvw100/
2.http://ziggituning.com/index2.htm
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Page generated in 0.09658 seconds with 9 queries
[Output: 77.16 Kb. compressed to 66.48 Kb. by saving 10.68 Kb. (13.84%)]
