zatffej
Looking for timing belt procedure for 2004 Passat TDI. Thanks
chittychittybangbang said:http://www.myturbodiesel.com/1000q_how_to/b5/bhw_timingbelt_1.htm
most of the work is to to slide the lock carrier out.
I think you just do it whenever you rid yourself of the chain.abctdi said:So should it be 80k or 100k?
I got rid of my chain too....now it's 15 pieces of chain.oilhammer said:I think you just do it whenever you rid yourself of the chain.
Too late...chainless at 56k under warranty, now what?oilhammer said:I think you just do it whenever you rid yourself of the chain.
Did they not replace the timing belt/tensioner etc when they did the balance shaft? You should have requested it, and paid for the parts, if necessary. That would have got you to 136,000 miles or more without having to worry about it.abctdi said:Too late...chainless at 56k under warranty, now what?
