Old October 11th, 2009, 06:59   #1
EnrichoPalazzo
Default Intake Manifold A4 to A3 Retrofit?
I'm sick and tired of cleaning my intake manifold.
I'd like to retrofit the A4 intake manifold; and include EGR Delete (via both chip and race pipe). I've heard the A4 AHU manifold will fit the A3; but, obviously, the air intake points to the right side of the engine (A4) versus left (A3). How 'bout moving the washer fluid reservoir to the left (where the air box is); and using that space for new air intake (like a new A4 cold air intake)?
I can get a replacement Intake Manifold for 99.5+ A4 for $99. Impex wants $514 for new A3 Intake Manifold (which includes EGR). Any thoughts?
Charlie Franz, Bel Air, MD
1998 Jetta TDI 190K
1986 Golf TD (w/84 Jetta 1.6 TD motor) 250K
EnrichoPalazzo is offline   Reply With Quote
Old October 11th, 2009, 07:13   #2
G60ING
G60ING's Avatar
There are other options, I just yanked my mk3 tdi intake
*order a European Passat intake. I picked up a PD for $75 shipped and had a friend make me a race pipe.
*Take a Mk4 ALH and cut it and flip it. I did this on my DZSL SLC
*Take the MK3 intake and cut the EGR off and then cut the inlet to the EGR off and weld it to the intake.
Pics we all love pics
Here is the Mk4 that I had cut and flipped:
The European PD intake:
All Cleaned up:
Mk3 Manifold with the EGR deleted:
G60ING is offline   Reply With Quote
Old October 13th, 2009, 10:33   #3
cscmc1
TDI(s): n/a
I bought mine off Craigslist -- someone just cut the pipe off at the EGR and welded some galvanized pipe in its place. Been working great for a couple of years now!
1998 Jetta TDI
cscmc1 is offline   Reply With Quote
Old October 14th, 2009, 00:25   #4
EnrichoPalazzo
G60ing, Thank you very much for your quick reply. Sorry, I was off a couple of days. The PICs are Excellent. Is that a Corrado converted to TDI?
That definitely changes my ideas about "retrofitting". Are you saying the European Passat intake bolts on and points left in an A3 Jetta w/o issue?
Old October 14th, 2009, 05:52   #5
G60ING
G60ING's Avatar
fits like a glove on the Mk3 engine:
Old October 14th, 2009, 19:35   #6
paramedick
paramedick's Avatar
Fits great in the B4 also. TDIParts sells the PD racepipe. Just gotta trim the length to let the factory hose connect up.
Old October 14th, 2009, 19:45   #7
Wally
Dude,
that is so sexy...
And where'd you get the the little engine cover from?
98 NB TDI Black 241k (Looks Stock...) 96 Passat Wagon TDI White 227k RIP
97 Passat Wagon TDI Black 281k 03 A4V Blue 237k
All B100 Powered-Homebrewed since April 2000
Relocated to Prescott, AZ from Saratoga, NY
Wally is offline   Reply With Quote
Old October 14th, 2009, 20:16   #8
G60ING
G60ING's Avatar
I picked a couple up from german ebay.
Old October 15th, 2009, 09:18   #9
Wally
PM Sent.
Old November 4th, 2009, 19:21   #10
savannah996
savannah996's Avatar
TDI(s): None now
anyone know where i can get a euro pd intake?
savannah996 is offline   Reply With Quote
Old November 7th, 2009, 07:12   #11
Matt-98AHU
Matt-98AHU's Avatar
If cleaning your intake is the only reason you want to change the manifold, why not just get block off plates for the EGR system and delete the EGR cooler?
Beyond that, the PD intake is a good performance upgrade. It flows better. Block off plates are much cheaper, though
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old March 9th, 2010, 17:32   #12
CNDTDI
CNDTDI's Avatar
Fuel Economy: 33/45/55
hello does anyone have the part number for one of those pd intakes? id like one myself
2012 Jetta with 57K KM 6 spd manual
sold 98 jetta 295k KM
sold 91 golf odo died at 400k KM
any idiot can face a crisis, its this day-to-day living that wears you out.
CNDTDI is offline   Reply With Quote
Old March 11th, 2010, 15:48   #13
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
exactly. $2 solution to the problem
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old March 13th, 2010, 00:26   #14
bikeprof
bikeprof's Avatar
Fuel Economy: 47 @ 65 & getting better...
2 ez...
bikeprof is offline   Reply With Quote
Page generated in 0.20062 seconds with 9 queries
[Output: 115.33 Kb. compressed to 95.26 Kb. by saving 20.07 Kb. (17.40%)]
