Old October 1st, 2009, 08:18   #1
evad
TDI(s): 2005 jetta
Default 2005 tdi (bew) jetta
I have a problem with my jetti,it has a surging problem with it. The 4 shops I've taken it to are all stumped. If you hold the speed at 75 to 80 it has a constant surging or miss. When you set the criuse at a speed it will begin to slow down, then if you tap the throttle it will go back to the speed it was set to. this all takes place between 2000 and 3000 rpm's. Also if you go up thru the gears at a slow pace you can feel the surging, but if you get on it the car performs fine. If anyone out there has any ideas on this problem, I would appreciate the INFO!
evad is offline   Reply With Quote
Old October 1st, 2009, 16:11   #2
andreigbs
Welcome to TDIclub!
It's a Jetta, not Jetti...
Try to find someone nearby who has VAG-com, or VCDS for short. They'll help you diagnose. I doubt there are any indy shops in MONTANA that specialize in TDIs. Then again, how far are you from Boise, ID? Username "Drivbiwire" is one of the top gurus and lives there. Definitely worth the drive to have him look it over/diagnose whatever problems you're having.
2014 GLK250 BT // 65xxx miles // 37 MPG - current
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed!
2004 Bora TDI // 146xxx miles // 42 MPG - sold!
1997 Jetta TDI // 317xxx miles // 44 MPG - sold!
1986 Golf NA Diesel // 188xxx miles // 52 MPG - totalled
andreigbs is offline   Reply With Quote
Old October 1st, 2009, 16:19   #3
frugality
frugality's Avatar
Fuel Economy: 33mpg
I would try this easy test: disconnect your MAF (mass air flow) sensor and go for a drive and see how it drives. It's the electrical connection where the accordion intake tube meets the air filter box. Running with the MAF sensor disconnected will cause the check-engine light to come on for a while, but it will go off on its own, and driving with the MAF disconnected will not harm things. But if it drives better with the MAF disconnected, it means you have a bad MAF sensor. One of the possible symptoms of a bad MAF is that it sometimes messes with the cruise control, but my experience with that is on an ALH motor, not a PD/BEW.
(if you do end up needing a new MAF sensor: http://www.tdiparts.com/catalog/prod...roducts_id=648 )
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline   Reply With Quote
Old October 2nd, 2009, 04:49   #4
PDJetta
PDJetta's Avatar
How is the idle smoothness? I wonder if your camshaft and lifters are beginning to wear out. Has VW 505.01 oil been used it's whole life? How many miles are on it?
Another possibility is a failing in-tank lift pump or glogged fuel filter.
--Nate
Old October 2nd, 2009, 08:16   #5
evad
TDI(s): 2005 jetta
Thanks frugality,andreigbs,and pdjetta for the info. I will work on thes ideas. The car has 200k on it, but has been maintained very well. The idle is perfect, and have used 505.01 oil from the beginning. Had the fuel system cleaned and have changed the fuel filter every 9 months. Again thanks for the info. If there and other thoughts out there please post them. Thank You!
Page generated in 0.13068 seconds with 9 queries
[Output: 65.63 Kb. compressed to 57.42 Kb. by saving 8.21 Kb. (12.51%)]
