Old September 16th, 2009, 18:23   #1
dzcad90
Rolex & gin
dzcad90's Avatar
Lightbulb HowTo: RNS-510 Installation + Coding ('09 Jetta)
RNS-510 Retrofit Instructions - '09 Jetta TDI
Tools Required:
  • Precision straight screwdriver. 1.4MM worked for me.
  • Small straight screwdriver.
  • T15 driver.
  • 18 inch flat ruler or other straight, flat object. (For fishing the satellite antenna wire..)
  • Microfiber cloth.
Items required:
  • RNS-510 head unit for the proper region (US unit, EU unit, etc..)
  • Antenna Adaptor - Part no 7L6 051 551 - Currently $31.13 from Impex (Interesting Fact: 7L6 parts are for the Touraeg..)
  • GPS Antenna. (Not shown in this picture.)
Head Unit Removal:
Note that in this procedure I will show a few pictures of a screwdriver being used directly on the plastic. Depending on how anal you are, how careful you are, and your level of concern for your interior trim
you might want to wrap the end of the screwdriver in the microfiber towel to avoid damaging the trim. I did, I removed it in most cases for picture clarity. Sometimes it's easier to not use the towel, however
you do run the risk of scratching your trim.
IMPORTANT STEP: Turn your Climatic air output to the defrost setting. This will close off the vent that goes down into the AC system. This will lessen the likelyhood of tools and parts dropping into the abyss.
You will find out why later on in this How-To
You may want to disconnect your battery before performing any of the following steps for an added level of safety.
Legaleese: The author of this How-To nor TDIClub assumes any responsibility for the content of this post, the accuracy of the information provided herein, or any damage that may result as of the application of this information. Have fun
1. Remove the above peice. In cars without Climatronic, this is a dummy peice. In cars WITH climatronic, this is an infrared sensor - be mindful of the connector when removing.
2. Remove the torx screw here.
3. CAREFULLY pry up the screen here all around the edge. The trim peice surrounding the indirect venting selector wheel will come off and makes this a little easier.
4. Pry up the vent assembely. Again, patience is the key here. It will come, and it will sound like plastic is snapping. It's fine though.
5. Be sure the Climatic selector knob is on defrost.
6. Remove the two torx screws circled in red and use the screwdriver to carefully pry the trim away from the three green marked points in the rear.
Pictures get a little few after here because the process is pretty easy to figure out from this point on.
I was panicing after a precision screwdriver managed to fly into the open vent, never to be seen again. This is why I place emphasis on closing the vent.
7. Pull the top vent trim toward you a little until it raises about 1/4 inch from the top of the radio. Then gently pull STRAIGHT UP from the radio until the two tabs separate from the lower portion of the dash.
8. At this point you can either simply move the vent piece to the side and set it on the top of the dash, or you can remove the electrical connectors and completely remove it from the dash area. I just moved it to the side and it was fine.
9. Remove the two torx screws made visible after the removal of the top vent piece.
10. Carefully use your screwdriver to remove the trim surrounding the lower portion of the radio and the climate control knobs. Mine didn’t require much force at all and I was able to remove by hand without using the screwdriver. YMMV.
11. Remove the four Torx screws from the corners of the radio.
Your old radio should pull right out now. Pull it out until you are limited by the length of the antenna wires or the radio electrical harness.
12. Remove the antenna connectors from the radio.
13. Remove the electrical harness from the radio. The bottom of the connector has a lever - flip it 90 degrees and the connector will come right off.
Set your old radio aside. If your RNS came with a plastic protector over the face, this should fit your Premium VII radio perfectly.
15. Install the antenna adaptor. Match the colors to each single antenna lead. You will be left with the double antenna lead to plug into your RNS.
16. Install your GPS antenna. This is where I’m really sorry I have no better pictures. The antenna included in my kit had a magnetic base and was about 1 inch square. Stick it to the support bar that goes across the dash. It sides right in and fits perfectly. The location is circled in the above picture. Neatly coil the slack to be placed behind the RNS. You can alternately mount the antenna wherever you wish, however make sure it’s on something metallic for best operation.
GPS receiver circuts are very sensitive these days, and the antenna can be mounted below the dash without having a significant effect on satellite reception. I get a fix on 9 satellites in this location.
17. If your car was equipped with the Aux In connector in the center console, you must do some pin swapping on the BLUE connector in the electrical harness. These steps are covered here.
The large black connector actually houses three smaller connectors. You will be removing the blue connector from the black connector. Use a small screwdriver to push the clip down on the blue connector and pull it from the black connector. One side of the blue connector is open so you can see the black housing inside of it. On the side of the blue connector you can see a little spot to pry and the blue housing will slide off of the black connector.
In the above picture, you can see that the Aux wiring is a separate wire bundle from the rest of the car. It contains a lime green wire, a gray wire, and a yellow wire. We will be moving the yellow and gray wires.
Using the smallest straight screwdriver you have (I used a 1.4mm driver), push down on the barb of the gray wire and push it toward the rear of the connector. After you reach a ceratin point, you can then gently pull the wire out from the connector.
If you look at the top of the black connector, you can see that each wire position is numbered, 1-6 on the top and this continues on to the bottom from 7-12.
You will swap the gray wire to pin 7 and the yellow wire to pin 1.
Re-assemble the black connector into the blue connector and then re-assemble the blue connector into the larger connector housing that connects to the radio.
18. Plug in your Sirius extension cable to the green connector on the back of the radio.
19. Plug in your GPS antenna connection to the blue connector on the back of the radio.
20. Carefully slide your RNS-510 into the dash opening, being mindful of the GPS and Satellite radio antenna wires. Make sure they are neatly bundled behind the radio and do not bind on anything.
21. At this point, you can turn your car on and test the functionality of your RNS unit. Note that it takes up to 15 minutes for the GPS to acquire a position fix. Until that time, it thinks you’re in Manhattan. Turn off the RNS and the car when you’ve assured that the RNS works. There will be plenty of time to play with it in a little bit
22. Replace the 4 torx screws that hold the head unit in, and re-assemble the dash. Just reverse the steps above. Note that all the screws used in this procedure are the same size and interchangeable.
The RNS unit is now installed, and will probably work, however you will need to perform the following steps to ensure that no trouble codes are stored and the RNS is configured properly.
Continued in next post...
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Old September 16th, 2009, 18:23   #2
dzcad90
Rolex & gin
dzcad90's Avatar
Disconnect the Satellite Receiver and Position Sensing (Compass) Module in the trunk
Above picture courtesy: TurbineSuburban.
1. Disconnect the two cables from the Sirius receiver in the trunk. This Sirius receiver is now unused in your car. I tucked the cables neatly into the gray liner so they don’t rattle.
This picture shows where the compass module resides. It's mounted on the metal that is under the cloth hat shelf in a Jetta. In the JSW and Golf/Rabbit/GTI it's mounted above the headliner.
2. Press the clip, push up on the module and spin the module 90 degrees so you can access the connector. Unclip it and secure the connector so it does not rattle. Rotate the position sensing module back to its original position so the tab locks and the module is secure.
The RNS -510 will provide compass information to the instrument cluster using information received via the satellite. Having the legacy position sensor and the RNS plugged in has been found to cause a lot of excess traffic on the CAN bus.
VCDS Programming
Hopefully if you plan on going 100% on this project, you either have or have access to a VCDS with the proper interface for CAN bus based cars. If not, consult the VAG-Tool locator. The link is available on TDIClub and is also available via a Google search.
Recode the CAN gateway for installed options
1. Select module 19 – CAN Gateway
2. Select “Coding -07”
3. Write down / copy your existing long coding.
4. Go through the long coding. You will uncheck the boxes next to “Digital Radio” and “Position Sensing.” Place a check mark in the box next to “Navigation” Exit long coding.
5. Click “Do It” to save your new long coding.
- Don
Old September 16th, 2009, 18:24   #3
dzcad90
Rolex & gin
dzcad90's Avatar
Code your Navi Unit
The RNS-510 now will answer to either address word “ 37 – Navigation” or “56 – Radio.” Both are the same module and coding only needs to be performed on one of these. It does not matter which module you select here.
1. Select module 37 - Navigation
2. Select Coding - 07
3. Code your unit similar to the following screenshots:
The coding options are pretty self explanitory. Any reference to "Sound System" indicates that you have an amplifier under the drivers seat. Some '09 TDI loyal edition owners are reporting they have this as do some earlier model MKVs, so you should code your unit accordingly. Most cars can code just like this and be good.
Note that on the last page of coding options, there's a Display Variant. This allows you to select one of three different "skins" that the RNS has programmed in. The premium I believe is what comes on stock '09 Jetta TDIs with RNS-510. I perfer the highline. The sportline has some bright colors if you're into that kind of thing. Try them all.
4. Before you click "Do It!" you need to enter in a workshop, importer, and equipment code here or your unit will store a fault code that it is not coded correctly. I made up numbers, however you may do as you wish. Just don't leave everything at all zeroes. Once these are coded ,it appears they are not changable for some reason.
5. Click "Do It!"
Whenever you change coding on the RNS, you need to perform a reset of the unit for those changes to take effect. Hold the day/night, left, and right buttons that are adjacent to the DVD slot. The RNS will power off and then on again.
- Don
Old September 16th, 2009, 18:24   #4
dzcad90
Rolex & gin
dzcad90's Avatar
Bluetooth Module Coding
If your car came equipped with the 9W3 factory Bluetooth module, you can enable the advanced functionality of this module with your RNS. On supported phones, it will download the phone book, missed calls, recent calls, and dialed calls list and display this information on the RNS. You will also receive caller ID information on the RNS.
This coding procedure is known to work on BT modules 1Z0 035 729 A and 1Z0 035 729 D. Modules with the same part number ending in B and C may also work with this coding. If you have the Volk-L, you cannot get this to give you the advanced functionality on the RNS-510. It is simply not supported, however you MAY be able to enable Bluetooth audio to the
RNS-510 if you have the Volk-L module.
Some older production North American RNS-510 modules do not have a “Phone” button, but have a “Mute” button instead. It is my understanding that this will work as the phone button, so don’t panic if your RNS says “Mute” as the fourth button down on the left side.
1. Select 77 - Telephone
2. Code your module as shown above
My car came coded as: 0000377
I had the Premium VII head unit and MFSW.
The new coding to enable the menus on the RNS is : 0010377
3. Click "Do It!"
You will need to reset the RNS-510 for this change to be recognized by the nav unit.
At this point, you're pretty much done. You can run an auto-scan / clear all DTCs with VCDS and should come up with no faults regarding navi, radio, digital radio, or position sensing. You may have a fault for "Tuner not enabled / activated" if you haven't activated your Sirius tuner inside the RNS. Keep in mind that you will need to contact Sirius and give them your new Sirius ID for your RNS-510. The RNS-510 has two Sirius IDs, one for Audio and one for Traffic. The traffic info is about $3 a month I belive. It's well worth it. It's been fairly accurate around Chicago and the RNS will figure traffic delays into navigatoin time to destination. You can get your IDs by turning to channel 0 on Sirius, or it's in the Setup menu.
Be sure to press Setup on the unit and go through the menus and set your preferences, especially enabling HD radio. You also need to enable Aux-In in the setup menu as well if you have it.
- Don
Old September 16th, 2009, 18:54   #5
dzcad90
Rolex & gin
dzcad90's Avatar
Reserved for instructions on fishing satellite antenna. Will post at a later date when I get the pictures.
- Don
Old September 16th, 2009, 18:54   #6
D-Cell_Mekanick
Fuel Economy: 45ish
Very nice. Now I need me one of them pesky RNS-510's.
2014 Passat SEL TDI(GONE BUT NOT FORGOTTEN). Tungsten Silver exterior with Titan Black interior. I have VCDS HEX-USB+CAN, still learning how to use it.
D-Cell_Mekanick is offline   Reply With Quote
Old September 16th, 2009, 19:28   #7
MPBsr
Very impressive write up.
MPBsr is offline   Reply With Quote
Old September 17th, 2009, 11:28   #8
Turbine Suburban
I'm in this thread.
Just wish I had the cabbage to REALLY be in this thread!
Would those numbers you made up actually be a security code if someone were to pop the radio? I.E., what keeps it secure?
BTW, excellent write up!
Turbine Suburban is offline   Reply With Quote
Old September 22nd, 2009, 09:28   #9
jryanvt
TDI(s): 2010 jetta
dzcad90, thanks for the great guide. i've popped in other forums and said the same thing, but i'm waiting for someone with a 2010 jetta tdi to perform the upgrade from the rcd-510 to the rns-510, and maybe while they're at it upgrade the bluetooth. then hopefully that will give me the confidence to do the upgrade myself.
jryanvt is offline   Reply With Quote
Old September 22nd, 2009, 17:16   #10
dzcad90
Rolex & gin
dzcad90's Avatar
I think I talked to you on GolfMKV.com.
'10 is the same procedure.
Since your car has a bluetooth module already, it's plug and play with the bluetooth as well. Remove the old module, plug in the new one. It's one or two bolts and the electrical connector.
You're local. Get the parts and bring it over and we'll get it installed!! I bet Peter has a few units left. Also, if you are interested, I have a buyer for your RCD-510
- Don
Old September 26th, 2009, 19:36   #11
Ironman24
I have a 2010 and received a RNS-510 from Peter this week. I plan on starting the install tomorrow. I also have a plug N play amp to install under the drivers seat and subs/amp for the trunk so the whole process will take me a while.
I am a little concerned with the coding on the 2010 due to very limited options I got when hooking up my vag com. According to Ross-Tech the 2010 has some MKVI control modules and there is very limited information on them.
I am supposed to log some controler channel maps for Ross Tech and email them over so they can start to look at the new controlers.
I should at least be able to get the RNS-510 and PnP amp installed tomorrow if the weather holds out. Will keep you posted...
Michael Huff
10 Jetta TDI DSG
Ironman24 is offline   Reply With Quote
Old September 27th, 2009, 19:27   #12
Ironman24
Well I got everything hooked up today including a 4 channel plug N play amp under the drivers seat and some bass in the trunk. I just have to put all the trim back together this week.
Couple of notes for a 2010...
The blue connector only had 3 wires, 2 of them were yellow and gray and already in the correct 1 and 7 positions so I didn't have to do that.
I did not need to use the antenna adaptor, that just plugged right in. I will be able to use it when I put the RCD-510 in my 09.
I don't have a sirus receiver in the trunk so I'm assuming it's built into the RCD-510? I'm assuming the module for the bluetooth is the one under the passengers seat. I have to call sirus this week and get that activates.
I unplugged the compass module on the rear deck lid but now I have no direction displayed in the MFD.
Other than some coding issues it really is plug N play. Everything on the unit seems to be working, it found my location after about 10 minutes. I used the SD card and that worked and I also synced up my phone via bluetooth and all my contacts showed up on screen.
I made all the changes listed in this thread with vag-com but I am still getting some stange fault codes in the instrument (17) and steering assist (44). I also have a lot of malfunction status for several controlers.
Don, can I send you a copy of my log for possible help with coding on the fault codes? Do I need to find a 2010 with a factory Navi unit?
Michael Huff
10 Jetta TDI DSG
Old September 27th, 2009, 20:44   #13
dzcad90
Rolex & gin
dzcad90's Avatar
Send it over. I'll take a look at it.
You don't have compass, do you get navi information in the MFD?
You might need to enable BAP on the '10. It's in long coding of the Navi unit.
- Don
Old September 30th, 2009, 13:04   #14
Ironman24
Don is the man for this install. He helped me get my issues figured out. Turns out part of them were from having the battery disconncted since I ran a wire through the firewall for my amp (not required for navi install) and then not resetting the navi unit by pressing the 3 buttons.
For coding, the only thing different I did in addition to what is listed above is check the shortpress steering wheel controls box and the BAP communication with the instrument cluster box (both are located on the last screen shot)
So, if you have a 2010 it's easier than a 2009.
Michael Huff
10 Jetta TDI DSG
Old November 2nd, 2009, 08:44   #15
jryanvt
TDI(s): 2010 jetta
has anyone else done the rns-510 swap on a 2010 jetta tdi sedan? i am trying to figure out if i need a sirius extension cable. from the looks of ironman24's post, the sirius receiver might not be in the trunk. thanks.
Page generated in 0.20378 seconds with 9 queries
[Output: 144.25 Kb. compressed to 122.07 Kb. by saving 22.19 Kb. (15.38%)]
