Old November 1st, 2011, 07:36   #31
Yblocker
TDI(s): 1997 Passat
Bowelder-
Read this:
http://www.myturbodiesel.com/1000q/m...er-mod-TDI.htm
K03/04 hybrid turbo, RC II, Stage II Cam, Titan 502's, DC Stage I, TT LCA bushings
Yblocker is offline   Reply With Quote
Old November 1st, 2011, 11:13   #32
davidm2232
Fuel Economy: Hoping for 30MPG
Originally Posted by rventerprises View Post
I can't get a consistent reading for my IQ. I get it to 3.0, then drive it, it has absolutely no power and dies when I push the clutch in. After a hard restart the IQ is at 8 or 9 and slowly drops. I just can't get it dialed in. When I crack the torx screws loose, I get a bunch of air in my fuel line, if I get a decent IQ it starts idling really rough when I tighten the screws. Any suggestions before this thing visits the bottom of the local reservoir?
I'm having the same problem. I have to hold the go pedal to the floor and crank the starter for like 30 seconds to get it to start. I need to drive this to school, how can i get it back to stock?
davidm2232 is offline   Reply With Quote
Old November 1st, 2011, 11:30   #33
kooyajerms
grocery getter
kooyajerms's Avatar
Originally Posted by NB_TDi
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
Love it.
kooyajerms is offline   Reply With Quote
Old December 6th, 2011, 03:50   #34
shwagondawheels
shwagondawheels's Avatar
Fuel Economy: 40/47 city/hwy
from what I've been reading it sounds like the IQ needs the be raised when you install larger injector nozzles correct?
or the value your looking at in vag has to be raised
I have an AHU A3 tdi and just installed a set of Bosio P520 sprints yesterday and Im going to a friends shop today to hook up the vag and set the idle injection quantity. It smells pretty rich and I swear I could see the fuel gauge moving on a 50 mile test drive. I did let it idle a while so that didn't help mpg.
But I would like to try this too because my triangle bolt has been ground into a square so somebody has been playing with it before me and that would explain some issues if they didn't us VCDS doing whatever they did in there and the IQ has been off..
shwagondawheels is offline   Reply With Quote
Old February 3rd, 2012, 11:26   #35
fastcash43
Did the original author of this thread forget to mention loosening the 4th triangle bolt or is the point of the article to show that the hammer mod can be done without loosening the triangle bolt. Can I get some confirmation from folks that hammer mod can be done without loosening the 4th bolt ?
fastcash43 is offline   Reply With Quote
Old February 3rd, 2012, 11:52   #36
Good Ol' Boy
VeeDubTDI's Avatar
It can be done without loosening the 4th bolt.
Old February 4th, 2012, 07:13   #37
fastcash43
Thanks VeeDubTDI, I'm going to give it a try today. Btw does going the 3 bolt method increase potential for pump gasket damage etc does anyone know ?
Old February 6th, 2012, 11:11   #38
fastcash43
UPDATE: I did the hammer mod the other day, loosening ONLY 3 pump head bolts (ignored the special triangle bolt) with success. The 3 bolt method does work or at least so far anyway. The question now is has anyone who's done the (3 bolt) hammer mod not had success ? Are we all wasting time and money diggering around for that special triangle socket for nothing ?
Old February 6th, 2012, 12:35   #39
Good Ol' Boy
VeeDubTDI's Avatar
I suspect that there is an increased risk for gasket damage by only loosening 3 of the 4 bolts. If you have a very old pump, you may want to consider loosening the 4th bolt or sucking it up and doing a pump re-seal (it probably needs it anyway).
We've had varying success by only loosening 3 bolts. Some pumps are fine, others leak afterwards. Who knows if loosening the 4th bolt would have saved the gasket - not really worth trying in my opinion... if it leaks, re-seal it because it's going to leak eventually anyway.
Old March 5th, 2012, 20:54   #40
acesneights
acesneights's Avatar
if you are good you can have the car running with VCDS displaying the IQ reading while you whack it. (not hard!) that takes the guesswork out of it
if you loosen the bolt too much, it squirts you with fuel... tighten it a little.
altho pay attention as you tighten the bolts, the IQ value may change...
it would also be a good idea to get the special bit from metalnerd to loosen the 4th bolt, makes the job much easier.
Good How to BTW
Metalnerd ?? Can you expand on that ?
Thanks.
2004 Golf TDI 5 spd 4dr
acesneights is offline   Reply With Quote
Old March 6th, 2012, 15:59   #41
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
Thanks.
Welcome to metalnerd.com, your source for specialty tools and accessories for German Automobiles.
1998 Beetle TDI Malone Tuning Stage 2
2001 Dodge Cummins 5.9
2005 Dodge Cummins 5.9
maxwellp is offline   Reply With Quote
Old April 1st, 2012, 23:22   #42
TTR 21
TTR 21's Avatar
TDI(s): 2002 Super J
I recently did this mod and while the engine was running i tapped the pump towards the driver side until the idle became poor. I then slightly tapped it back to where the idle just cleaned up. It feels like i have definately picked up a HP from doing this. The exhaust has a slight puff of black smoke when you tap the throttle or quickly accelerate from a stop.
2002 VW Jetta GLS TDI 5 speed: Kerma 150kit w/ borg S7 Turbo, 3" turbo back, AFE intake, Intercooler and intake piping, EGR delete, ARP Head studs. 16.0@ 86mph 1/4 mile
1994 Dodge Cummins Race Truck: 1000+HP 10.64 @129 1/4 mile
www.DX2Parts.com
TTR 21 is offline   Reply With Quote
Old May 6th, 2013, 16:08   #43
thesupercat
Fuel Economy: 45 mpg (with foot in it)
I did this exact method, just out of common sense, then had my IQ checked with VCDS, it was running at 1.0. There was TONS more power and absolutely no smoke except a light haze at idle when cold. I have done almost every airflow related upgrade I can think of, 3" DP & exhaust, k03/k04 turbo, ported head and exhaust manifold, port matched intake, egr delete, 1.5" intercooler piping, etc... My question is: Is there anything wrong with running at 1.0 with my setup? I have not upgraded injectors yet, that will come soon. But is there a danger of over-stressing the pump or overheating the turbo, valves, piston, etc. when running at 1.0? Once again absolutly no smoke when I had it at 1.0. Mileage seemed to be fine until I used the power, but I never did run it that way long enough to burn through a tank and then refuel. If I got on it and then looked at the gauge it would sometimes have dropped noticeably. Have it set at 3.2 now and really miss the power!
TIA for any input!
thesupercat is offline   Reply With Quote
Old January 7th, 2015, 20:41   #44
VRTn
NB_TDi :
I followed your procedure for the hammer mod on my 01 jetta which had a real bad case of the slowdown/idle shudders.
After 1 small tap I went from 2.4 to 9.1. So I gave it a small tap back and it was within spec. No more shudder but I now have a small leak (gasket must have got compromised). I still have a real rich smell from the exhaust and my pump timing is good as well. I have bosio .205 nozzles but no other mods.
My question does the IQ # being lower mean more fuel (and higher the number less fuel?). Because I have experienced a loss in power from bringing the IQ up to spec which doesn't make sense to me lol. Going to tinker with it again tomorrow evening, I may need to source out a new gasket.
VRTn is offline   Reply With Quote
Old January 7th, 2015, 21:12   #45
SFHGolfTDI
SFHGolfTDI's Avatar
Originally Posted by VRTn View Post
NB_TDi :
Yes, this is how it works.
Front end swap (Jolf), GTI tails, heated GTI leathers, GLI steering wheel, aluminum trim, center console w/cupholders, homelink visor, SGII, front/rear fogs, remote windows, 35% ceramic tint, Q5/Touareg rear wiper, roof rack, vented, PD engine cover mounts, Fumoto F106SW, panzer skid, Bilstein HDs, mudflaps, Conti PureContacts, custom 2" class II hitch. Kerma tuning. VCDS available (K-II USB).
SFHGolfTDI is offline   Reply With Quote
Page generated in 0.16237 seconds with 9 queries
[Output: 128.28 Kb. compressed to 106.98 Kb. by saving 21.30 Kb. (16.60%)]
