Old January 25th, 2010, 13:27   #16
NateTDI
Fuel Economy: 2000 Jetta, low 50's
Dumb question alert!!!!
Why would one want to do the hammer mod?
NateTDI is offline   Reply With Quote
Old January 25th, 2010, 13:55   #17
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
If you're IQ is out of spec, you want to do this. This will slove most cases of slow down shudder.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old January 25th, 2010, 22:31   #18
Ausgezeichnet TDi
Ausgezeichnet TDi's Avatar
TDI(s): None
Great writeup NB, I've seen this post awhile ago thinking that I'd never have to do this, and I think I just may....anyone ever heard of an idle shudder (not slow down)?
Here's the situation...got the 99.5 Jetta in March with 100k mi, has had an idle "shudder" ever since. When I say shudder I mean stuttering. I get excessive shudder almost like a misfire on a gasser. I can come to a stop, engine shudders, keeps shuddering and sputtering until I "blip" the throttle then it smooths out for whatever period of time, then it will go back into throwing a fit. Timing belt was done by a trusted guru shortly after I purchased it, and I had a code for quantity adjuster and my timing was jumping all over the place so I ended up putting in a high quality rebuild from DFIS at the recommendation of the trustworthy guru. Shortly after I installed balanced injectors with Sprint 520's from a very reputable vendor through this site. Together they made the shudder 1/3 as intense as it was, but its still there.
I had a fellow member check my IQ when up to temp, and we adjusted it up to 4.0 as it will not go any higher...any lower and it shakes uncontrollably...alas I think this is my next step (besides buying VCDS once and for all!!). Does it seem odd that even with a new pump I can't get the IQ setting higher than 4? Is this another one of those weird 99.5 glitches?
I didn't intend to hijack this thread and if so I apologize, just wanted to request some more experienced brainpower! Thanks! -AGTDI
R.I.P. 2003 Bora Estate TDI -
2006 Volvo V70R
Ausgezeichnet TDi is offline   Reply With Quote
Old January 26th, 2010, 04:29   #19
NB_TDi
NB_TDi's Avatar
VCDS cannot adjust very far, actually it's the pump. That's when you perform this mod. You'd reset your settings via VCDS and then do this mod. Then you can fine tune it with VCDS.
I had idle and slowdown shudder too.
Old September 11th, 2011, 18:42   #20
Good Ol' Boy
VeeDubTDI's Avatar
Gonna make this a sticky for a little while. Great How-To thread!
Old September 16th, 2011, 16:57   #21
NB_TDi
NB_TDi's Avatar
Sweet!
Thanks!
Old September 18th, 2011, 17:30   #22
Good Ol' Boy
VeeDubTDI's Avatar
+400 views in a week. Not bad!
Old September 18th, 2011, 17:33   #23
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
It's the title promising cake that is the draw .
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old October 23rd, 2011, 22:56   #24
Rawlins
Rawlins's Avatar
What, no cake? Fooled again. Nice write up. Will be doing this soon
Rawlins is offline   Reply With Quote
Old October 26th, 2011, 10:00   #25
kooyajerms
grocery getter
kooyajerms's Avatar
NB, why don't you loosen the anti-tammper bolt in your method? I was scratching my head till Matthew and CCBB posted the more familiar style of hammer modding. Thought I was crazy.
kooyajerms is offline   Reply With Quote
Old October 31st, 2011, 18:00   #26
rventerprises
TDI(s): '12 Jetta
I can't get a consistent reading for my IQ. I get it to 3.0, then drive it, it has absolutely no power and dies when I push the clutch in. After a hard restart the IQ is at 8 or 9 and slowly drops. I just can't get it dialed in. When I crack the torx screws loose, I get a bunch of air in my fuel line, if I get a decent IQ it starts idling really rough when I tighten the screws. Any suggestions before this thing visits the bottom of the local reservoir?
rventerprises is offline   Reply With Quote
Old October 31st, 2011, 18:28   #27
Ski in NC
Fuel Economy: 48-52 typical
Sounds like an air getting into the fuel problem, fuel restriction but not an IQ problem. As I understand it, if iq goes up to 8 or 9 as you describe, that is the QA moving the collar to compensate for the root problem. Any signs of fuel leaks on your injection pump?
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 31st, 2011, 21:50   #28
NB_TDi
NB_TDi's Avatar
Mainly because in my situation, and the others I've fixed, it's barely out. If it was completely off due to some catastrophic failure, then yeah maybe.
Sorry about the cake. Perhaps you'd like some conversion gel?
Old November 1st, 2011, 06:26   #29
bowelder
as a newbie (approx 1 month) in the club, I still don't know what most of you all are talking about most of the time. But i'm reading and learning daily. My question is, what is IQ and is this something i should be looking at with my 2000 Golf ALH engine?
all these abbreviations are rough on the newbies
bowelder is offline   Reply With Quote
Old November 1st, 2011, 07:33   #30
rventerprises
TDI(s): '12 Jetta
I am a newbie too and I have been scouring threads for 3 days trying to find a solution. I see massive amounts of air in my clear inlet line but only at certain IQ adjustments. It could just be coincidence I see the air when I loosen the screws but sometimes I see it after I tighten them. The only thing I can think of is I read something about some check valves I could have gotten stuck when I bled the air out the first time. I have a mity-vac I put it on the return to the right of the pump the first time and thought I got it. Yesterday I put a new fuel filter on. I thought I read about a check valve at the tank so I put the mity-vac to pressure to try to reseat it before sucking the air out. Then pinched the returns on the filter before sucking the air out of the filter. Filter was filled before installing. Where else can air get in?
Page generated in 0.17079 seconds with 9 queries
[Output: 125.92 Kb. compressed to 104.68 Kb. by saving 21.24 Kb. (16.87%)]
