Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2009
TDIFest 2009 Discussion about TDIFest 2009 coming to Washington, DC (Dulles)on the Labour Day weekend (September 4-6th, 2009) .
Old September 17th, 2009, 04:37   #76
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
I do think a dyno is a liability defcit. Having a serious malfunction with out the benefit of having a TDI knowledgable garage on site, ie. Wis fest, is paramount. The Fest is not really to show off muscle that should be left to local GTGs.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old September 17th, 2009, 06:59   #77
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
A dyno is less abusive than starting from the stop light when it turns green.
The clutch is already engaged, the wheels are already rolling, there is no driveline 'shock'.
One gear is used for the pull, there is no shifting. (automatics might shift, but the ECU/TCU controls this to the same conditions as used daily).
There is no steering input, no angular load on C/V joints.
There are no potholes, no speed bumps, no changes in suspension load.
Any car that has "a serious malfunction" on rollers was not in any condition to have been driven TO the rollers.
Svante Arrhenius 1896
Old September 17th, 2009, 12:14   #78
Good Ol' Boy
VeeDubTDI's Avatar
Amen!
We're not driving 1,000+ HP Toyota Supras here... if someone's car blew up because the dyno operator floored it, then it shouldn't have been driven there in the first place.
Page generated in 0.12059 seconds with 9 queries
[Output: 58.33 Kb. compressed to 52.77 Kb. by saving 5.56 Kb. (9.53%)]
