Old September 7th, 2009, 22:12   #1
blizzak
Default MK3 Jetta with VNT-15 swap, tune, and supporting mods: PP520's or PP764's?
Hey guys,
Planning a VNT swap in my MK3 and wanted some advice. I already have a used VNT-15 in good condition and PP764's waiting to go in. In addition to these, here's my hypothetical list of mods:
-EGR delete (already done)
-upgraded intake piping
-upgraded intercooler piping, PD130 or 150 intake
-2.5 inch downpipe with magnaflow cat and 2.5 inch exhaust
-some sort of lift pump (Walbro FRB-11 looks good)
-RC tuning
I was talking to Jeff at TDIFest and he said that PP520's would probably be better for the task. I can trade for them, that's no problem, but it's always possible that I'll get a bigger turbo in the future and an FMIC. So my question is should I install the 764's alongside this project? I'm not sure how much Jeff can modify the tune for the nozzles in my specific case, but I'm looking to have minimal/no smoke if possible. Can I do it with this setup? Jeff currently has an ECU of mine and is going to work on it and send it out so I can swap it in when doing the conversion; I'd like to be able to discuss all options with him.
Blake | Custom alignments available in Southwest GTA
2004 Grey TDI Sport Edition | 270,000 km | Grey | 6 speed ERF transmission with upgraded shifter fork & LSD | R32 18 Aristos | PP Downpipe, 2.5 SS exhaust with Magnaflow muffler, rest of mods in profile
Whitedog's no start thread - very useful!
blizzak is offline   Reply With Quote
Old September 8th, 2009, 02:35   #2
cog
yes most certainly put the pp764s in . if you have any thoughts even of further tuning and bigger turbos.
i was in the same position a year or two ago and went for the pp520s because they would work best . and at that point i thought that chip and injectors was as far as i wanted to go .
but now i find my self with a whole host of mods including stage 3 clutch and vnt 17 turbo . and if id have gone for pp764s to begin with i wouldnt be underfueling the 17 now.
bigger injectors can always be turned down with the tune but smaller injectors cannot push more than there max .
at worst you will find the pp764s on stock turbo a little more smokey and a little worse on fuel .
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
cog is offline   Reply With Quote
Old September 8th, 2009, 08:13   #3
blizzak
Hey, thanks for the response. The 764s are quite a bit larger though. What I am interested to know is will a PD130/150 intake and upgraded intercooler piping make a difference? Would it make a difference with 520s, 764s, or both? I need an downpipe/cat/exhaust when the VNT goes in. But I could easily go either way and never get an FMIC or a bigger turbo than the VNT-15, and thus I think that PP520's would be almost perfect. Lift pump is going in for sure, I think it'll do a good job helping my almost 200k mile injection pump.
Old September 8th, 2009, 09:10   #4
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Running a 15 in this application is edgy, so you definitely want to run the Pd130 intake and improved intercooler piping. Also a larger intercooler and a serious exhaust. Jeff can tame the fuel of the PP764's so that isnt an issue. The turbo inlet should also be a decent size and not kinked in any way. Use a Mk4 MAF minimum. Lift pump is a must on a MK3. If you elect to not put in a larger intercooler you will smoke much more and make less power than you otherwise would. The PP520's are good for 180whp and better with 11mm pump head.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old September 8th, 2009, 10:32   #5
kooyajerms
grocery getter
kooyajerms's Avatar
Chris, why the move to the mk4 maf? First time I've noticed this suggestion. Any difference in plugs when doing so?
BTW how's the 2056 coming?
kooyajerms is offline   Reply With Quote
Old September 8th, 2009, 10:46   #6
blizzak
Chill, you da man! I really enjoyed your talk at the fest. I think you've helped me make a decision; PP520's are my best bet.
While I'll keep the PD130 intake and larger intercooler as ideas for the future, it's not something I'd like to incur expense for right now. I'll try intercooler cleaning and we'll see how my intake is doing as well (did the cleaning a while back). Larger intercooler piping will be done as the VNT will need something custom anyways, and I'll modify the intake (piping, at the least) in some fashion so it is larger and smoother.
Regarding the MK4 MAF, I never thought much about my MAF. It's a pierburg and has never given me any apparent trouble. I didn't think that a MK4 MAF was compatible with a MK3 but I guess it's all in the programming, eh? Are the harnesses the same? What are the advantages of a MK4 MAF? Does it give higher airflow readings, such that you can have more control? Obviously I want the one from an ALH, right? (PN Bosch 0 281 002 757 or 038 906 461C)
I'm going to use a new style N75 (not one from the early A4's cause they are more expensive) and modify the harness. Not much more to say!
Old September 8th, 2009, 10:52   #7
jsrmonster
Veteran Member - TDIClub Enthusiast
jsrmonster's Avatar
Blake we need to talk.
Jeff
15 Golf SW DSG, 00Jetta 6spd race, 99.5Jetta Rocket ARL-PD150 6spd 2260, 2003.5 5.9L Cummins QCLB 4x4 Blue Monster, 00Passat1.8T, other tdi's: 97J, 98J, 99.5J2x, 00-C5 6spd - EFILive, HPTuner, Diablo Sport!
Never argue with an idiot.They will just bring you down to their level and beat you with experience.
The beatings will continue until the morale improves!
Good judgement comes from experience, and experience comes from bad judgement !
"DIESEL TUNING PROFESSIONAL" 1-5-3-6-2-4=;-)
jsrmonster is offline   Reply With Quote
Old September 8th, 2009, 10:54   #8
blizzak
calling!
Old September 8th, 2009, 11:02   #9
blizzak
Thanks Jeff, good talking to you.
Old September 8th, 2009, 11:11   #10
jsrmonster
jsrmonster's Avatar
You will be very happy with 150hp/250ftlbs AFN setup, low smoke car that is capable of 60mpgs.
The vnt15 will give good snap and throttle response with RC3+ and pp520's, and should last many miles.
Jeff ;-)
Old September 8th, 2009, 11:58   #11
mrchill
mrchill's Avatar
Indeed! The Mk4 MAF allows finer fuel control and less smoke. The connectors are different, but Jeff can give you a diagram to swap them. B the way, my car can get(has gotten) 55 mpg with this setup.
Old September 8th, 2009, 18:42   #12
Edgy, Chris? How so? I'm considering this setup and would only do it with a better than stock downpipe (I'd probably stick with the 2" size that's in the car, but obviously it would have to be swapped out to fit the new turbo), CAT delete, PD130 intake, and an A4 MAF. And I'd probably run Sprint 520s unless I upgraded the intercooler. Even then I think the car would smoke a bit because of more primitive fueling and electronics.
Chill and I differ a bit on this: I like less fuel, less torque, more top end, as little smoke as possible. Right now my A3 is running RC3+ with the stock turbo and nozzles, lift pump, 2" exhaust, no cat. It's really nice.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Page generated in 0.12781 seconds with 9 queries
[Output: 114.32 Kb. compressed to 96.94 Kb. by saving 17.38 Kb. (15.20%)]
