Old September 5th, 2009, 09:59   #1
alkmisc
Fuel Economy: 42-61 mpg, avg low to mid 50s
Default How to Replace ALH Serpentine Belt Tensioner and Idler Pulley (with photos)
There are a bunch of threads talking about replacing the serpentine belt tensioner and idler pulley but mostly without pictures so I thought I'd add some.
There was a noticeable rough sound from the passenger side of the engine compartment after my car met a large pothole. Taking off the timing belt and spinning the various pulleys, the idler pulley had a noticeable grittiness that didn't belong there. I though I'd replace the tensioner too at 127K miles while I was there.
The tools you will need:
16 mm box wrench (notice two wrenches hooked together)
13 mm socket (may need regular and deep)
extension
6 mm hex bit (the shorter the better)
torque wrench
ratchet
flathead screwdriver
pliers
tools for removing skid plate/belly pan and side skirt
**** Torque value to remember - 18 ft-lbs ****
Here is the new tensioner and idler pulley. It even comes with a new hat for the pulley!
1. Put the car on ramps, chock wheels, remove the skid plate/belly pan and passenger side side skirt. Open the hood (do I need to say this?).
2. Here is the tensioner from above and where the serpentine belt runs over the PS pulley.
3. The tour from below - take note of the routing of the belt:
(1) crankshaft pulley
(2) AC pulley - may want to check tightness of 14 mm nut while there
(3) idler pulley
(4) power steering pump pulley
(5) alternator pulley
(6) tensioner and pulley
4. Remove the serpentine belt by placing the 16 mm box wrench onto the "nut" on the tensioner and pushing back towards the firewall (the direction of the arrow) to relieve the tension and slip the belt off the pulleys. I used a second wrench on the end of the first for extra leverage and to reduce the chance of pinching myself. (If you're only replacing the serpentine belt, just reverse the steps from here and you're done.)
5. Pop the "hat" off the idler pulley with a screwdriver and loosen the bolt with a 6 mm hex wrench. If you use a socketed bit like I did, use the shortest one you have since clearance is tight. I had to loosen with the bit, remove the bit, then take the screw out by hand, then remove the pulley.
6. Remove the 3x 13 mm bolts holding the tensioner (arrows in photo). It may help to remove the upper hose leading to the EGR to give yourself some wiggle room.
7. Here are the 3 bolts for the tensioner and the bolt for the idler pulley. Note that one of the tensioner bolts is longer. That goes through the hole in the thicker part of the casting that you will see.
8. Here are the new and old tensioners. The new one is folded like it is probably to reduce shipping size. You will need to remove the pin (yellow circle) at some point so that it will actually work. I recommend doing this before trying to put it in. Put your box wrench on the nut and set that end against the ground, push down a little, and pull the pin out with pliers - easier done than described.
9. Reinstall in reverse order. No pictures here because it looks just like before except with newer shiny parts. Torque the tensioner bolts to 18 ft-lbs. The idler pulley bolt is also 18 ft-lbs but I had trouble getting a torque wrench in there so tightened it to what felt tight enough. I'll recheck the tightness later down to road to make sure it hasn't loosened. Remember to put the new hat back over the idler pulley to keep things clean, to. When putting the belt back on, you'll notice the new tensioner will be stiffer than the old one.
10. Reinstall side skirt and skid plate/belly pan.
The postmortem showed that the tensioner pulley was freewheeling much more than the new one. The old idler pulley was definitely due for replacement, too. It sounded gritty spinning in hand and had noticeable side-to-side play and it rattled loudly if you shook it gently.
alkmisc is offline   Reply With Quote
Old September 5th, 2009, 10:00   #2
alkmisc
Hey, and I'm no longer a newbie!
Old September 5th, 2009, 11:42   #3
VWMod
TDI(s): Golf
Thank you!!! I'll be following these instructions now to replace mine
VWMod is offline   Reply With Quote
Old September 5th, 2009, 12:42   #4
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
Thumbs up
thanks for doing this! you da man
this is another helpful reference to add:
(post #33 from this thread: http://forums.tdiclub.com/showthread.php?t=99516)
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old September 5th, 2009, 12:47   #5
VWMod
TDI(s): Golf
one question how do i tighten them to 18ft-lbs?
Old September 5th, 2009, 12:49   #6
Sip'n Diesel
Veteran Newbie
http://www.myturbodiesel.com/1000q/torquewrenchFAQ.htm
Old September 5th, 2009, 12:50   #7
VWMod
TDI(s): Golf
And i cant seem to get the pin out :-x
Old September 5th, 2009, 12:52   #8
VWMod
TDI(s): Golf
Originally Posted by Sip'n Diesel
I dont have a tourqe wrench at the moment.. what would be the appropriate thing to do at this moment? considering i dont have the luxary of my second car now...
Old September 5th, 2009, 14:55   #9
alkmisc
Put the 16 mm box wrench on the nut of the tensioner so that it's parallel to and on the same side as the black piston thing (the whole thing will look like a "U"). Put the whole thing so that the box wrench and pulley (one side of the U) are on the ground (basically stand the U on it's side) and push down on the piston (the other side of the U) towards the ground while pulling the pin out at the same time. It's hard to describe but once you can figure it out it makes sense. This is the one picture I should have taken but forgot.
Old September 14th, 2009, 06:57   #10
nh nam vet
Last week I swapped out the Bosch 120 amp alternator in our 2002 ALH Jetta. The serpentine belt tensioner is indeed secured with three 13 mm hex head bolts, but on our engine they are all different lengths! The correct installation combination is......top to bottom: short, medium and long. I hope this saves somebody a little time.
nh nam vet is offline   Reply With Quote
Old October 20th, 2009, 18:43   #11
spoilsport
spoilsport's Avatar
Fuel Economy: 53/46/40
Thumbs up thanks!
Thanks for the nice tip. This worked like a charm!
2000 Golf 5M -RC2/3 Sprint 520 Kerma 1" LIFT!!
spoilsport is offline   Reply With Quote
Old November 12th, 2009, 10:58   #12
gtveloce
Fuel Economy: 43, 40.5 with Yakima
Thanks alkmisc!
Nice to have some picture for reference. I am going to do this tomorrow!
gtveloce is offline   Reply With Quote
Old June 24th, 2012, 05:06   #13
reyemtm
Incorrect...to change the belt you need to REMOVE the idler pulley. Also, there are at least three different belts available for the Jetta ALH so make sure to get the right one there is a ten mm difference in the belt sizes. And they are a tiiiight fit. And you need to seat the belt on theadd and alt and then reinstall the pulley and route the rest of the belt.
reyemtm is offline   Reply With Quote
Old June 25th, 2012, 10:41   #14
alkmisc
I was able to remove and install the belt with all pulleys in place. It is a small space to work. You need to take the tension off the tensioner before putting on or taking off the belt and you need to remove the belt to change the idler (unless someone else is taking the tension off the tensioner for you). I've only seen one belt being sold for the ALH by the US online sellers.
2000 Jetta GL TDI (01M->02M)
1999 Chevy K1500 Suburban 6.5 TD
Old July 7th, 2012, 14:16   #15
pcjr
Fuel Economy: 42/38/33
Does anyone know the size of the bolt that holds the round bar to the assembly. The bolt in missing on my 2002 TDI.
pcjr is offline   Reply With Quote
Page generated in 0.16467 seconds with 9 queries
[Output: 124.34 Kb. compressed to 103.90 Kb. by saving 20.43 Kb. (16.43%)]
