Old August 31st, 2009, 20:27   #1
DirtyDzl
Default The Evry mod how to.
I can't believe there isn't more clear information on this, i spent about an hour searching and ended up doing it the logical way to me (knowing basic electronics).
The mod really is simple, hopefully this clears up any confusion from the many other threads because i was indeed confused with them until i thought for a while on it.
This shows exactly where the injector harness is and what part of the wires to splice (though either side of the plug will work, this side is more accessible). Wires 2 and 3 are connected with a 1k (what i used) resistor. Wire 2 is the first pin on one side of the harness, pin 3 is second from the other side. The wires are labeled on the harness (which is awesome).
Here's the wiring, i personally cut the wires, put the resistor wiring in there and twisted it all back together and electrical taped it up. Basically you take the wires apart, splice them back together, but add the resistor's wiring.
For "tuning". You turn the resistance down until the motor starts idling rough, then turn it back up until it smooths. I played it safe and went to smooth and turned a bit more.
And the disclaimer part, you **** up your car, not me, i'm not liable for damages.
Any questions will be happily answered.
DirtyDzl is offline   Reply With Quote
Old August 31st, 2009, 21:27   #2
thunderwolf
What engine is this for and what does it do?
thunderwolf is offline   Reply With Quote
Old August 31st, 2009, 21:37   #3
DirtyDzl
I'm not sure the engine code, works on the 1.9 TDIs from 1998 to 2005 (correct me if i'm wrong, i'm very new to diesels). It tricks the computer in to dumping more fuel in (which on a diesel is like pushing the pedal through the floor). Results surprised the hell out of me...but i also have bigger injectors.
Old September 1st, 2009, 19:34   #4
twentyeight
twentyeight's Avatar
TDI(s): 1Z & ALH
Fuel Economy: Personal Best: 57mpg
As I understand it:
There's a sensor that senses the position of the quantity adjuster. Think of it as a syringe pumping up and down. If you extrapolate for time, you get a (more or less) sine wave.
The computer reads this wave to check itself on how much fuel to inject. What you are doing with this mod is tying the signal low through a resistor. The lower the resistor, the more of the voltage (and thus amplitude) of the wave 'leaks' out.
A shorter wave is interpreted by the computer as a need to move that syringe plunger further, resulting in more fuel.
Honestly, it's a lot more fun with a switch and potentiometer in cockpit somewhere . It's telling to witness the change when the switch is flipped.
Watch out for the smoke, though. Mine absolutely dumps the stuff.
twentyeight is offline   Reply With Quote
Old September 2nd, 2009, 07:51   #5
DirtyDzl
Originally Posted by twentyeight
As I understand it:
Yeah, i put mine on a switch, thing smoked everywhere and i got horrible fuel mileage. It's fun to flip the switch on while you're flooring it to feel the actual gains.
Old September 2nd, 2009, 08:06   #6
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
If you don't under stand the information given in this thread...
http://forums.tdiclub.com/showthread...=evry+mod+beer
Don't do it. I created a circuit that indicates if it's on. I built it, tested it and tossed it. Walk away.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old September 2nd, 2009, 20:10   #7
DirtyDzl
Explain?
And BTW, by resistor i meant a potentiometer so you can dial it around until you find the sweet spot.
Old September 2nd, 2009, 21:16   #8
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Its a crappy and ineffective mod that could potentially damage your engine.
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old September 2nd, 2009, 21:27   #9
traxterXT
traxterXT's Avatar
TDI(s): jetta 2005
Fuel Economy: 4.6L/100km
well i would not say ineffective but you need more air. my GF car i run the evrymod over a 500ohm and a 1k pot. i got R520 injectors, a KKK K14 running 22PSI and 4GPH meth injection. I'm still tweaking the car but i got no chip. i will run the dyno in few weeks
05 Jetta TDI PD KermaTDI tuned
99 Jetta TDI(wreck)
96 Golf GL 2L ABA soon TDI(with pics)
91 Jetta TD God bless Diesel
traxterXT is offline   Reply With Quote
Old September 10th, 2009, 21:47   #10
puffsmokeonya
puffsmokeonya's Avatar
TDI(s): 99 bug 5 spd
if you do this to a switch just for some smoke action do you need the resistor? 99 bug TDI 5spd
puffsmokeonya is offline   Reply With Quote
Old September 11th, 2009, 07:16   #11
DirtyDzl
Yes, the resistor is required. I don't know what would happen without it, but i'm sure it wouldn't be good.
Old September 11th, 2009, 10:08   #12
Pugsley
TDI(s): 2003 Beetle
I think the reason nobody fully explains this is because if you can't figure out how to do it with the limited info you probably won't understand the risk your taking when using this mod.
I did this mod awhile back, only use it when I see a big pickup or some asshat is riding my bumper.
Pugsley is offline   Reply With Quote
Old September 12th, 2009, 20:29   #13
puffsmokeonya
thats what i want it for. is bumper riding idiots. or show off what size resistor?
99 bug TDI 5 Spd
99 dodge CTD 5Spd 2door LWB
2004 dodge CTD Auto 4door SWB
Old September 12th, 2009, 21:31   #14
DirtyDzl
I used a 1k pot.
Old September 13th, 2009, 07:52   #15
puffsmokeonya
thats what i was thinkin. is there a hp bump? or is it just smoke?
99 bug TDI 5 Spd
Page generated in 0.15640 seconds with 9 queries
[Output: 123.48 Kb. compressed to 102.49 Kb. by saving 20.98 Kb. (16.99%)]
