Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old August 31st, 2009, 19:24   #1
scooperhsd
Default September 2009 Mileage thread
This is a month by month competition. Every time you make an entry it will be added up and recorded together according to the fuel type and car/year you are driving.
THIS IS NOT an individual tank competition (or a partial tank competition for that matter).
Entries will be accepted until OCT 5th 2009, but remember, report tanks FILLED IN SEPTEMBER.
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
You are allowed to put more than one fill up in a post, so long as each fill up conforms to format.
MPG: (optional since I will calculate it automatically anyway)
(anything else you would like to add)
Hint on entering your data - after the colon ( ":") put a space.
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please noted this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
Biodiesel use equal to, or more than B20, will be indicated in GREEN.
ULSD / LSD / D2 = normal petroleum based diesel
Also please note if it's winterized
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Posts not in format will not be tallied / corrected. If I have to do any editing to get your post in format (or to get the correct name), it will not be counted. Feel free to correct your own posts to get them in format.
Please do not go back and add additional fillups to a post. Multiple fillups per post is fine as long as all fillups are in format. If the driver name is not the same as your post name - this will be considered "Not in format" and will not be counted. Only exceptions would be "and spouse" etc.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old September 1st, 2009, 12:33   #2
path23dv
TDI(s): 2009 Jetta
Driver: path23dv
Miles: 655
Gallons: 13.86
Model Year: 2009
Model: Jetta Sedan
Tranny: 6M
Fuel type: ULSD
path23dv is offline   Reply With Quote
Old September 2nd, 2009, 05:33   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Driver: Bonjonbart
Miles: 433.4
Gallons: 11.934
Model Year: 2005
Model: B5.5V
Tranny: 5A
Fuel Type: B100
Svante Arrhenius 1896
Old September 2nd, 2009, 13:04   #4
bakerinva
Driver: bakerinva
Miles: 719.4
Gallons: 14.67
Model Year: 2006.5
Model: Jetta Sedan
Tranny: 5M
Fuel type: ULSD
2006 "Special Edition" TDI White/Beige, 5-Speed. My 4th diesel VW!!! Others included: 1979 Diesel Rabbit - RIP, 1991 Diesel Jetta - Sold!, 2003 TDI Jetta Wagon - Sold!, 2006.5 TDI Jetta - Will drive into ground....
bakerinva is offline   Reply With Quote
Old September 3rd, 2009, 04:46   #5
Harden
Harden's Avatar
Fuel Economy: 41.0 Average right now
Driver: Harden
Miles: 598.9
Gallons: 14.140
Model Year: 2009
Model: Jetta TDI (Sedan)
Tranny: 6M
Fuel Type: ULSD
MPG: 42.4
Harden 2009 Volkswagen Jetta TDI (Built 10/08), 6M, Black, Sunroof, 17" Avignon Wheels
Mods: DRL's Disabled Keyfob Window Control FrostHeater
Coming Soon: DG Panzer Skid Plate, DG Sigma 6 Short Shift Kit, Blue Tinted Aspherical Mirrors, E-MFA Additional Gauges
Harden is offline   Reply With Quote
Old September 4th, 2009, 09:53   #6
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
Driver: Ruking
Miles: 311
Gallons: 6.1
Model Year: 2003
Tranny: 5 M
Fuel Type: ULSD +Primrose 405C
MPG: 50.98 (perpetual italian tune mode)
ruking is offline   Reply With Quote
Old September 4th, 2009, 13:00   #7
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Driver: Bob_Fout
Miles: 686.5
Gallons: 13.887
Model Year: 2003
Model: Jetta GLS
Tranny: 5M
Fuel Type: ULSD
MPG: 49.4
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old September 4th, 2009, 13:13   #8
volmaniac
volmaniac's Avatar
TDI(s): 02 Golf GLS
Fuel Economy: around 50 mpg
Driver: volmaniac, mrs. volmaniac, volmaniac iii
Miles: 796.7
Gallons: 16.34
Model Year: 2002
Model: golf gls
Tranny: 5M
Fuel Type: D2
2002 gls golf
Originally Posted by foxracer1 View Post
Wars are fought over religion, money, land, and brand of injectors for a TDI
volmaniac is offline   Reply With Quote
Old September 5th, 2009, 18:10   #9
scooperhsd
Sept 5
Driver: scooperhsd
Miles: 576.9
Gallons: 14.7
Model Year: 2000
Model: NB
Tranny: 4A
Fuel Type: ULSD
Tank MPG - 39.2449
Old September 5th, 2009, 18:17   #10
ObscuredByClouds
ObscuredByClouds's Avatar
Location: A required field called Location is missing or has an invalid value.
Driver: ObscuredByClouds
Miles: 720
Gallons: 14.3
Model Year: 2003
Model: Jetta TDI Sedan
Tranny: 5M
Fuel Type: ULSD
50.3 MPG, approx 70% Highway, 30% City
ObscuredByClouds is offline   Reply With Quote
Old September 6th, 2009, 08:19   #11
jhutton1
Fuel Economy: 42 mpg combined
Driver: jhutton1
Miles: 562.9
Gallons: 13.707
Model Year: 2009
Model: Jetta Sedan
Tranny: 6M
Fuel Type: ULSD
MPG: 41.1
2009 Jetta Sedan TDI, 6 speed Manual, Reflex Silver, Sunroof.
jhutton1 is offline   Reply With Quote
Old September 6th, 2009, 14:48   #12
cswaner@peoplepc.com
Fuel Economy: To soon to know
Driver: Cswaner
Miles: 456 First Tank on new TDI
Gallons: 12.73
Model Year: 2010
Model: Jetta Sedan
Tranny: 6M
Fuel Type: ULSC
MPG: 35.82
cswaner@peoplepc.com is offline   Reply With Quote
Old September 7th, 2009, 08:47   #13
ScooterJim
Driver: Scooter Jim
Miles:416
Gallons: 9.87
Model Year: 2009
Model: Sportwagen
Tranny: DSG
Fuel Type: ULSD
Miles per Gallon: 42.15
Total Mileage 19,810
ScooterJim is offline   Reply With Quote
Old September 7th, 2009, 10:47   #14
schoonerj
Driver: Schoonerj
Miles: 624.6
Gallons: 13.98
Model Year: 2009
Model: Jetta SW
Tranny: 6Sp Manual
Fuel Type: ULSD
schoonerj is offline   Reply With Quote
Old September 7th, 2009, 15:43   #15
Mike in Anchorage
Mike in Anchorage's Avatar
Driver: Mike in Anchorage
Miles: 472.5
Gallons: 12.725
Model Year: 2009
Model: JSW
Tranny: DSG
Fuel Type: ULSD
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Page generated in 0.21330 seconds with 9 queries
[Output: 125.36 Kb. compressed to 103.98 Kb. by saving 21.38 Kb. (17.06%)]
