Old August 31st, 2009, 05:22   #1
cod
cod's Avatar
TDI(s): 2006 Jetta
Default Hammond Mod ??
Hi,
I have been reading the hard to start when hot thread and see the Hammond Mod talkd about.
Where is the link explaining how to do this mod ?
I tried to find it .
2006 Jetta TDI 132000 KM
2003 Harley Road King Police 30700 KM
2004 Volvo XC 70 236000 KM
cod is offline   Reply With Quote
Old August 31st, 2009, 05:59   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
hammer mod. AND NO!!!!!!!!! DO NOT DO IT!!!!!
You need someone with a vagcom and experience to do this. You could possibly REALLLLLLLLLLY damage the pump. It will not help your 99's start. They need a reflash of the ECU to solve this problem.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old August 31st, 2009, 08:22   #3
cod
cod's Avatar
TDI(s): 2006 Jetta
Old August 31st, 2009, 14:00   #4
jcrews
jcrews's Avatar
TDI(s): All gone
Hamman mod
I don't care for the idea, which is why I replaced the ECM with one that has the correct starting program (RC2).
The idea is simple - disconnect the engine coolant temperature signal when the key is in the start position.
The correct starting program is also in ECM coding 1 automatic transmission. It will work fine for the most part, but there will be a TCM missing signal code (which I don't remember seeing the MIL illuminate for) and the clutch switch will not work. This means some fuel damping software is bypassed and the cruise control won't disable when the clutch is pressed. The starting interlock will still work though.
jcrews is offline   Reply With Quote
Old August 31st, 2009, 14:11   #5
werewolf
werewolf's Avatar
Its the Hamm's mod!
You drink a 12-pack of Hamm's beer and fall underneath your TDI to find
your skid plate gone!
Bob:
Jetta's 03 & 04 TDI (GLS)
Golf 04 TDI (GL)
New Beetle 03 TDI (GLS) & Looking!
werewolf is offline   Reply With Quote
Old August 31st, 2009, 16:33   #6
jasonTDI
jasonTDI's Avatar
That's the up there don'tchaknow hamms mod!
Old December 31st, 2017, 10:56   #7
Seb500
Does this Hammond mod actually work.
I have a 54 plate Golf 2.0 TDI & a 55 plate Golf TDI the 55 plate is superb with cold and hot starting but the 54 plate takes about 1.5-2 secs to start because of this so called ecu software problem common on 99.5% of 2.0 TDI's
I know a new Bosch Battery will cure the poor hot start as well as a New Starter but only temporary as these parts wear with age surely a relay will last 3 times longer.
I know the ecu needs to see 250rpm from crank sensor before it will squirt fuel in injectors hence with a slower worn starter it might only be 220rpm not enough for a hot start.
Or am I best to forget the relay hammond job and just get a new Starter?
As the Bosch Battery is only 2 years old!!
Seb500 is offline   Reply With Quote
Old December 31st, 2017, 11:10   #8
UhOh
UhOh's Avatar
VE pump in a 2.0L?
Old December 31st, 2017, 11:56   #9
Mongler98
if your carefull you can hammer mod no issue. it helps 100% to have VAG-COM with vcds though. what engine code?
Old December 31st, 2017, 12:03   #10
GoFaster
Moderator at Large
"54 plate" doesn't mean anything to the rest of the world ... we need what model year the car is at a minimum, and preferably what engine it has.
I THINK your engine is a 16-valve "pumpe-duse", which does not have a separate external "Bosch VE" fuel injection pump, and if that's the case, the "hammer" mod is not applicable, not possible, can't be done ... because it only applies to the older engines with an external Bosch VE rotary distributor injection pump.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old December 31st, 2017, 13:16   #11
Tdijarhead
Ok I always thought google was my friend, but even she couldn’t tell me what a 54 or 55 plate Golf is. So, what is it.
Tdijarhead is offline   Reply With Quote
Old December 31st, 2017, 15:41   #12
UhOh
UhOh's Avatar
Wait! What is a HAMMOND Mod?
Maybe made a wrong turn and wanted to go here:
http://www.electronickeyboardservice.com/
Old December 31st, 2017, 17:18   #13
jettawreck
jettawreck's Avatar
Now I'm really confused and thrown back into 2009 just for good measure!?
2004 Cadillac SLS (wife's)
Old December 31st, 2017, 17:25   #14
Owain@malonetuning
[/URL]
I think it's some kind of Italian tune up with questionable consequences?
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old December 31st, 2017, 17:40   #15
UhOh
UhOh's Avatar
So, Owain, are you saying that it increases smoke?
Page generated in 0.15333 seconds with 9 queries
[Output: 124.93 Kb. compressed to 103.35 Kb. by saving 21.58 Kb. (17.28%)]
