Old August 29th, 2009, 05:29   #1
SFL_TDI
SFL_TDI's Avatar
Post mud flap / splash guard installation on MK5 Sportwagen
Greetings All.
I recently purchased a 2009 TDI Jetta Sportwagen. I was planning on installing OEM mud flaps on the vehicle.
The rear set (part # 1K9075101 - Golf Variant / Jetta Wagon 2007 =>) fits my vehicle perfectly.
The flaps in the front set (part # 1K0075111 - Golf 2004 =>), are very ill fitting. According to the instructions and mounting points, they look like they are the correct part and should fit just fine. But, even when mounted properly according to diagram, they flex away from the quarter panel and look as if they were made for another vehicle. I'm wondering if despite what I have read online, these front flaps are made only for MK4 vehicles, or if there is a newer part number that I should be trying to track down.
If anyone has any info on the proper front mud flaps for the 2009 TDI Jetta Sportwagen, I'd be grateful.
Regards,
Ryan
SFL_TDI is offline   Reply With Quote
Old August 29th, 2009, 05:53   #2
HeAvYfUeL
HeAvYfUeL's Avatar
Fuel Economy: Fuelly signature --->
Hi,
I fitted the front mud flaps of an Mk4 on mine. Looks OEM. Just needed a rivet nut.
2009 Jetta Wagon Comfortline DSG ESP build 03/09 Graphite Blue
History:
2006 Golf TDI GLS/1992 Jetta 2.slow GL
HeAvYfUeL is offline   Reply With Quote
Old August 29th, 2009, 17:54   #3
tomo366
TDI Lifer
tomo366's Avatar
http://www.worldimpex.com/item_detail.html?sku=250984
The gave you the wrong part!!
These are the correct parts.......
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old August 30th, 2009, 05:21   #4
Ol'Rattler
Ol'Rattler's Avatar
Also, I think they redesigned the sheet metal on the A5 bodies at the lower front doors for 07 or 08 and later to keep ice and slush from accumulating and bending the lower front doors. Might make a difference on how the front mud flaps fit.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 8th, 2009, 18:01   #5
SFL_TDI
SFL_TDI's Avatar
Thanks for the replies guys. I will check out the alternate part number.
Regards,
Ryan
Page generated in 0.14011 seconds with 9 queries
[Output: 65.84 Kb. compressed to 57.80 Kb. by saving 8.04 Kb. (12.21%)]
