Old August 13th, 2009, 05:39   #1
cleaver
cleaver's Avatar
Default varying boost - what to log
I have issues with my boost at WOT. It bounces from 6-20psi...I just replaced the VNT actuator and all hoses.
I am going to use VCDS to get some more info, what should I log?
Diagnosing Limp Mode
IMO, best place to buy VW parts in Canada: contact Brian @ http://www3.ns.sympatico.ca/roseland/
cleaver is offline   Reply With Quote
Old August 13th, 2009, 08:30   #2
Curious Chris
Fuel Economy: 47/42/38
Log MAF specified, MAF Actual, MAP specified, MAP actual, and throttle position. Then warm engine, 3rd gear, 100% throttle, 2000-5000 rpm, repeat 3 or 4 times.
I am guessing either boost system leak or screwy MAF. I have seen screwy MAF's that bounce all over causing boost to jump up and down. I also had a OMI break a bracket that gave me an intermittent leak and cause my boost to meander. The 100% throttle eliminates adaptation.
Wavetrac LSD, PP520's with RC4, VNT17/22, Flying Kasper FMIC 3" OMI, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Page generated in 0.09551 seconds with 9 queries
[Output: 47.32 Kb. compressed to 43.28 Kb. by saving 4.04 Kb. (8.54%)]
