Old August 21st, 2009, 10:36   #61
QuickWrite
Interesting. So why are the US ratings so much lower, or sometimes not even stated? Liability?
Originally Posted by newguy
Oh, and YES my wife drives the motorhome!
As for the passat, I was overweight on the tongue, but I kept a very close watch on it.
The Airbags made a HUGE difference and for anyone that tow's I would highly recommend them.
Take a look here at the towing ratings...
http://www.volkswagen.co.uk/#/new/pa...ngines/towing/
http://www.volkswagen.co.uk/#/new/go...ngines/towing/
The new Jetta Wagon with a TDI is good for 1399KG with a manual transmission! 3084lbs for us 'mericans
Cheers!
2005 Jetta GLS TDI wagon, 5-speed
QuickWrite is offline   Reply With Quote
Old August 21st, 2009, 12:32   #62
PapaBare
Fuel Economy: 43 MPG CDN
Default Show what you tow
This is what is behind our 2005 Jetta TDI Wagon most weekends in the warmer weather.
PapaBare is offline   Reply With Quote
Old August 21st, 2009, 12:59   #63
QuickWrite
Papa: Wow, that's a pretty big load too. How much does all that weigh? What hitch are you using and do you have stock rear suspension?
Old August 21st, 2009, 13:13   #64
BadMonKey
BadMonKey's Avatar
Naaa... lack of demand...
There is a lot more to the towing capacity of vehicale then just being able to pull it. I had a friend killed by one these "Darwin Awards" when a pickup was pulling a skid steer down the highway someone cut him off causing the pickup to lock up his brakes and snap the rear axle the trailer took out 7 other cars between the trailer and skid steer. The driver claimed he was within the limits of the truck but was actually 400lbs over the trucks limits due to his 3 passengers which he didn't account for.
All airbags do is level the tow vehicle and keep the rear axle from bottoming out. They don't increase the vehicle capacity and they don't put the weight back on the front wheels. When your bottoming out the suspension of any vehicale its your 1st clue that over the limits. Most cars are designed to carry a full load that's passengers and all their crap. If you towing a trailer with all the seats full and all their crap plus a 1000lb trailer you are certainly over what it was designed to do.
BadMonKey is offline   Reply With Quote
Old August 21st, 2009, 13:13   #65
PapaBare
1. Weight? I need to run it out to the DOT weigh scales after hours. The trailer is rated at a GVW of 2190lb. (It does get loaded with much more occasionaly though. I do try to keep those occassions to less than 3800lb and short distances)
2. The hitch is a Hidden Hitch.
3. Still a stock supension.
I do have the ball mount (that goes into the receiver) going up __/-- and I purchased a long neck 2" ball and filled the gap between the bottom of the ball and the ball mount with 3/4" washers. This raises the top of the ball high enough that the trailer pulls flatter. Balancing the load so that there is little weight on the hitch really helps also. I can lift the trailer tongue easily.
The quads are listed as 571 lb and 755 lb dry. Ten gallons of fuel is about 100 lb. The mud is weightless. kind of like eating a Brat at the ball game (Very little or no Calories)
Fuel economy does drop to about 37-38 MPG though and even less when against a strong wind. (My buddy feels good when he gets 21 MPG with his new Tacoma Sport and no load)
Old August 21st, 2009, 14:19   #66
QuickWrite
I had an experience like that once. My wife and I were moving cross-country with our 1970 Chevy Blazer, pulling our 1989 Subaru Justy on a U-Haul flatbed car trailer. Both the Blazer and the Justy were loaded with stuff. I began to notice the rear suspension on the Blazer was bottoming out: the bump stops on the axle were getting smashed and I didn't like the way it was handling. Halfway along the trip, I found another U-Haul and swapped the car trailer for a tow-dolly, which made the trip a lot less stressful! It wasn't the weight of the car that was so bad, but the heavy U-Haul trailer and the massive tongue load it placed on my truck.
Old August 21st, 2009, 18:23   #67
GoFaster
Moderator at Large
Different standards, different laws, different driver training, different expectations of the vehicle ...
In europe, all but the lightest trailers have trailer brakes, and they use what we call "surge brakes" that apply trailer braking in proportion to what the tow vehicle is doing, unlike the electric brakes that are pretty much on or off (not in proportion to tow vehicle braking).
Vehicles towing trailers are restricted to a lower speed on motorways.
In europe, towing trailers with cars has been standard practice for decades, so a lot of vehicles are designed with hitch attachment in mind. The hitches have different weight classification ranges from North American hitches.
But yeah, a lot of it is market demand (or lack thereof) and fear of liability. In europe, larger cars are expected to have trailer towing capability, and if you as a manufacturer don't offer it, sales numbers will suffer! Nobody drives pickup trucks over there ...
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old August 21st, 2009, 21:33   #68
Golden Dub
Dub Life: the only way to live!
Golden Dub's Avatar
TDI(s): 2012 Golf
Default towed home
Big brother picks up little brother. Blown turbo, stock ecu on a 3bar map, didnt know any better. lasted not even a day, it sounded awesome just before it blew up, I felt like a plane, it sounded like a 747 jet airliner was driving down the street, it was hilarious, I was thinking wow this is so cool, then all of the sudden POP!! then all this some and no more turbo noise! uh oh jet airliner on fire!! I thought my exhaust popped off and it was burning my sidewall, then I realized no turbo noise and the car is going nowhere, must be the turbo.
Golden Dub is offline   Reply With Quote
Old August 21st, 2009, 22:37   #69
newguy
Fuel Economy: too new to tell
Wow, I think you are overloaded on that single axle trailer, aren't you? LOL
SSSSSSSStefan
'09 Jetta SportWagon 6 speed Manual - White
'05 Passat Wagon GLS TDI - White, Wifemobile
'02 Itasca Horizon 39' diesel pusher motorhome
'06 Chev 2500HD Duramax/Allison pickup truck! Lotsa mods now... EFILive tuned...
'66 Pontiac GTO - www.driven-1.com
My Photo Gallery
For the most important thing you will ever do... click below
www.claybe.com
newguy is offline   Reply With Quote
Old August 21st, 2009, 22:52   #70
Golden Dub
Golden Dub's Avatar
TDI(s): 2012 Golf
yeah by like 300 pounds, not to bad, 3500 pound axels. It was an emergency! thats why I have the ass end jacked up with a jack while it sat in front of the house while I cleared out the garage. you can see it in the picture. Why is everyone so crazy when it comes to towing. People towing big stuff with little cars, people towing big things on little trailers, what is wrong with all these people??
Old August 21st, 2009, 23:13   #71
newguy
oh, now I see the jack!
it's all good man - I was just having fun poking at you... I got poked at plenty for towing my **massive** popup camper with my VW...
I was pushing the limit, but I took it easy.
SSSSSSSStefan
My Photo Gallery
www.claybe.com
Old August 21st, 2009, 23:52   #72
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
No offense intended, but I've seen some of your other posts, and I think you need to read/learn some more about these engines before you just start bolting stuff on. There is a prescription for power on these cars that is well-established. There is nothing wrong with innovation, and there is likely room for some more TDI innovation...but you need to start with the established methods first and then build on that. A 3 bar map comes after a bigger turbo and with new tuning to make it work right so that things don't go boom. As you found out...a 3 bar map on stock tuning and a stock turbo is not going to work for long.
Good luck.
ALH TB Tool Rental Trusted TDI Mechanics
2000 NB 3 pedal mod RC3 PP520's Eurojet SMIC SBC 3 2.5" side exit straight pipe2" lift
TDICADDGUY is offline   Reply With Quote
Old August 22nd, 2009, 00:35   #73
Golden Dub
Golden Dub's Avatar
TDI(s): 2012 Golf
thats funny, I didnt just install the 3 bar. It was part of the egr delete, 3"exhaust, Fmic install all at once. Better for me anyways because I get to buy something better! I will have a rocket by the time I am done blowing things up.
Old August 30th, 2009, 17:34   #74
Keven
2000 Jetta TDI - 5pd with 190k miles
2002 Jetta TDI Wagon - Auto with 149k miles - Mom's
2004 Jetta TDI - 5 spd with 140k miles - Sister's
Keven is offline   Reply With Quote
Old August 30th, 2009, 20:50   #75
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Default Y'all already know I'm nuts, but...
The hitch...
What I pull with it...
This one was easy... 100 miles of highway...
This one was a little heavier.. Me.. In the pouring rain.. With a 2001 Taurus on the dolly..
I'll try to find the pictures of the F-150 I had on the dolly.. I've also towed my Camaro to the dragstrip numerous times with the TDI. Mostly off highway hilly terrain. The camaro weighs 3500lbs on a light day.. The only issue I ever have with the dolly is slow speed turning, like in a parking lot or on dirt.. The dolly only turns so far, then it starts to push the back of the car sideways if you need to turn sharper than the dolly wants to turn..
Stopping power was fine..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Page generated in 0.18025 seconds with 9 queries
[Output: 134.38 Kb. compressed to 112.51 Kb. by saving 21.87 Kb. (16.28%)]
