Old August 15th, 2009, 09:12   #31
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Originally Posted by burpod
you're the only one in here quibbling and NOBODY IS LISTENING
Forgive me for noting that people are posting non tdi's on a tdi forum. I mean. What was I thinking.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old August 15th, 2009, 09:27   #32
KROUT
persona non grata
I like cheese and crackers with my wine.
KROUT is offline   Reply With Quote
Old August 15th, 2009, 09:36   #33
NB_TDi
NB_TDi's Avatar
Sweet gift idea!
Old August 15th, 2009, 10:10   #34
KROUT
persona non grata
Sweet gift idea!
U get me a hitch for my tdi so I can post some tow pics and I will send you some cheese and wine. lol
Old August 15th, 2009, 12:53   #35
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Hello,
My two loads when I moved back to my home from DC:
The combined weight was just under 4500-lbs for each trip. I stayed off the interstate. Here are some of my other loads:
http://www.stealthtdi.com/Albums/Tra...tos/index.html
Take Care,
Scott
| .M y . S t a g e . 2 . G T I . |
| Facebook | YouTube | Fuelly |
Stealth TDI is offline   Reply With Quote
Old August 17th, 2009, 00:07   #36
Pugsley
TDI(s): 2003 Beetle
Originally Posted by Whitbread
Not a tdi, but at least it's diesel . This is what I pulled with my bone stock 6.5TD 4 weeks ago on a trip to haspin acres in indiana. One samurai, one 81 J10 with an atv in the bed, and 2 atvs in my bed. She did it, but wasn't very happy.... Anything over 60mph and it would kick out of overdrive haha.
You go there too! I would like to tow my sand rail behind my NB, but I am not sure if the car can do it. I would have to build a custom T trailer to keep the weight off the the ball. I think on the NB you can only have like 200 pounds on the ball.
Pugsley is offline   Reply With Quote
Old August 17th, 2009, 10:35   #37
QuickWrite
Wanders: Nice teardrop! We were thinking of going with one of those but are now considering a modified small cargo trailer for camping/hauling.
Stealth: When you say 'combined 4500 lb.', do you mean the trailer + its contents, or the car + trailer/contents? As I recall, your Jetta is lowered, right? Any problems bottoming out the rear suspension with a load like that?
2005 Jetta GLS TDI wagon, 5-speed
QuickWrite is offline   Reply With Quote
Old August 17th, 2009, 10:52   #38
Stealth TDI
Hello,
"Combined" means the trailer/contents + the car/contents. However, that did not include ME, another 200-lbs. Odds are the trailer alone was about 1500 lbs.
No problem with bottoming out the suspension. I do bump the hitch in driveways if I'm not careful. I take them at an angle and do fine. It's the very lowest point which hits, just forward of the safety chain connections:
But I can bump that with adults in the back seat and no trailer at all as well. Perhaps that'll improve once I replace my suspension (soon).
Later,
Scott
Old August 17th, 2009, 16:34   #39
TDikook
TDikook's Avatar
Fuel Economy: ~44+
Default does this count
A Golf behind a Golf. I do not recommend it. but it worked just fine. towed it from Pensacola,Fl to JAX,Fl. Scott was laughing when we pulled in. the drive was nervewracking but it can be done. it definately knocked the mpg down a bunch.
'06 Golf RC4+, Cat fuel filter, Passat Oil cooler, VNT 17/22, PD 150 intake, PD 150 injectors, 02M
TDikook is offline   Reply With Quote
Old August 17th, 2009, 18:38   #40
wanders
wanders's Avatar
Fuel Economy: AVG 48 MPG Best- 53 MPG
Thanks! We are really happy with it.
'01 Jetta GLS 5-speed Baltic Green/tan
CD changer, Ventectomy, 5 brake light mod, EGR Mod, VAG-COM,PP 520's, Boostvalve, Koni Yellows,
Boost, Oil Temp Oil Pressure Gauges,G60/VR6 Clutch
wanders is offline   Reply With Quote
Old August 18th, 2009, 21:09   #41
odinsjetta
Here is my 4' x 8' trailer that I use to haul my tools, etc.
Jeff
2003 Jetta GLS TDI Wagon
odinsjetta is offline   Reply With Quote
Old August 18th, 2009, 21:31   #42
TDI_Convert
Fuel Economy: 50 mpg average
Triton aluminum trailer. 81" between the rails, 12' bed. 44 bales of hay.
While the car stopped fine with this load, I do have electric brakes on the trailer, and a brake controller in the car for heavier loads.... The load seemed heavier when I brought back all the parts for a 1200 sq. ft. dropped ceiling in the basement, incl. a dozen 4 bulb fluorescent 4' lights.
TDI Convert
2003 Jetta Wagon GLS 5 sp. Reflex Silver/Black Leather plus a few mods. See profile for list.
TDI_Convert is offline   Reply With Quote
Old August 18th, 2009, 21:37   #43
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
TDI Convert - any more details on the trailer?
Axle rating
Tires
Brakes
Weight of empty trailer
etc?
Do you have a picture from front/back/angle?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old August 19th, 2009, 13:00   #44
QuickWrite
Axle rating
Tires
Brakes
etc?
Ditto that. I'd like to know your estimated tongue weights and what kind of hitch you're using, also.
Old August 19th, 2009, 19:04   #45
TDI_Convert
It's a Triton AUT1282. Here's the specs:
http://www.tritontrailers.com/produc...specifications
It's a Hidden Hitch, I put a piece of 1/4" thick steel plate where the bolts are supposed to go thru the sheet metal in the well for the spare tire, and bolted that piece of steel to the sheetmetal with a couple more bolts & a fishplate on the outside. I tossed the wimpy plate that came with the hitch. As for tongue wt, I figure it's too much if I can't pick it up. They're electric brakes, not surge brakes.
It does take getting used to since it's a wee bit wider than the car!
I don't tow with the standard ramp, I made a couple of ramps that are removable so I don't have a bunch of wind drag going down the road.
Before I left, I moved the cooler to the rear of the trailer. We just took the trailer off of the truck we drove to Wyoming and threw it on the wagon. Too much tongue wt. for the VW. One of the mods on the car is brakes from an Audi TT Roadster, thanks to BleachedBora.
TDI Convert
Page generated in 0.11670 seconds with 9 queries
[Output: 131.90 Kb. compressed to 110.35 Kb. by saving 21.55 Kb. (16.34%)]
