Old August 13th, 2009, 13:10   #16
vw4life
vw4life's Avatar
Fuel Economy: 7.4 L/100km 75% city (~32 MPG US)
\\\ David /// 2005 B5.5V TDI Stonehenge Grey - Manual Headlamp Leveling - Aspherical Mirrors - Ventectomy trouble? - Fuel Economy - Euro trailer hitch: towing, install, safety chains, towing, wiring, euro bike rack! +Factory de-tooef's, Airlift
vw4life is offline   Reply With Quote
Old August 13th, 2009, 14:12   #17
QuickWrite
I started the post to see what TDI's are towing, but I don't mind the other stuff. Just for the record.
2005 Jetta GLS TDI wagon, 5-speed
QuickWrite is offline   Reply With Quote
Old August 13th, 2009, 15:16   #18
QuickWrite
No sugar for your Cheerios this morning, Krout?
Old August 13th, 2009, 16:10   #19
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Originally Posted by KROUT
Cause the title does not sat what do you tow with your tdi. It says what do you tow. lol
I'm curious what other people are towing with their TDI's, so post up some picks of your TDI-trailer rig!
Dep de deeer
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old August 14th, 2009, 07:25   #20
Mike96ZJ
Mike96ZJ's Avatar
TDI(s): 2002 Jetta
Before:
After:
And occasionally the motorcycle makes it back there:
2002 Jetta - 17/22, PP764 Stage 2, 3 Bar map, Alligator tuned, Custom mounted X-Monitor, DG Racepipe, Southbend Stage 3, DG Panzer Plate, TDI Parts OMI, Ventectomy, and mufflerectomy. - RIP
2002 Jetta - 17/22, PP764 Stage 2, 3 Bar MAP, Malone Tuned, New South Boost/EGT Gauges, DG Racepipe, PD150 TIP, DG Panzer Plate.
Mike96ZJ is offline   Reply With Quote
Old August 14th, 2009, 07:30   #21
chimmike
TDI(s): 05.5 A5
driving a toyota to tow a jeep? WEAK! Should be towing a yota with the yota! lol.
chimmike is offline   Reply With Quote
Old August 14th, 2009, 07:33   #22
Mike96ZJ
Mike96ZJ's Avatar
TDI(s): 2002 Jetta
If I could afford my dream rig, I would have a buggy with the same powertrain as the tow rig.
Old August 14th, 2009, 11:12   #23
irvingj
Fuel Economy: 05 Jetta wgn: 40-49 mpg
Tow this with an 05 wagon. 1800lbs. Hard above 55; it'll maintain 65+, but only with a generous allowance of turbo & RPMs!
Oops. Got to look at posting pics again....
'05 Jetta TDI PD wgn 5-spd (his)
'04 Toyota Matrix 4WD (hers)
'75 Honda CB360, '76 Honda XL250, '71 Honda CB100
'82 Yamaha Virago 750
'94 Subaru Loyale wgn 4WD (given away 6/07)
'82 Peugeot 504D wagon (R.I.P.)
irvingj is offline   Reply With Quote
Old August 14th, 2009, 11:16   #24
irvingj
http://pics.tdiclub.com/data/uploads...B_7:1:09-2.JPG
There! Think I got it that time!
Old August 14th, 2009, 11:25   #25
QuickWrite
That's really cool, another T@b trailer tower! What brand of hitches are you T@b towers using?
Old August 14th, 2009, 17:50   #26
bsalbrig
bsalbrig's Avatar
TDI(s): 2010 Golf
Have to put mine in here too.
I pull this with my Jetta, it is a 21' Hobie sport cruiser. The car is about 12" narrower than the inner edges of the hull.
2010 TDI Golf
xenon, sunroof, dynaudio, cw package
2012 6.7 F250
bsalbrig is offline   Reply With Quote
Old August 14th, 2009, 19:45   #27
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
Default Iluv2tow
The 3x6 utility trailer. Great for hauling brush, garbage, appliances, lawn tractors (with the sides off):
The tent trailer. Sleeps four. May become a 6x8 utility trailer one day:
The pop up, belongs to my father-in-law and we have taken it camping once a year for the past three years. Took it to the trucks scales fully loaded its single axle was carrying 1900lbs, the tongue weighed 300lbs on the bathroom scale:
- Paul
2001 VW Golf Naturally Aspirated Direct Injection Diesel 5MT 620,000 km
With 1.5" lift / Valeo G60/VR6 SMF /
Sprint 520's / RC3 / sweet turbo delete
The NARFmobile blog / push button ignition / thrustmaster shifter / http://youtube.com/narfblast
Last edited by NarfBLAST; September 20th, 2016 at 18:30. Reason: updated links to photos
NarfBLAST is offline   Reply With Quote
Old August 14th, 2009, 19:49   #28
burpod
teh stallionz!!1
burpod's Avatar
Originally Posted by NB_TDi
So when you read a book's title, you say you read the book?
you're the only one in here quibbling and NOBODY IS LISTENING
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old August 15th, 2009, 04:14   #29
irvingj
Wow- how many T@B towers are there out there? We just got back from a 10-day trip in New Brunswick (no, I didn't get the 30-lb salmon that went for my wet fly on the Miramichi. ) and we only saw one other T@B in about 1600 miles! Sure drew a crowd wherever we went with it; most people had never seen one before. "Its so CUTE!!" Yeah, OK.
I have a Reese "Hidden Hitch" that bolts, with reinforcement plates, to the sides & bottom of the spare tire well, as well as to one of the shipping tie-downs. I tossed out all the hardware it came with and replaced all with stainless steel bolts, nuts, washers & locks. Also greased exposed threads and sprayed with undercoat. Our northern New England winters can be tough on ANY exposed hardware. So far, so good.
Old August 15th, 2009, 05:10   #30
wanders
wanders's Avatar
Fuel Economy: AVG 48 MPG Best- 53 MPG
We tow this teardrop trailer. The trailer is somewhere around 900 lb, I think. Haven't actually weighed it.
'01 Jetta GLS 5-speed Baltic Green/tan
CD changer, Ventectomy, 5 brake light mod, EGR Mod, VAG-COM,PP 520's, Boostvalve, Koni Yellows,
Boost, Oil Temp Oil Pressure Gauges,G60/VR6 Clutch
wanders is offline   Reply With Quote
Page generated in 0.15820 seconds with 9 queries
[Output: 131.34 Kb. compressed to 109.21 Kb. by saving 22.13 Kb. (16.85%)]
