Old August 8th, 2009, 20:07   #1
TDIinTexas
TDIinTexas's Avatar
Default gtb2260vk build: stateside, aiming for the masses
Alright guys here we go!
I have spent many months in preparation for this build, and I am very excited to finally be making some progress with a grinder and welder.
I am developing a turbo system for the masses. When I mean system, I am trying to provide a bolt-on big turbo, with all the trimmings for us. For a long time I have been under the impression that we as a niche group are capable of using larger turbos, to take us to a higher standard of performance TDI.
I want to see more large turbo TDIs running around here. I think the biggest hurdle has been sourcing manifolds and other plumbing parts reliably. That is what I hope to accomplish.
I am going to focus on Audi's gtb2260vk. Many guys in Europe are using this turbo with great results.... Its time for some of them here stateside! It does require modification to convert it to vacuum actuation, from the factory it is electronically controlled.
So without delay, lets get started.
Car: 2002 Jetta TDI
Here is what I have come up with in CAD. You can't see the hood, firewall, K-frame, or steering. It is in the drawing, just turned off for the picture. All should fit.
The manifold is 1.5" .065 stainless tube with all equal volume runners. Flanges are .5" stainless. The flange on the block is port matched to the exhaust gasket, and extra material given to accommodate the welds for the pipe. Intake manifold will have the plenum up by the injection pump, I'm trying to get the volume and length of the SDI manifold, still needs minor touches. The turbo drain sits perpendicular to the ground, without clocking the exhaust side at all (both the compressor and exhaust sides of this turbo can be clocked in any position 360 degrees for those who do not know this). The actuator bracket is incorporated into the oil drain flange, making it dependent to the chra and nothing else . There are 2 actuators in the picture, but it is the one on the left that is correct, the one on the right shows the offset, you'll understand later when it is pictured mounted. Exhaust is 3" with v-band clamps. The flex is shown in the picture.
I have played with the manifold alot, and have ideas for a smaller volume version in the future.
I started work today, going with the intentions of following my drawings as carefully as possible. Here is what I got done:
I want to thank Steve Glover for lending me a bad head to mock-up on. I build a frame that holds it at the 12.5 degrees that my engine sits at in the car.
Here are some goodies:
and I welded up the collector too..
This system is going to consist of: gtb2260vk (new, not re-mann), stainless exhaust and aluminum intake manifold, 3" aluminum turbo inlet pipe, stainless oil supply and drain lines, 3" stainless downpipe, intercooler & piping. This should be everything unique to installing this turbo. We will see what the future holds for supplying tuning. I am working on a website and vendor status.
What do you think?
David
His:02 Jetta TDI, GTB2260VKLR, Fun stuff to come...
TDIinTexas is offline   Reply With Quote
Old August 8th, 2009, 20:27   #2
scubagli
scubagli's Avatar
Fuel Economy: MID 40'S IN THE MKII, HIGH 30'S IN THE MKIII
umm wow...that collector looks clean. can't wait to see more.
scubagli is offline   Reply With Quote
Old August 8th, 2009, 21:52   #3
79TA7.6
79TA7.6's Avatar
Location: Live: Wilbur/Creston; Work: Moses Lake Washington
David, where did you get that rendering of the block and head? Did you mock those up from your bad head? What are you using for your cad? I use SolidWorks everyday at work. I love to see others work with 3D renderings.
Keep up the goos work. Looks like you will have a great end product.
2003 Jetta 5 Speed 301K miles. Malone stage 3. Titan 502 big hole injectors. VNT17 turbo. BuzzKen 2.5" down pipe. Ventectomy, EGR and cooler delete, Euro Switch, Home made custom HID.
79TA7.6 is offline   Reply With Quote
Old August 9th, 2009, 02:44   #4
TDikook
TDikook's Avatar
Fuel Economy: ~44+
interesting... cant wait to see more...
and I know this is a crappy question. but do you have a ballpark(high side estimate) of what the finished price would be... so I can save up and budget it...
'06 Golf RC4+, Cat fuel filter, Passat Oil cooler, VNT 17/22, PD 150 intake, PD 150 injectors, 02M
TDikook is offline   Reply With Quote
Old August 9th, 2009, 03:02   #5
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Wow, the primaries look exceptionally long.
Edit: be that as it may, I'm not criticizing. However, may I suggest you consider welding in a divider plate to separate the exhaust pulses between the 1-4 and 2-3 cylinders.
Old August 9th, 2009, 03:57   #6
ryanp
ryanp's Avatar
Looks good! subscribed!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old August 9th, 2009, 04:40   #7
TDIinTexas
TDIinTexas's Avatar
I started from scratch, I rendered the head from measurements taken from the head on the stand. Its Autocad2009, that is what I work with all day at work. I wish they would let me play with Solidworks or Catia.
David
Old August 9th, 2009, 04:45   #8
TDIinTexas
TDIinTexas's Avatar
Yes, I battled with the pulses, and could not come up with a clean, cost efficient, equal volume primary setup. Instead I went with what I could get, equal volume. I work with cnc tube benders, and have layed this out to be bent, after the prototyping, this will drop labor time.
I could weld in the divider, which means I need to cut that collector open , we'll see. Probably.
David
Old August 9th, 2009, 04:47   #9
TDIinTexas
TDIinTexas's Avatar
We will have to see how much labor is invested. It will be in the ballpark of similar kits for gassers.
David
Old August 9th, 2009, 04:47   #10
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
No no, don't do that then. Maybe something to consider in another header build.
Old August 9th, 2009, 09:29   #11
79TA7.6
79TA7.6's Avatar
David
I think that is the first rendering from AutoCAD that I have seen. It looks pretty good. I have not heard very many good things from people who have worked with AutoCAD and other 3D CAD programs. They say AC is harder to work with. But that is a different thread topic. Keep up the good work. Hope everything goes good with this project.
Old August 9th, 2009, 10:07   #12
Rub87
for the easyness I work with Inventor, and for finite elements NX with Nastran solver.. Catia with Fluent pluging can do nice trings for CFD but I don't have the skill
as for the intake manifold, I'd make it so that it also fit a PD head, so it will not go to low in the IP area, this will be better for many people with more recent cars
with the exh manifold like that does it have enough clearance for the driveshaft?
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old August 9th, 2009, 10:53   #13
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Good idea Ruben. If possible, the design would be best suited for both ALH and BEW customers...
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old August 9th, 2009, 11:03   #14
TDIinTexas
TDIinTexas's Avatar
Yes, good point, as I am trying to accommodate both ALH's and PD's with this. I need to measure up a PD head with valve cover on.
Will the SDI manifold fit the PD's, or better yet... Is it made for the PD's? I don't know alot about the SDI.
David
Old August 9th, 2009, 11:12   #15
Rub87
the plastic sdi one I don't think it will fit PD, altough there are PD sdi's in caddy IIRC but don't know what intake they use
the actuator like you have it there is very handy to adjust
Page generated in 0.19336 seconds with 9 queries
[Output: 136.03 Kb. compressed to 113.84 Kb. by saving 22.19 Kb. (16.31%)]
