Old August 3rd, 2009, 18:21   #1
PoPimOr
Default 01 Jetta Transmission rebuild?
Hi,
My parents have a 2001 Jetta TDI with an automatic transmission and 170k miles approximately. I don't have one right now, but do run my 84 Mercedes diesel on veg oil...
Anyway, basically the local dealer is ridiculously expensive, and can't identify the problem with their car which is the same situation with other local shops. They just took the car to a dealer in Chicago on their way to a trip.
Recently they went to a local mechanic and found out another mechanic (possibly the dealer) had filled their transmission with too much fluid. They were in because the transmission was not shifting correctly in the higher gears. Well now the car does not engage correctly between the lower gears or into first sometimes.
Usually this is when cold.
The fluid is clean, not burnt, no metal shavings.
I have driven it a bit and there is sometimes a clunk when shifting between gears which has been a problem for a while.
They just drove to Chicago and it worked fine, but was warmed up.
At this point the dealer is likely going to tell them the valve body is going bad based on what they said to my parents when they dropped the car off, which is quite possible, and is going to say this costs $2,500 or so to fix.
This won't even give them a new transmission...
Who has good rebuilds for the Auto TDI's for this car that one can order, or will do a good job somewhere in MI, preferably in the Holland or Traverse city area, rebuilding the transmission?
Outside of that.
Could this be an engine speed sensor problem? Vacuum problem?
I seem to remember something about the transmission shifts being adjusted based ion driving style.
I do not have time to put the transmission in myself.
The car is not throwing any codes.
They are not interested in a swap to a manual, even though this is much less expensive, because of my dad's arthritis...
Opinions, thoughts?
Thank you
PoPimOr is offline   Reply With Quote
Old August 4th, 2009, 06:37   #2
mike944
TDI(s): 2004 Jetta
Fuel Economy: 44-46
It's going to cost way more than $2500 to fix. Don't let them waste money on a valve body. That won't fix the problem.
The problem is: The transmission is a piece of sh!t. 170K is actually pretty decent. You should consider yourself lucky. The only long-term fix that won't fall apart (without changing to a 5-speed) is a VW remanufactured transmission, roughly $4500. That will get you another 100k-200K
I have 190K on my automatic, and it's almost done. I researched this topic for quite a while, and the only 'permanent' answer i came up with is the 5-speed conversion. if medical issues require them to keep the automatic, just be aware, it's going to be very, very expensive. They might be better off selling the car, and replacing it with something else that has a more solid transmission.
did the "local mechanic" (second paragraph) know the proper way to check the fluid? The transmission has to be only slightly warm. if they drove it there, and he immediately checked it, the fluid would have been way too hot, and it would appear to be overfilled. It would need to sit and cool for several hours before checking.
Everything you mentioned are all classic symptoms of the 01M trans going bad. Unfortunately, they're looking at an expensive bill here to keep the automatic.
Mike
'04 Jetta TDI
'92 Porsche 968
Formerly '01 Jetta TDI (Sold at 306k)
mike944 is offline   Reply With Quote
Old August 4th, 2009, 06:52   #3
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Click here: http://www.importperformancetrans.com
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old August 4th, 2009, 07:19   #4
vwcampin
vwcampin's Avatar
You might want to talk to CoolAirVW and read some of his posts:
http://forums.tdiclub.com/member.php?u=38678
02 Jetta GLS TDI, Auto, 212k, W8 mod, Audi TT Pedals, Euro Switch, '04 Tails, rear fog, Homelink, GLX Lights w/ fogs, VW 17" Siata wheels, TDI Heater, PP357's, Venectomy, modified Greasecar kit
86 Vanagon Syncro Westy Weekender, 07 Passat Wagon 4Motion
vwcampin is offline   Reply With Quote
Old August 4th, 2009, 07:42   #5
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
As Mike944 stated, the trans fluid needs to be "warm" and must be checked with a VCDS scan to get the accurate temp reading to verify level. There is no dip stick to measure the level with.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old June 7th, 2010, 16:35   #6
mikevil
my auto tranny in this 2001 jeta tdi 4speed auto just went to very exspensive to repair got 255000 on it ,anyway would like more info on this conversion to change it to a 5 speed is it worth it whats invovled ?thanks
mikevil is offline   Reply With Quote
Old June 7th, 2010, 17:31   #7
toadz1
banned
TDI(s): A4
Do a search on Kill the wabbit auto by Alpha Senor.
toadz1 is offline   Reply With Quote
Page generated in 0.13436 seconds with 9 queries
[Output: 77.34 Kb. compressed to 66.71 Kb. by saving 10.64 Kb. (13.75%)]
