Old July 30th, 2009, 09:57   #1
mattmann58
Default speaker replacement on 2009 jetta tdi
Has anyone replaced their speakers with quality after market components on their 2009 tdi? I can't seem to find any good info on speaker sizes/quality makes/etc... Would love some help. Thanks.
mattmann58 is offline   Reply With Quote
Old July 30th, 2009, 10:07   #2
Ol'Rattler
Ol'Rattler's Avatar
If it's like an 06, I don't think there is anything that is a direct replacement for some of the locations. However, Crutchfields is probably your best bet.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old July 30th, 2009, 10:16   #3
mattmann58
Default Thanks for your reply
I tried crtchfield and they basically didn't know exactly what if any replacement speakers were available. Of course, they may mean they didn't have anything themselves that could replace the 2009 speakers.
Old July 30th, 2009, 10:36   #4
Ol'Rattler
Ol'Rattler's Avatar
Ya, that's the downside of having a car that is not mainstream. On my 06, I found that the speakers do sound better after they have a few hours on them.......................
Being that the 06 and 09 are actually the same car except for the engine, ask about options for an 06.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old July 30th, 2009, 10:36   #5
karlthev
karlthev's Avatar
TDI(s): 2009
The sound in my '09 TDI is dismal as well....possibly the only aspect of the car in which I am disappointed...wish I'd gotten the upgrade when I bought it...
Karl
Previous--'64 Beetle, '70 Beetle, '95 Jetta, '98 Jetta, '09 Jetta TDI, 2017 Jetta gasser
karlthev is offline   Reply With Quote
Old July 30th, 2009, 11:32   #6
mattmann58
Does your jetta have the ten speaker set up? That's what's in the 2009.
Old July 30th, 2009, 12:07   #7
Ol'Rattler
Ol'Rattler's Avatar
According to Bentleys, my 06 has 3 speakers in each front door and 2 speakers in each rear door (10 total) for both the standard and premium systems. The premium sound system has a control module (amp) under the drivers seat.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old August 2nd, 2009, 11:15   #8
ffcoog
be careful! if its anything like my 2006 jetta you may run into some problems.
first of all (and these are based on my 2006), the front door speaker screwhole diameter sizes are 8" woofer, (i think) 3 1/2 mid range and the tweeter in the sail panel. the speaker size in the woofer location is 6 1/2 but the casing around the speaker fills in the rest.
you'll have to drill out the rivets in the woofer location to get them out. not terribly difficult, but it is a little time consuming.
now, if you have a monsoon system you may run into some trouble. the monsoon speakers are 2 ohm, whereas most aftermarket speakers are 4 ohm. so there will be some loss of power if you have 4 ohm aftermarkets with the monsoon amp.
as much as i love crutchfield, they were not much help with the jetta. last time i checked they only recommend replacing the 3 1/2 mid range (thats the only sing they say will fit...). its a little difficult to find 3 way components in general, though.
if you want to just use a single coaxial 2-way speaker in the woofer location, you'll have to re-wire the system to bypass the stock crossover. audio specialist quoted me about $150 to do this, though your mileage may vary on that.
i'm certainly not an expert and my experiences replacing the front stocks for my 2006 have been somewhat of a nightmare - not sure why VW made this setup so complicated.
ffcoog is offline   Reply With Quote
Old August 2nd, 2009, 11:28   #9
ffcoog
also, be aware that the available depth for the front door woofer is very small - you only have about a 1" clearance. depth extenders/spacers will likely be necessary
Old September 21st, 2009, 08:15   #10
Jetta Knight
Any suggestions for replacing the rear door speakers on the 06? I decided long ago to live with the crap factory system and I don't really want to mess with it, but the rear left side tweeter has a raspy sound to it and I thought while I was at it may be a good idea to upgrade the rear speakers entirely. It appears that the tweeter ohm rating may be a problem. Yes?
2001 Jetta TDI Automatc, Black (Sold)
2006 Jetta DSG TDI, Pkg1, Plat Gray (Sold)
2009 JSW DSG TDI, Black (Sold)
2013 Passat SE DSG TDI, Tungsten Silver
2016 Subaru Outback Limited
Jetta Knight is offline   Reply With Quote
Old May 15th, 2011, 14:35   #11
HKS
TDI(s): 2009 Jetta
Default 2009 Bad Radio front Speakers
The sound is so bad that I believe the crossover network wring is switched. One dealer put in 2 radios. Another dealer put is a crosover network, drivers side, and then gave up, stating that the front speaker will sound different than the back ones. Yea, but not like the difference in night and day.
I believe there are a few thousand 2009 Jettas with bad factory wiring.
HKS
Karl
HKS is offline   Reply With Quote
Old May 15th, 2011, 14:51   #12
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
see http://forums.tdiclub.com/showthread...light=dynaudio for Dynaudio OEM DSP amp and
http://furmanka.blogspot.com/2009/12...-speakers.html for the speaker part numbers
this may help also http://www.big-partycentral.de/Bilde...a_3C_Build.pdf
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old June 7th, 2015, 11:22   #13
squeedle
squeedle's Avatar
Fuel Economy: Yes, please.
The problem is the crossovers. They are fairly easily replaced with off the shelf stuff. I have completed this mod, as has a friend of mine. Night and day improvement.
http://forums.tdiclub.com/showthread.php?t=429757
Crossover replacement DIY
squeedle is offline   Reply With Quote
Page generated in 0.16104 seconds with 9 queries
[Output: 110.06 Kb. compressed to 91.30 Kb. by saving 18.76 Kb. (17.05%)]
