| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
July 23rd, 2009, 19:06
#1
P0226 Code - Throttle Position Sensor?
So I was in like 2nd gear going around a corner tonight and suddenly the go pedal stopped working and I got a CEL. I would push it down with no result. I limped the car home at idle and looked up/cleared the code with scangauge: P0226. My search indicated that this was the throttle position sensor. The question is: what do i do?
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
July 23rd, 2009, 21:15
#2
I have had the same problem intermitently with my NB. Mine only happens sometimes in heavy rain or very wet conditions. If it sits overnite its fine the next day. The scangauge is always hooked up in my car and the tps shows that it is working even when i get the code. In my car the cruise will still work if i clear the cell and get the car past 29mph. I have limped home this way, you would not want to be behind me in town when it happens.
01Golf(200k), 2013 Mustang V6, 2010 JSW White Gold (sold), Y2k Bettle(400k sold),.
July 23rd, 2009, 21:23
#3
Very good to know. It has been raining like crazy here. I will start her up tomorrow and see what she does. Thanks!
2001 Golf TDI 5 spd
July 24th, 2009, 02:57
#4
I had the same problem, was stranded in traffic one day. Limped home, took the throttle control ( gas Pedal) off , "3 10mm nuts" ounce I had it off "4 phillips screws" and cleaned the contacts with contact cleaner bent the contacts slightly to ensure they make proper contact, that was months ago no further problems
2003 Jetta Wagon TDI evo skid plate (467,000)
2000 Jetta Sedan TDI (440200)
2001 Jetta Sedan 2.0L (191,400)
1986 Mercedes 190D (210,000 kms)
July 24th, 2009, 07:11
#5
A night of drying out seemed to do the trick. She's running fine now. I might dig in and clean those contacts anyways.
2001 Golf TDI 5 spd
July 24th, 2009, 09:48
#6
Wayne, what car was it that gave u the problem? Was it wet when it happened? I have had my pedal apart
(looked like new inside). Also cleaned all conectors and grounds, thought my problem was cured, but months later it came back.
July 24th, 2009, 17:40
#7
Fuel Economy: 55 summer 50 winter
It does seem once you start having problems with the TPS that replacing it is the best and most expensive way to go. what happens next time it goes out on you and you have to have to towed back home or shop. Mine went bad 6 years ago, just coded and stopped working for a but. I had the VCDS with me and pulled the code and went ahead and bought a new one ( they were a lot cheaper then). The second time it did leave me setting but having the spare in the trunk I just swapped them out and never more a problem. You could find a used one I guess on car-parts.com and carry it for a spare or just get AAA plus (towing in 100 miles to your place of choice)
2003 Jetta 216 injectors, race pipe, OMI, 2.5 cat back pipe, Sachs power clutch,Lightweight fly wheel,Rocketchip 3.0,Dieselgeek race pipe,Borla SS exhaust,Dieselgeek Intercooler pipes,Pierburg MAF,EU cluster with LED Boost gauge,,
Ventectomy,Alientech window,Old Navy ccv filter,Catch can,Dieselgeek short shifter,ATE power slot rotors,Porterfield pads,Shine suspension,Shine rear sway bar,TT pedals & foot rest,Cat fuel filter 2 micron,Alum skid plate,Euro headlights and switch,5 Brake light mod.
July 24th, 2009, 18:08
#8
Interesting. Can the TPS be bought individually, or do you have to get the entire pedal assembly? Does anyone have the part number(s)?
2001 Golf TDI 5 spd
July 25th, 2009, 05:06
#9
The car was 2000 Jetta TDI and I hear that water has been known to come in from the wiring harness to the plug that connects the throttle pos sensor. really all it is a a huge volume control , a potentiometer, in any case slight bend of the contacts as well as cleaning with contact spray worked fine for me....
October 28th, 2009, 17:39
#10
The car was 2000 Jetta TDI and I hear that water has been known to come in from the wiring harness to the plug that connects the throttle pos sensor. ....
Good call on this one Wayne. It appears to be the problem in my NB. I only have the problem in the rain and the next day it is fine.
--- I have come to the conclusion that when driving at highway speeds with the sun roof up 1 click, recirc off and the fan off, my TPS will fail within 40 to 90 miles. If i leave the roof closed and turn the fan on i have no problems.
--- I have not actually checked the wires to see if they are wet.
--- My theory is that with the roof open and the fan off there is negative pressure in the cabin causing water to be drawn into the wires and making the TPS fail. Roof closed fan on keep cabin under positive pressure.
December 19th, 2010, 15:39
#11
Fuel Economy: 44 - 52 mpg
Is no one using electrical contact grease???
My SGII still reads 99 and 0.
Has anyone Re-calibrated the Tps???
01 Golf TDI, 160K mi, 2R520, Malone Tune, 2052, 3" DP-Cat-exhaust, SBC Stage 2, Stealth EGR, Carter p4070 lift pump, Ebay FMIC, 11mm, 3" TIP, WaveTrac, DIY Rear Sway, Custom Intake Mani, Dog-bone Shimmed, 4"snorkel, Stanadyne FM100 5 mic, T-belt tools & VCDS,
December 20th, 2010, 07:47
#12
I pulled my TPS apart last nite. Indede there was moisture on top of the houseing. It could easially come in from the fire wall penetration where I have run my EGT/ Boost gauge through.
The Heyes manual is not accurate. It shows a 2x3 connector. Mine is a 1 x 6 pin connector.
The OHM test did not show any continuity.
Does anyone have a bentley for this.
Also note when taking appart the TPS there is some adjustment. I did not match mark mine because i didnt notice it untill i was putting it back together.
I cleaned it w/ electrical cleaner.
I did the best i could by lining up the screw marks.
I wanted to silicone the gasket but this would not allow adjustment so I put electrical grease around the gasket.
The manual does not specify how to set up the adjustment. I remember on my subaru the TPS gets adjusted on the car checking continuity between 2 pins.
I put it back in. Did the calibration by flooring it for 1 min w/ the key turned to accessory.
It appears to have resolved it self.
SGII still shows 99 & 0
December 23rd, 2010, 00:55
#14
My 01 golf wasn't exactly user friendly. I didn't have any swing with a regular ratchet and was wishing for my air ratchet.
Thats after removing the plastic dash pieces left and right of the steering wheel and the plastic supporting the dash. Its all plastic clips and torx screws.
I think I put it back together with a swivel and 2 long extensions.
I dont know what they changed in 03.
December 31st, 2010, 10:16
#15
My TPS went out this week on my 99.5 and been having issues with it for 2 years now. Got a new hella pedal assembly and installed today. After install I started the motor and it went straight to 1500rpm, I hit the pedal and rpms dropped back down and I still have no throttle response. Does the sensor need to be programmed or what? Please help. Just had a baby last week and this is our only transportation.
99.5 green jetta TDI GLS, 5sp, 220k on body, 90k on 2nd motor('03), evo skid plate, DG race pipe, Sachs VR6 clutch with 17.5 balanced flywheel, bilstein tc's
