honda_vtec2
Scenario:
Driving back from Nova Scotia. My 1997 1z TDI Jetta decided to have some issues. I pulled into a parking area to rest my eyes for a few hours. After 4 hours, I turned the ignition and the car cranked like it would start but didn't. It was cranking pretty fast. Started was cranking the engine, engine was turning over.
I was able to jump start the car. It got me back to Toronto. 10 hour drive. I even stopped for lunch for an hour. The car started up like normal. Problem with no start seems to happen when car is sitting for 3-4 hours or longer.
Note:
While driving on the hwy on the way back, car would feel like it was going into limp mode. As soon as i hit 120, it would not accelerate. I would coast until speed was at 80km and then i could accelerate again.
Things i've tested and tried:
relay 109=working, swapped with 2 working spares
timing belt checked=not broken, missing teeth etc:
all drive belts good
I.P not leaking
Battery voltage good
fuel is getting to injectors, squirts pretty high
battery connections are clean and tight
ground points are clean and tight
starter/alternator connections clean and tight
fuel shutoff tested=working
I was able to jump start the car and make the drive back to Toronto, which was around a 10 hour drive.
When i arrived in Toronto, i swapped the starter with a used one from a wrecking yard. Exhibited same no start issue.
If anyone has any tips, please advise. I'm totally stumped right now.
Note:
I.P not leaking
