Old July 21st, 2009, 09:55   #1
Keven
Default Flip key went through the wash, can I fix it or do I need to replace it?
My VW key went through the wash about a month ago and stopped working. I took the key apart right away and let it dry while I went out of the country until now. Well I just put it back together hoping that it would be good to go but it isnt. Tried switching batteries too. Can it be fixed? Thanks!
2000 Jetta TDI - 5pd with 190k miles
2002 Jetta TDI Wagon - Auto with 149k miles - Mom's
2004 Jetta TDI - 5 spd with 140k miles - Sister's
Keven is offline   Reply With Quote
Old July 21st, 2009, 10:06   #2
RamMan4x4
RamMan4x4's Avatar
Fuel Economy: 45-55
in my experience, water+circuit boards = new paperweight...but I suppose if you know your way around a board you might be able to fix it. New keyfobs plus programming gets pretty expensive. Do a search on this site, you should be able to find more info.
03 VW Jetta TDI - Silver, PP520, RC3, DG Racepipe, Ventectomy, Old Navy CCV, Koni STR.T, 1" Koni Coils, 4pt lift pads
Useful Links: Vac/Fuel Hose Vac Diagram Limp-Mode Timing Adj Low Power 5th Gear
RamMan4x4 is offline   Reply With Quote
Old July 21st, 2009, 10:12   #3
kcfoxie
kcfoxie's Avatar
Fuel Economy: see fuelly
Clarify for us:
The Key does not start the vehicle.
The key starts the vehicle, but the remote does not work.
Thanks! I know a GTI driver who has washed both fobs many times and it still locks/unlocks the car, just the fob itself is toasted -- an easily replaced/programmed. The key itself is not so easy to cut and program.
14 TDI Beetle: the grey lemon.
kcfoxie is offline   Reply With Quote
Old July 21st, 2009, 12:21   #4
Vince Waldon
Vince Waldon's Avatar
My guess:
The fob is actually two parts... the switchblade and immobilizer chip are in one section and the remote is in the other. The immobilizer chip is passive, the part with the circuit board and battery is the remote and is what will fry under water.
VW will sell you just the remote part... you can get 'em on eBay as well as well as other suppliers. If you have two working remotes still you can program the new one yourself, if not you'll need to search a bit (I believe there's a Vag Com way to adapt the new remote) or get VW to do it.
The immobilizer end is the one that's a PIA to reprogram, so from that persepective you're in luck!
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old July 26th, 2009, 14:41   #5
Keven
The key that went through the wash still unlocks the car and starts the car, just the keyless entry does not work. So if I buy just the back half of the key with the buttons, I should be able to use it and program it with my other key? Any third party keys I should stay away from?
Old July 26th, 2009, 15:42   #6
kcfoxie
kcfoxie's Avatar
You got it!
Pull the bottom half from the top half, it does come apart. You can see the divider line on the front of the key.
Just ensure to get a remote for your year model range and you should be ok. Use your good key as the master key and follow this here:
Insert master key into the ignition lock & switch on the ignition (do not start car).
Using second key lock the vehicle from the outside manually (use key in door lock).
Press unlock button on the remote control one time, wait at least two seconds or more.
Manually open car using key in door lock.
Remove key from ignition.
Test your remote.
If you don't have a master key, there is a vagcom list that you can check for someone local to program the key with vagcom.
Old July 26th, 2009, 21:39   #7
Duster408
Duster408's Avatar
TDI(s): 1998 Jetta
I also ran mine through the wash and it work with a battery replacement, a few weeks later, the girlfriend did the same to her Beetles key and would you believe it works fine with no repair and hers was SOAKING in the washer overnight!!
1998 Jetta TDI Porcelain Blue Metallic, PDR .216 Nozzles, InMotion Stage 2, PD130 Intake (EGR and Cooler delete), Converterectomy, VAG-Com Tool
2007 Honda CRF450X
Exploring anthracite coal mines in the northern field - www.UndergroundMiners.com
Eat more Tastykakes
Duster408 is offline   Reply With Quote
Old July 26th, 2009, 21:42   #8
bigwoode
bigwoode's Avatar
Fuel Economy: 32-36 city, 42-51 hwy
I have washed mine before, replaced the battery and its back to normal. Hit up the watch stand at the mall!!!
2001.5 Jetta GLS TDI -- 5 spd, Sold at 311,393km
"Diesel Fried Chicken"
"There's some ridiculous joke about how "gas" doesn't work too well. It's beyond old." - jcrews
bigwoode is offline   Reply With Quote
Old July 27th, 2009, 09:56   #9
Powder Hound
Powder Hound's Avatar
It all depends on how much corrosion happens to the circuit board. I've run one through the wash a couple of times, but quickly disassembled the unit, carefully wiped the battery cells, watching for corrosion across the seams. Then make sure the contacts on the circuit board are clean, everything is really dry, reassembled, and...
no workie. Rats.
Problem solution was to reverse the cells and put them back in the way they were intended.
Old July 27th, 2009, 12:03   #10
cmitchell
Mine survived the washing machine. I took it apart and let it dry on a sunny window sill for a few days. It still works fine... and it's still on the original battery.
2002 Jetta GLS TDI 5 speed black / black leather
2013 Subaru Outback Limited Cypress Green (Wife's)
1983 Isuzu P'up 4X4 diesel 4 speed
cmitchell is offline   Reply With Quote
Old July 27th, 2009, 16:46   #11
JettaDrvr
This happened to mine just 2 months ago. I thought I had dried mine out enough to get it to work but it wasnt. It was still wet underneith the circuit board. What I did, aand I only did this because I thought it was already ruined, but I took it apart and removed the circuit board, took the batteries out, I poured some 90% Isopropyl alcohol in it and on the circuit board. After that I let it dry a minute, and then I dried all the parts with a har dryer held about 2 feet away on medium and let it dry out - you dont want it to get too hot. I put everything back together...and it works - YMMV though.
JettaDrvr is offline   Reply With Quote
Page generated in 0.13336 seconds with 9 queries
[Output: 100.89 Kb. compressed to 84.61 Kb. by saving 16.28 Kb. (16.14%)]
